MIKROE-2245
MIKROE-2245
    MIKRO
    MATRIX R CLICK
MIKROE-2245 数据手册
Matrix R click PID: MIKROE-2245 Weight: 30 g Matrix R click is a mikroBUS add-on board with two red 5x7 matrices driven by two MAX7219 8-bit LED Display Drivers. The active area of each matrix is 7.62mm high and 5.08 mm wide. 7x5 is a standard resolution for displaying ASCII characters, so the click is essentially a dual-character display capable of showing letters in more readable typefaces compared to a 14-segment display. The click communicates with the target MCU through the mikroBUS:tm: SPI interface with two separate Chip Select lines for each matrix (CSL for the left, CSR for the right). This board is designed to use a 5V power supply. Downloads Matrix R click Examples Matrix R click Schematic Type LED Matrix Applications Compact 7x5 dot matrix text display for user interfaces, for example on vending machines On-board modules Two MAX7219 Key Features A pair of 7x5 LED matrices, 2x MAX7219 8-digit LED Display drivers Key Benefits Displays letters in readable format, Scrolling text capacity Interface SPI,GPIO Input Voltage 5V,5V Compatibility mikroBUS Click board size L (57.15 x 25.4 mm) Features and usage notes The 7x5 LED matrix is a standard resolution for displaying ASCII characters. Matrix click is essentially a dual-character display capable of showing letters in more readable typefaces compared to a 14-segment display. If you double up on a board with two adjacent mikroBUS sockets, such as clicker 2 or Flip & click, you will get four characters. The possibility to horizontally scroll the text makes for a virtually unlimited space for displaying written information. Programming The possibility to horizontally scroll the text makes for a virtually unlimited space for displaying written information. 1 void main() 2 { 3 system_init(); 4 matrix_init(); 5 matrix_text_blink( "MIKROELEKTRONIKA", MATRIX_MED_FAST ); 6 Delay_ms( 1000 );} Code examples that demonstrate the usage of Matrix clicks with MikroElektronika hardware, written for mikroC for ARM, AVR, dsPIC, FT90x, PIC and PIC32 are available on Libstock. https://www.mikroe.com/matrix-r-click 3-8-18
MIKROE-2245 价格&库存
很抱歉,暂时无法提供与“MIKROE-2245”相匹配的价格&库存,您可以联系我们找货
MIKROE-2245
  • 1+73.626451+9.53720
库存:3
MIKROE-2245
    • 1+355.46592
    • 5+348.35327
    库存:3
