MIKROE-2335
MIKROE-2335
    MIKRO
    ATA663211 收发器 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2335 数据手册
      ATA663211 click PID: MIKROE-2335 Weight: 35 g ATA663211 click carries an Atmel LIN transceiver IC designed to handle low-speed data communication in vehicles and in industrial applications with electrically harsh environments. The LIN connection is established by attaching wires to the onboard screw terminals. The click communicates with the target MCU through the UART interface and runs on a 3.3V power supply. ATA663211 click can aslo be used as a standalone LIN transceiver, without being connected to a mikroBUS™ socket. An onboard LDO (low-dropout regulator) enables it to get its power supply through the VS line screw terminal. LIN transceiver LIN or Local Interconnect Network is a protocol used for communicating between components in vehicles. These days cars have hundreds of sensor applications to measure things like temperature, pressure, air flow, speed, etc. All these applications need to communicate with the main system. The LIN bus was created by European car manufactures in order to establish a new, uniform communication standard. It can be used with CAN (Controller Area Network), but LIN is more cost-effective for simple sensor networks in vehicles. For more information see our Learn article on the LIN network protocol. Low current consumption The IC has three very low power modes: normal, sleep and fail-safe. In sleep mode the current consumption is typically 9μA – this is the lowest current consumption mode. It automatically switches to fail-safe mode at system power-up or after a wake-up event. In fail-safe mode it typically uses 80μA. Applications Automotive industry and other electrically harsh environments. Key features      Atmel ATA663211 IC  o Compliant with LIN 2.0, 2.1, 2.2, 2.2A and SAEJ2602‐2  o Data communication up to 20Kbaud  o Power consumption 9μA in sleep mode  o Bus pin is over‐temperature and short‐circuit protected  o Interference and damage protection according to ISO7637  Can be used as a standalone device  Screw terminals for LIN connection  LDO for regulating external power supply  3.3V power supply  Type LIN Applications Automotive industry and other electrically harsh environments On-board modules Atmel LIN transceiver IC Key Features Data communication up to 20Kbaud, Power consumption 9μA in sleep mode, Bus pin is over-temperature and short-circuit protected Key Benefits Can be used as a standalone device, LDO for regulating external power supply Interface UART Power Supply 3.3V Compatibility mikroBUS Click board size M (42.9 x 25.4 mm) What does a LIN transceiver do LIN or Local Interconnect Network is a protocol used for communication between components in vehicles. The car industry has changed profoundly during this century. Cars have hundreds of sensor applications to measure things like temperature, pressure, air flow, speed, etc. All these applications need to communicate with the main system. The LIN bus was created by European car manufactures in order to establish a new, uniform communication standard. It can be used with CAN (Controller Area Network), but LIN is more cost-effective for simple sensor networks in vehicles. But what is the difference between LIN and CAN network protocols? CAN is an a really complex interface, and with so many electronic components in a car the manufactures needed a cheaper alternative. The LIN interface is simpler than CAN — LIN uses a single wire communication and the slave nodes are clocked by only one master. CAN interface has nodes that can act independently, receive messages and act. It can have more than one master on the CAN bus. A LIN network is usually made of up to 16 nodes - one master and 15 slaves. This serial communications protocol is also well suited for other industrial applications with electrically harsh environments. Screw terminals The click has three screw terminals: VS line for the power supply (up to 40V), GND for ground and LIN line for connecting to the other transceiver LIN line. Maximum Ratings This table shows how the pinout on Grid-EYE click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Description Min Typ Max Unit Supply voltage VS -0.3 / +40 V Logic pins voltage levels (RxD, TxD, EN,NRES) -0.3 / +5.5 V Logic output DC currents -5 / +5 mA LIN - DC voltage - Pulse time < 500ms -27 / +40 +43.5 V V INH -DC voltage -0.3 / Vs+0.3 V WKin voltage levels - DC voltage -Transient voltage according to ISO7637 (coupling 1nF), (with 2.7K serial resistor) -0.3 -150 / +40 +100 V ESD according to IBEE LIN EMC Test specification 1.0 following IEC 61000-4-2 - Pin VS, LIN to GND, WKin (with ext. circuitry acc. applications diagram) +-6 ESD HBM following STM5.1 with 1.5kW/100pF - Pin VS, LIN, INH to GND - Pin WKin to GND +-6 +-5 HBM ESD ANSI/ESD-STM5.1 JESD22-A114 AEC-Q100 (002) +-3 kV   kV   kV   CDM ESD STM 5.3.1 Machine Model ESD AEC-Q100-RevF(003) +750   +200   V V Junction temperature +150 C +150 C   Storage temperature -55 Pinout diagram This table shows how the pinout on ATA663211 click corresponds to the pinout on the mikroBUS™ socket. Notes Pin Pin Notes mikroBUStm controls an external voltage regulator INH 1 AN PWM 16 NC Not connected Not connected NC 2 RST INT 15 NC Not connected controls the operating mode of the device EN 3 CS TX 14 RX UART Transmit Not connected NC 4 SCK RX 13 TX UART Receive Not connected NC 5 MISO SCL 12 NC Not connected Not connected NC 6 MOSI SDA 11 NC Not connected +3.3V power input +3.3V 7 3.3V 5V 10 NC Ground GND 8 GND GND 9 GND Not connected Ground Additional pins and jumpers In addition to mikroBUS the click has four additional pins:    WKIN — high‐input voltage pin used to wake up the device from sleep mode.  EN — controls the operating mode of the device.  TXD and RXD — additional UART transmit and receive lines.  EN SEL jumper enables pin selection mode (by default it is always on, good for standalone purposes)  otherwise can be LOW ‐ then it is connected to EN pin on the mikroBUS.  Programming Maximum baud rate which achieved with 2 meter long cable is 19200 bps. Supported compilers C : ARM AVR FT90x PIC PIC32 The following code snippet shows a simple routine which prints received data on a terminal. Any time a click board receives 8 bytes of data it will print received data on another UART. In this case UART3 is used for ATA663211 and UART1 is used to log data. 1 void main() 2 { 3 system_init(); 4 5 while( 1 ) { 6 7 if( Button( &GPIOA_IDR , 5, 100, 1 ) ){ 8 ata663211_send( TX_DATA, sizeof( TX_DATA ) ); 9 UART1_Write_Text( "Data Sent" ); 10 } 11 12 if( ( chk = ata6563_rdy() ) == 8 ){ 13 ata663211_read( buf, chk ); 14 UART1_Write_Text( buf ); 15 } 16 } 17 } https://shop.mikroe.com/click/interface/ata663211 6-13-17
MIKROE-2335 价格&库存
很抱歉,暂时无法提供与“MIKROE-2335”相匹配的价格&库存,您可以联系我们找货
MIKROE-2335
  • 1+172.30735
  • 5+168.86037
库存:9
