USB Wizard
PID: MIKROE-2517
Communicate with up to four USB devices with the USB Wizard.
USB Wizard is an evaluation and demonstration platform featuring the USB4604 USB 2.0 4Port hub controller. The board has four USB 2.0 downstream ports with individual port power
control and overcurrent sense (OCS).
USB Wizard Board can be used as a standalone USB hub, or as an interface to mikroBUS™
socket.
What's on the board
See what the USB Wizard development board has to offer. A reset button and power indication
LEDs, that you already got used to on all our other boards, and a mikroBUS™ socket - add any
functionality, we have more than 300 click boards™ in our range.
On the bottom part of the board, you'll find 4 USB host ports. With the USB Wizard, you will no
longer be running low on USB ports.
USB4604 controller features
The Microchip USB4604 is a low-power, OEM configurable, MTT (Multi-Transaction
Translator) USB 2.0 hub controller with 4 downstream ports and advanced features for
embedded USB applications.
The USB4604 provides an additional USB endpoint dedicated for use as a USB to
I2C/SPI/UART interface, allowing external circuits or devices to be monitored, controlled, or
configured via the USB interface.
What's in the package
The USB Wizard development board is powered directly from the wall power supply. The plug
on the top left part of the board works on a 12V power supply.
You can check out our Wall Power Supply, with a 1.8m long cable that is included in the
package.
The USB Wizard package contains a USB cable as well.
Microchip support
USB Wizard should be used with ProTouch 2 software. You can download the software from
the following link.
You will find the complete user manual on how to use the ProTouch 2 software once you
download and install it.
For technical support concerning the ProTouch 2 software, contact the Microchip Support team.
You can also visit the Microchip forum, and join the discussions with the community.
Open up your possibilities
Did you know that we have more than 300 click boards™ in the shop?
The click board™ range is huge, and it's expanding every day. We have everything from
temperature and humidity sensors, to motor control and wireless connectivity clicks. So, find the
one you need, and utilize the mikroBUS™ socket on the USB Wizard.
Specifications
Type
USB
On‐board modules
USB4604 USB 2.0 4‐port hub controller
Key Features
Supports internal default hub configuration; optionally supports
external configuration via I2C or SPI.
Key Benefits
4 USB host ports
Expandability
mikroBUS™ socket
Input Voltage
12V
Compatibility
mikroBUS
https://shop.mikroe.com/usb‐wizard 9‐6‐17
很抱歉,暂时无法提供与“MIKROE-2517”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+801.60511
- 5+785.56780
