EnOcean 2 click
PID: MIKROE-2521
EnOcean 2 click carries the TCM 515Z transceiver, based on the 2.4 GHz IEEE 802.15.4 radio
standard. The click is designed to run on a 3.3V power supply. It communicates with the target
microcontroller over UART interface.
This low-powered wireless module is intended for use together with EnOcean’s range of energy
harvesting modules. These are miniaturized converters that harness energy from motion, light or
temperature differences, that come in the form of self-powered, battery-free wireless switches,
sensors and actuators.
TCM 515Z
TCM 515Z enables the realization of line-powered actuators, controllers, and
gateways communicating based on the 2.4 GHz IEEE 802.15.4 radio standard.
It provides a transparent radio link between EnOcean 2.4 GHz devices and an external host
connected via the standardized ESP3 interface (EnOcean Serial Protocol V3).
TCM 515Z works on a 2.4 GHz frequency for ZigBee systems.
EnOcean Serial Protocol 3.0 (ESP3)
ESP3 is a Point-to-Point protocol with a packet data structure.
The maximum size of transferred data is 65535 bytes. Compared with ESP2.0, that has the
maximum of 25 bytes, it’s a considerable improvement.
Onboard antenna
TCM 515Z receives and transmits data based on a 50Ω whip antenna connected to its
ANTENNA input.
Key features
TCM 515Z module
o Frequency: 2.4 GHz ZigBee systems
o Receiver sensitivity (typ, at 25°C): ‐95 dBm
o Transmit power (typ, at 25°C): +2 dBm
o Default radio channel: IEEE 802.15.4 radio channel 11
UART interface
3.3V power supply
SPECIFICATION
Product Type
Applications
On-board
modules
RF 2.4GHz
Incorporate battery-free wireless energy harvesting modules into your designs
TCM 515Z
the 2.4 GHz IEEE 802.15.4 radio standard, EnOcean Serial Protocol 3.0, 3.3V
power supply, UART interface
Communicates with battery-free switches, sensors and actuators. Onboard chip
Key Benefits
antenna
Interface
UART
Power Supply
3.3V
Compatibility
mikroBUS
Click board size L (57.15 x 25.4 mm)
Key Features
Pinout diagram
This table shows how the pinout on EnOcean 2 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Not connected NC 1 AN
PWM 16
NC
Not connected
Not connected NC 2 RST
INT 15
NC
Not connected
Not connected NC 3 CS
TX 14 UART_TX UART transmit
Not connected NC 4 SCK
RX 13 UART_RX UART receive
Not connected NC 5 MISO SCL 12
NC
Not connected
Not connected NC 6 MOSI SDA 11
NC
Not connected
NC
Not connected
Power supply +3.3V 7 3.3V
5V 10
Ground GND 8 GND GND 9
GND
Ground
Jumpers and settings
Designator
JP1
Name
TURBO
MODE
Default
Position
Right
Default
Option
Disable
Description
Change the default ESP3 interface speed at power up
from 57600 Bit per second to 460800 Bit per second.
Programming
Code examples for EnOcean 2 click, written for MikroElektronika hardware and compilers are
available on Libstock.
The library implements EnOcean Serial Protocol 3. It can be used for communication between a
host and an EnOcean module. Recieved packets, if valid, are forwarded to a user via the callback
function.
The demo demonstrates the library functionality using EnOcean 2 click and PTM215ZE
Pushbutton Transmitter Module. When the user pushes the button, a corresponding LED is
turned on or off.
Code snippet
The code snippet shows how to use library packet type and send command to an EnOcean
module.
01 static void read_version()
02 {
03
esp3_packet_t cmd_packet;
04
uint8_t cmd_packet_buffer[1];
05
06
cmd_packet.data_length = 1;
07
cmd_packet.option_length = 0;
08
cmd_packet.type = ESP3_TYPE_COMMON;
09
cmd_packet.data_buffer = cmd_packet_buffer;
10
// Command code.
11
cmd_packet_buffer[0] = ESP3_CO_RD_VERSION;
12
13
esp3_send(&cmd_packet);
14 }
https://shop.mikroe.com/click/wireless-connectivity/enocean-2 2/24/2017
很抱歉,暂时无法提供与“MIKROE-2521”相匹配的价格&库存,您可以联系我们找货
