MIKROE-2535
MIKROE-2535
    MIKRO
    4G LTE-NA CLICK NORTH AMERICA
MIKROE-2535 数据手册
    4G LTE‐NA click (North America) PID: MIKROE-2535 4G LTE-NA click carries the LARA-R204 multi-mode cellular module from u-blox. The board is designed to use 5V power supply. I/O voltage levels could be 3.3V or 5V. It communicates with the target microcontroller over UART interface, with additional functionality provided by the following pins on the mikroBUS™ line: AN, RST, CS, PWM, INT Note: The European version of the 4G LTE click is also available.    LARA-R204 overview With a range of interface options and an integrated IP stack, the modules are designed to support a wide range of data-centric applications. The unique combination of performance and flexibility make these modules ideally suited for medium speed M2M applications, such as smart energy gateways, remote access video cameras, digital signage, telehealth, and telematics. 4G LTE-NA click overview The board has a rich set of components to simplify development: two SMA connectors, a MicroUSB port, as well as a SIM card slot. The LARA-R204 module specifies data rates of up to 10.3 Mb/s for Download, and 5.2 Mb/s for Upload. The network protocol stack includes support for TCP, UDP, PPP, MMS, FTP, SMTP, SMTPS, HTTP, HTTPS, PING, and SSL. It covers following LTE bands: 4, 13. Antenna interfaces - The module has two RF pins with a characteristic impedance of 50 Ω. The primary antenna pin (ANT1) supports both Tx and Rx, providing the main antenna interface, while the secondary antenna pin (ANT2) supports Rx only for the LTE Rx diversity configuration A diversity antenna only covers the Rx frequencies, and its job is to acquire an independent sample of data. The application in which you are using the click board can then choose the receive signal it wants to use. Free u-blox software u-blox offers m-centre, a free evaluation software for all their cellular modules. It is an easy to use graphical interface where you can configure the module and save the changes on EPROM. You can also view and edit SIM phonebook entries, send text messages, and communicate with the wireless module using AT commands. 4G LTE explained Simply put 4G is the fourth generation of the cellular network standard. This fourth generation does not support traditional circuit-switched telephony service, but all IP based communication such as IP telephony. If you are not familiar with cellular network standards and protocols and are not sure whether you need GSM or 3G or 4G, read our learn.mikroe.com article about 2G/3G/4G to get a better understanding. LTE or Long Term Evolution, or 4G LTE as it is most commonly called has different categories defined. There are nine different ones so far. LARA-R204 module supports the LTE Cat 1. Key features       LARA‐R204 cellular module   o Data rates of up to 10.3 Mb/s for Download  o Data rates of up to 5.2 Mb/s for Upload  o Covering the following LTE bands: 4,13  SMA antenna connectors  Micro USB connector  Micro SIM card holder  UART interface  5V power supply  Specification  Product Type 4G LTE medium speed M2M applications, such as smart energy gateways, remote Applications access video cameras, digital signage, telehealth, and telematics, and more MCU LARA-R204 cellular module from u-blox Data rates of up to 10.3 Mb/s for Download, Data rates of up to 5.2 Mb/s for Key Features Upload, Covering the following LTE bands: 4,13; Micro SIM card socket, SMA antenna connectors, micro USB connector Interface UART Power Supply 5V Compatibility mikroBUS Click board L (57.15 x 25.4 mm) size     Pinout diagram This table shows how the pinout on 4G LTE-NA click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes    Pin  Pin Notes  mikroBUStm  Module status  STA  1  AN  PWM 16 RI  Ring indicator  Power up module  PWK  2  RST  INT  15 CTS UART Clear to send UART Ready to send  RTS  3  CS  TX  14 TXD UART Transmit data Not connected  NC  4  SCK  RX  13 RXD UART Receive data  Not connected  NC  5  MISO  SCL 12 NC Not connected  Not connected  NC  6  MOSI  SDA 11 NC Not connected  Power supply  +3.3V  7  3.3V  5V  10 +5V Power supply  Ground  GND  8  GND  GND 9 GND Ground  Jumpers and settings Designator  Name  JP1  I/O  SEL.  Default  Position  Left  Default  Option  3V3  Description  Power Supply Voltage Selection 3V3/5V, left position  3v3, right position 5v  Buttons and LEDs Designator  Name  Type (LED, BUTTON...) LD1  NET  LED  LD2  STAT.  LED  Description  Network status LED.  Module Power On status.  Programming Code examples for 4G LTE-NA click, written for MikroElektronika hardware and compilers are available on Libstock. Code snippet The following code snippet shows the SMS composing function. The SMS_RECEIVER is a phone number which will receive the SMS. 01 void C4G_replyToCaller() 02 { 03 char tmp[ 30 ]; 04 char cmdContent[ 30 ]; 05 char replyContent[ 256 ]; 06 strcpy( cmdContent, "AT+CMGS=" ); 07 strcat( cmdContent, SMS_RECEIVER ); 08 strcpy( replyContent, "4G LTE by MikroE rocks!" ); 09 AT_cmdDouble( cmdContent, replyContent ); 10 }                                                     https://shop.mikroe.com/click/wireless‐connectivity/4g‐lte‐na 5‐1‐17
MIKROE-2535 价格&库存
很抱歉,暂时无法提供与“MIKROE-2535”相匹配的价格&库存,您可以联系我们找货
