Grid-EYE click
PID: MIKROE-2539
Weight: 30 g
Grid-EYE click is a 8x8 thermal array sensor-detector that carries the AMG8853 infrared
array sensor from Panasonic. The click is designed to run on either 3.3V or 5V power supply.
It communicates with the target MCU over I2C interface.
Use the Grid-EYE click to detect absolute surface temperature without any contact. Or use it to
detect the movement of people and objects.
Take a look at how Panasonic's AMG8853 64 thermal sensors see a moving hand:
AMG8853 sensor features
The AMG8853 is made out of 64 individual thermal sensors. It can build an image according
to the heat it detects. You don’t need light to form a picture.
The temperature measuring range is from -20°C to +100°C.
The detecting distance is 5m, the viewing angle 60 degrees.
The AMG8853 has a built-in thermistor for suppressing ambient temperature noise.
The I2C levels and address are jumper selectable, while the AMG8853 is supplied with
designated voltage.
Infrared sensor
Infrared waves are outside the visible spectrum of the human eye, just like radio waves. Even
though people can’t see infrared waves, they can certainly feel them, in the form of heat.
Our bodies emit heat or infrared radiation, and the AMG8853 thermal array sensor can detect it.
Key features
AMG8853 infrared array sensor
o 5m detecting distance
o 60 degrees viewing angle
o 0.25°C temperature resolution
o Typical current consumption: 4.5mA
o Time to stabilize the output: 15 seconds
o Frame rate: 1f/sec or 10f/sec
I2C interface
Product Type
Applications
MCU
Key Features
Key Benefits
Interface
Power Supply
Compatibility
Click board size
Temperature / Humidity
Thermal imaging systems, detecting movement of people and objects, etc
AMG8853 thermal array sensor from Panasonic
5 m detecting distance, 60 degrees viewing angle, 64 individual thermal sensors
Detect absolute surface temperature without any contact
I2C
3.3V or 5V
mikroBUS
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on Grid-EYE click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Not connected NC 1 AN
PWM 16 NC Not connected
Not connected NC 2 RST
INT 15 INT INT out to MCU
Not connected NC 3 CS
TX 14 NC Not connected
Not connected NC 4 SCK
RX 13 NC Not connected
Not connected NC 5 MISO SCL 12 SCL I2C SCK
Not connected NC 6 MOSI SDA 11 SDA I2C data
Power supply +3.3V 7 3.3V
5V 10 +5V Power supply
Ground GND 8 GND GND 9 GND Ground
Jumpers and settings
Default
Position
Designator Name
Default
Option
Description
JP1
LOGIC
SEL
Left
3.3V
Logic Level Voltage Selection, left position 3.3V,
right position 5V
JP2
ADDR
SEL
Right
I2C address selection, right 0 (0b1101 000) Left 1
(0b1101 001)
Buttons and LEDs
Designator Name Type (LED, BUTTON…)
PWR
Power LED
Description
Power supply LED, lights green when power is on.
Maximum ratings
Description
Min Typ Max Unit
Supply Voltage (with AMG8853 module) 5
5
V
I2C Levels (JP1 select)
V
INT out (JP1 select)
V
Programming
Code examples for Grid-EYE click, written for MikroElektronika hardware and compilers are
available on Libstock.
Code snippet
This code converts the grid array sensor data to temperature [in C] and fills the grid array drawn
on the TFT display by the appropriate color, depending on the temperature detected.
01 void main() {
02
// Initialize pins as digital I/O
03
AD1PCFG = 0xFFFF;
04
JTAGEN_bit = 0;
05
06
// Initialize I2C2 module
07
I2C2_Init(100000);
08
Delay_ms(100);
09
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
// Draw screen
DrawScreen();
// variable declaration
x_start = 80;
element_dimension = 20;
j = 0;
// Set AMG88 sensor registers
GridEye_WriteByte(0x00,0x00);
GridEye_WriteByte(0x01,0x30);
GridEye_WriteByte(0x02,0x00);
Delay_ms(100);
GridEye_WriteByte(0x08,0x30);
GridEye_WriteByte(0x09,0x00);
// INTHL
// INTHH
GridEye_WriteByte(0x0A,0x15);
GridEye_WriteByte(0x0B,0x00);
// INTLL
// INTLH
GridEye_WriteByte(0x0C,0x20);
GridEye_WriteByte(0x0D,0x00);
Delay_ms(100);
// IHYSL
// IHYSH
// small delay
Normal mode
Flag reset
Frame mode 10FPS
small delay
// Temperature register value
register_address = 0x80;
while(1) {
// Reading grid temperature
for(i = 0; i < 64; i++) {
// multiply the values with 0.25 to get temperature in [C]
gridArray[i] = (float)GridEye_ReadWord(register_address) * 0.25L;
// increment register address by 2
register_address = register_address + 2;
// draw grid
// set row position
Set_Row_Position();
// set color
color = Set_Color();
54
// set grid element number
55
j++;
56
57
// fill grid element with color
58
TFT_Set_Brush(1, 0, 1, LEFT_TO_RIGHT, color, color);
59
60
// draw grid element
61
TFT_Rectangle(x_start + (element_dimension * (j - 1)), y_start ,
x_start + (element_dimension * j), y_end);
62
63
// if more than 8 elements in the row, reset counter
64
if (j >= 8) {
65
j = 0;
66
67
68
69 }
https://shop.mikroe.com/click/sensors/grid-eye 3/21/2017
很抱歉,暂时无法提供与“MIKROE-2539”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1055.839901+137.20909
- 国内价格
- 1+473.05314
- 3+454.13389
- 国内价格 香港价格
- 1+521.728891+67.80000
