WiFi ESP click
PID: MIKROE-2542
WiFi ESP click carries the ESP-WROOM-02 module that integrates ESP8266EX. The click is
designed to run on a 3.3V power supply. It communicates with the target microcontroller over
UART interface and the following pins on the mikroBUS™ line: RST, CS.
Access point and WiFi client mode
WiFi ESP click can function in both AP (Access Point) WiFi mode, as well as in WiFi client
mode. The click brings easy implementation and usage.
The module supports the following network protocols: IPv4/TCP/UDP/HTTP/FTP. Thanks to
this the click can operate as a client device requesting a file from a file server device (FTP - file
transfer protocol) in local network systems, or request a web page via internet (IP/TCP/HTTP). It
can also be used as a small web server, for example a wireless weather station prototype, etc.
Station mode is default when the click is in WiFi client mode.
ESP‐WROOM‐02 module features
ESP-WROOM-02 carries ESP8266EX highly integrated Wi-Fi SoC solution to meet the
continuous demands for efficient power usage, compact design and reliable performance in the
industry.
Besides the Wi-Fi functionalities, ESP8266EX integrates an enhanced version of Tensilica’s
L106 Diamond series 32-bit processor and on-chip SRAM. As well as antenna switches, RF
balun, power amplifier, low noise receiver amplifier, filters and power management modules.
With the complete and self-contained Wi-Fi networking capabilities, it can perform as either a
standalone application (WROOM module itself) or the slave to an MCU host which is the
primary intention of the click board as a whole. So, this click board is applied to any
microcontroller design as a Wi-Fi adaptor through UART interface (RX,TX lines on mikroBUS
pin socket).
For more information see the datasheet.
http://www.espressif.com/sites/default/files/documentation/0c-esp-wroom-02_datasheet_en.pdf
Advanced usage
There are additional pad headers onboard (HSPI/GPIO interface of the module) for advanced
usage.
For more information see the Documentation tab.
Key features
ESP‐WROOM‐02 module
o 802.11 b/g/n
o Protocols: IPv4/TCP/UDP/HTTP/FTP
o Frequency range: 2.4 GHz ~ 2.5 GHz
o 32‐bit processor
o on chip SRAM
PCB antenna
UART interface
3.3V power supply
Product Type
Applications
MCU
Key Features
Wi-Fi
Create smart appliances, home automation systems, wireless data loggers, etc
ESP-WROOM-02
Protocols: IPv4, TCP/UDP/HTTP/FTP, 802.11 b/g/n standard, UART interface,
3.3V power supply
Key Benefits
Interface
Power Supply
Compatibility
Click board
size
The click can function in both AP mode and WiFi client mode
UART
3.3V
mikroBUS
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on WiFi ESP click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Not connected NC 1 AN
PWM 16 NC Not connected
HW Reset RST 2 RST
INT 15 NC Not connected
Chip enable (active
EN 3 CS
high)
TX 14 TX
UART0_TXD / Transmit end in UART download
(program) mode
Not connected NC 4 SCK
RX 13 RX
UART0_RXD / Receive end in UART download
(program) mode
Not connected NC 5 MISO SCL 12 NC Not connected
Not connected NC 6 MOSI SDA 11 NC Not connected
Power supply +3.3V 7 3.3V
5V 10 NC Not connected
Ground GND 8 GND GND 9 GND Ground
Additional pins
Name I/O
CLK
Description
IO HSPI_CLK / GPIO14
SDO IO HSPI_MISO / GPIO12
SDI
IO HSPI_MOSI / GPIO13
CS
IO HSPI_CS / GPIO15
IO0
IO GPIO0 (UART download mode ‐ pull down, Flash boot ‐ pull up)
GND
GND
Buttons and LEDs
Designator Name Type (LED, BUTTON…)
LD1
PWR LED
Description
Power Supply ON
Programming
Code examples for WiFi ESP click, written for MikroElektronika hardware and compilers are
available on Libstock.
Code snippet
This code snippet configures GPIO ports, initializes the display and prepares the WiFi module.
In an endless loop, LED is enabled or disabled by a button, and that information is then sent to
the server.
01 void main() {
02
03
// Initialize variables
04
length = 0;
05
state = 0;
06
response_rcvd = 0;
07
responseID = 0;
08
response = 0;
09
i = 0;
10
11
// GPIO Direction
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
GPIO_Digital_Input( &GPIOA_IDR, _GPIO_PINMASK_4 );
GPIO_Digital_Output( &GPIOD_BASE, _GPIO_PINMASK_13 );
GPIO_Digital_Output( &GPIOC_BASE, _GPIO_PINMASK_2 );
GPIO_Digital_Output( &GPIOA_ODR, _GPIO_PINMASK_0 );
// UART Initialization
UART3_Init_Advanced( 115200, _UART_8_BIT_DATA,
_UART_NOPARITY,
_UART_ONE_STOPBIT,
&_GPIO_MODULE_USART3_PD89);
// Enable Interrupts
RXNEIE_USART3_CR1_bit = 1;
NVIC_IntEnable( IVT_INT_USART3 );
EnableInterrupts();
display_init();
// Initialize WiFI module
WiFi_Init();
// Setting WiFi Mode - SoftAP + station mode
WiFI_Configure();
state = 100;
i = 0;
TFT_Write_Text("Please connect to your STAIP...", 50, 100);
Delay_ms(20000);
WiFi3_Send();
TFT_Write_Text("Entering button toggling loop.", 50, 150);
LED_switching = 1;
while( 1 )
// detect logical one on PA4 pin
if (Button(&GPIOA_IDR, 4, 1, 1))
oldstate_A4 = 1;
// detect logical one-to-zero transition on PA4 pin
if (oldstate_A4 && Button(&GPIOA_IDR, 4, 1, 0))
if ( !strcmp(txt_state_A0, "OFF
57
58
", 8 );
59
60
61
62
63
", 8 );
64
65
66
67
68
69
70
71 }
strncpy( txt_state_A0, "ON
GPIOA_ODR.B0 = 1;
else
strncpy( txt_state_A0, "OFF
GPIOA_ODR.B0 = 0;
oldstate_A4 = 0;
A0_change = true;
WiFi3_Send();
https://shop.mikroe.com/click/wireless-connectivity/wifi-esp 3/21/2017
