MIKROE-2564
MIKROE-2564
    MIKRO
    键锁 人机接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2564 数据手册
      Keylock click PID: MIKROE-2564 Keylock click carries a processed sealed key lock mechanism that can be set in three different ositions. The click is designed to run on either 3.3V or 5V power supply. It communicates with the target microcontroller over the PWM, INT, and AN pin on the mikroBUS™ line. The key can be removed from the lock in any of the three positions. The package contains two keys and one protective cap. Keylock features The contact mechanism provides unequaled logic-level reliability and smoother, positive detent actuation. Detent mechanism, with its spring-operated steel ball, gives crisp, positive action for accurate switch setting. Specifications Type  Joystick  Applications  Use the three different positions of the mechanism to turn applications on or off, for  home security applications, for industrial equipment, etc.  On‐board  modules  Keylock switch with 3 positions  Interface  GPIO  Input Voltage  3.3V or 5V  Click board size  S (28.6 x 25.4 mm)  Pinout diagram This table shows how the pinout on Keylock click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes  Pin  Pin  Notes    Output position 1  1  1  AN  PWM  16  2  Output position 2  NC  2  RST  INT  15  3  Output position 3  NC  3  CS  TX  14  NC        NC  4  SCK  RX  13  NC      NC  5  MISO  SCL  12  NC      NC  6  MOSI  SDA  11  NC      Power supply  +3.3V  7  3.3V  5V  10  +5V  Power supply  Ground  GND  8  GND  GND  9  GND  Ground  Programming Code examples for Keylock click, written for MikroElektronika hardware and compilers are available on Libstock. Code snippet This is a simple example of how Keylock click works, depending on the state of the Keylock click the appropriate position will be detected. 01 02 03 04 05 06 07 08 09 uint8_t state; char txt[20]; void systemInit() { ANCON0 = 0x00; ANCON1 = 0x00; ANCON2 = 0x00; UART1_Init(9600); 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 } void Keylock_Init() { KEYLOCK_STATE_1_Direction = 1; KEYLOCK_STATE_2_Direction = 1; KEYLOCK_STATE_3_Direction = 1; } void Keylock_Task() { state = KEYLOCK_STATE_1*1 + KEYLOCK_STATE_2*2 + KEYLOCK_STATE_3*3; UART1_Write_text("Keylock is in state:"); IntToStr(state,txt) ; UART1_Write_Text(txt); UART1_Write_Text( "rn" ); delay_ms(500); } void main() { systemInit(); Keylock_Init(); while( 1 ) { Keylock_Task(); } }                                                    https://shop.mikroe.com/keylock‐click 9‐29‐17
MIKROE-2564
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管集电极,6脚光电晶体管发射极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输入电流为10mA,输出电流为10mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:EL817广泛应用于数字通信、测量控制等领域。
7. 封装信息:EL817采用DIP-6封装形式。
MIKROE-2564 价格&库存
很抱歉,暂时无法提供与“MIKROE-2564”相匹配的价格&库存,您可以联系我们找货
MIKROE-2564
    • 1+215.56643
    • 5+211.24469
    库存:5
