MAC Address click
PID: MIKROE-2733
MAC Address click provides a unique node address for your application. It also has 1Kbit of writable
EEPROM memory. MAC Address click carries the 24AA025E64 2K I2C Serial EEPROM with EUI‐64™ node
identity. The click is designed to run on either 3.3V or 5V power supply. MAC Address click
communicates with the target microcontroller over I2C interface.
24AA025E64 features
The Microchip Technology Inc. 24AA025E64 is a 2Kb Serial EEPROM with a pre-programmed
IEEE EUI-64 MAC Address. The device is organized as two blocks of 128 x 8-bit memory with
a 2-wire serial interface. Low voltage design permits operation down to 1.7V, with maximum
standby and active currents of only 1 uA and 1 mA, respectively. The 24AA025E64 also has a
page write capability for up to sixteen bytes of data.
Specifications
Type
EEPROM
On‐board
modules
24AA025E64 2K I2C Serial EEPROMs with EUI‐64™ node identity from Microchip
Key Features
Pre‐programmed globally unique, 64‐bit node address; more than 1 Million
erase/write cycles
Key Benefits
1Kbit of writable EEPROM memory
Interface
I2C
Input Voltage
3.3V or 5V
Click board size
S (28.6 x 25.4 mm)
Pinout diagram
This table shows how the pinout on MAC Address click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
NC
1
AN
PWM
16
NC
NC
2
RST
INT
15
NC
NC
3
CS
TX
14
NC
NC
4
SCK
RX
13
NC
NC
5
MISO
SCL
12
SCL
I2C clock
NC
6
MOSI
SDA
11
SDA
I2C data
Power supply +3.3V
7
3.3V
5V
10
+5V
Power supply
Ground
8
GND
GND
9
GND
Ground
GND
Jumpers and settings
Designator Name
Default
Position
Default
Option
Description
JP2
ADD
SEL
Down
I2C slave address A0 (LSB) bit selection 0/1, down
position 0, upper position 1.
JP3
ADD
SEL
Down
I2C slave address A1 bit selection 0/1, down position 0,
upper position 1.
PWR SEL
PWR
SEL
Left
3.3V
Power Supply Voltage Selection 3V3/5V, left position
3V3, right position 5V
Programming
Code examples for MAC Address click, written for MikroElektronika hardware and compilers
are available on Libstock.
Code snippet
The following code reads one byte from EEPROM and transmits data to UART.
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
if( !MACADDRESS_readByte( loop, &read ) )
LOG( "rn Byte value [ " );
ByteToHex( read, txt );
Ltrim( txt );
LOG( txt );
LOG( " ] succeessfully read from [ " );
ByteToHex( loop, txt );
Ltrim( txt );
LOG( txt );
LOG( " ] address" );
else
LOG( "rn Read Byte Error" );
https://shop.mikroe.com/mac‐address‐click 9‐6‐17
很抱歉,暂时无法提供与“MIKROE-2733”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+96.768451+12.51848
