MIKROE-2750
MIKROE-2750
    MIKRO
    DS28E17 1-Wire 转 I2C 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2750 数据手册
        1-Wire I2C click PID: MIKROE-2750   1-Wire I2C click carries DS28E17 1-Wire-to-I2C master bridge from Maxim Integrated. The click runs on a 3.3V power supply. It communicates with the target microcontroller over 1-Wire® protocol, using the following pins on the mikroBUS™ line: AN, PWM, RST. How the click works There are two on-board screw terminals used for connecting SCL, SDA, Vcc and GND of the I2C slave. After that, you are able to communicate with that slave through the onboard DS28E17 MCU. DS28E17 features The DS28E17 is a 1-Wire slave to I2C master bridge device that interfaces directly to I2C slaves at standard (100kHz max) or fast (400kHz max). Data transfers serially through the 1-Wire® protocol, which requires only a single data lead and a ground return. Every DS28E17 is guaranteed to have a unique 64-bit ROM registration number that serves as a node address in the 1-Wire network. Specifications Type  1‐wire  Applications  1‐Wire I2C click can be used to extend the length of I2C lines by converting I2C to 1‐ wire  On‐board  modules  DS28E17 1‐Wire‐to‐I2C master bridge from Maxim Integrated  Interface  1‐wire,GPIO  Input Voltage  3.3V  Click board size  S (28.6 x 25.4 mm)  Pinout diagram This table shows how the pinout on 1-Wire I2C click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes  Pin  Pin  Notes    1‐Wire 1st pin  OW1  1  AN  PWM  16  OW2  Reset pin  2  RST  INT  15  NC  RST  1‐Wire 2nd pin    NC  3  CS  TX  14  NC      NC  4  SCK  RX  13  NC      NC  5  MISO  SCL  12  NC      NC  6  MOSI  SDA  11  NC      Power supply  +3.3V  7  3.3V  5V  10  NC    Ground  GND  8  GND  GND  9  GND  Ground  Programming Code examples for 1-Wire I2C click, written for MikroElektronika hardware and compilers are available on Libstock. Code snippet The following code snippet shows 1-Wire I2C click communication with the Thermo 4 click. It uses skipRom, writeI2C, and readI2C commands to read the temperature data from the sensor, and displays it back via UART output. 01 void One_Wire_I2C_Task() 02 { 03 char uartText [20]; 04 char IWireData [20]; 05 06 IWireData [0] = 0x00; //Thermo 4 temperature register address 07 08 OWI2C_skipRom (); 09 OWI2C_writeI2C ( OWI2C_WRITE_NORMAL_NOSTOP, 0x48, 1, &IWireData); //0x48 is unshifted I2C address of Thermo 4 click 10 OWI2C_skipRom (); 11 OWI2C_readI2C ( 0x48, 2, &IWireData); 12 13 UART_Write (13); 14 UART_Write (10); 15 UART_Write_Text("Current temperature is: "); 16 ByteToStr(IWireData[0], uartText); 17 UART_Write_Text(uartText); 18 19 Delay_ms (2000); 20 }        https://shop.mikroe.com/1‐wire‐i2c‐click 9‐29‐17
MIKROE-2750 价格&库存
很抱歉,暂时无法提供与“MIKROE-2750”相匹配的价格&库存,您可以联系我们找货
MIKROE-2750
  • 1+225.37627
  • 5+220.87749
库存:4
MIKROE-2750
  • 1+210.364181+27.12000
库存:1
