Ozone 2 click
PID: MIKROE-2767
Ozone 2 click carries an MQ131 sensor for Ozone (O3). The sensor outputs an analog voltage,
which is converted by the onboard MCP3551 22-bit ADC converter or it is sent to the
microcontroller via AN pin on the mikroBUS™, depending on the position of ADC SEL.
jumper. The click is designed to run on 5V power supply. It communicates with the target
microcontroller over SPI interface or AN pin on the mikroBUS™ line.
Note: The click carries TXB0106 Voltage Translator. For selecting the interface voltage level,
use the onboard jumper, and choose between the 3.3V and 5V. For more information, see the
Jumpers and Settings table below.
MQ131 sensor features
MQ131 is a semiconductor sensor for Ozone (O3). The gas sensing layer on the sensor unit is
made of Tin dioxide, which has lower conductivity in clean air. The sensor’s conductivity is
higher with the rising of the gas concentration. The sensor consists of micro Al2O3 ceramic tube,
Tin dioxide sensitive layer, measuring electrode and heater fixed into stainless steel net. The
heater provides necessary conditions for the proper functioning of the sensitive components.
Calibrating the sensor
To calibrate the sensor for the environment you’ll be using it in, Ozone 2 click has a small
potentiometer that allows you to adjust the Load Resistance of the sensor circuit. For precise
calibration, the sensor needs to preheat (once powered up, it takes 48h to reach the right
temperature).
Specifications
Type
Gas
Applications
It can be used in different Ozone concentration detectors for air quality control, or for
gas leak detection.
On‐board
modules
MQ131 sensor, MCP3551
Key Features
Ozone concentration 10‐1000 ppm, communicates over the AN pin or ADC MCP3551,
sensitivity Rs(in air)/Rs(in 50 ppm O3)≥3, onboard potentiometer for calibration
Interface
SPI
Input Voltage
3.3V or 5V
Compatibility
mikroBUS
Click board size L (57.15 x 25.4 mm)
Pinout diagram
This table shows how the pinout on Ozone 2 click corresponds to the pinout on the mikroBUS™
socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
Analog pin
AN
1
AN
PWM
16
NC
NC
2
RST
INT
15
NC
MCP3551 chip select CS
3
CS
TX
14
NC
SPI clock pin
SCK 4
SCK
RX
13
NC
SPI slave data out pin SDO 5
MISO SCL
12
NC
NC
6
MOSI SDA
11
NC
Power supply
+3.3V 7
3.3V
5V
10
+5V
Power supply
Ground
GND 8
GND
GND
9
GND
Ground
Jumpers and settings
Designator Name
Default
Position
Default
Option
Description
JP1
VCCIO
SEL.
Left
3V3
Power Supply Voltage Selection 3V3/5V, left position
3V3, right position 5V
JP2
ADC
SEL.
Left
EXT
Analog signal selection. Left position ADC located on the
click board, right position AN pin of mikroBUS™
LEDs, Buttons, Switches, Connectors, etc.
Designator Name
LD1
PWR LED
Type (LED,
BUTTON...)
Description
Power LED, lights green when power supply is established
properly.
Programming
Code examples for Ozone 2 click, written for MikroElektronika hardware and compilers are
available on Libstock.
Code snippet
The following code snippet outputs data from Ozone 2 click ADC reader via UART
01: void Ozone_2_Task()
02: {
03:
uint32_t readValue;
04:
uint8_t loggerTxt [40];
05:
readValue = OZONE2_Read();
06:
LongToStr(readValue, loggerTxt);
07:
UART1_write_text("rnRead value:");
08:
UART1_write_text(loggerTXT);
09:
10:
delay_ms(1000);
11: }
https://shop.mikroe.com/ozone‐2‐click 9‐29‐17
很抱歉,暂时无法提供与“MIKROE-2767”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+472.319531+61.02000
