MIKROE-2766
MIKROE-2766
    MIKRO
    DRV10983 电机控制器/驱动器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2766 数据手册
        Brushless 3 click PID: MIKROE-2766       Brushless 3 click carries the DRV10983, a three‐phase sensorless motor driver with integrated power  MOSFETs. When an external power supply is applied, you can drive a brushless DC motor through the  PWM pin, AN pin or I2C interface. It communicates with the target microcontroller over I2C interface,  with the additional functionality provided by the following pins on the mikroBUS™ line: PWM, AN, INT,  RST.    A 3 wire BLDC motor can be connected over the screw terminals.    DRV10983 driver features  The DRV10983 is a three-phase sensorless motor driver with integrated power MOSFETs, which can provide continuous drive current up to 2A. The DRV10983 uses a proprietary sensorless control scheme to provide continuous sinusoidal drive, which significantly reduces the pure tone acoustics that typically occurs as a result of commutation. The interface to the device is designed to be simple and flexible. The motor can be controlled directly through PWM, analog, or I2C inputs. Motor speed feedback is available through either the FG pin or I2C. Specifications Type  DC  Applications  The automotive industry, drones (because of the good power‐to weight ratio of  brushless motors), computers, medical equipment, HVAC systems, small home  appliances, robotics, battery powered systems, small cooling fans in computers, toys, etc. On‐board  modules  DRV10983, a three‐phase sensorless motor driver with integrated power MOSFETs.  Key Features  Input voltage range from 8V to 28V  Interface  GPIO,I2C  Click board  size  M (42.9 x 25.4 mm)  Pinout diagram This table shows how the pinout on Brushless 3 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes  Pin  Pin  Notes    NC  1  AN  PWM  16  PWM  PWM output  Direction  DIR  2  RST  INT  15  INT  FG signal output  NC  3  CS  TX  14  NC        NC  4  SCK  RX  13  NC      NC  5  MISO  SCL  12  SCL  I2C clock  NC  6  MOSI  SDA  11  SDA  I2C data  NC  7  3.3V  5V  10  NC        Ground    GND  8  GND  GND  9  GND  Ground  Jumpers and settings Designator  Name  Default Position  Default Option JP1  SPEED  Left  PWM  Description  Speed mode selection between analog and PWM. Programming Code examples for Brushless 3 click, written for MikroElektronika hardware and compilers are available on Libstock. Code snippet The following code snippet sets the motor paremeters and measures the motor velocity. 01 sbit BRUSHLESS_3_DIR_PIN at LATC.B0; 02 sbit BRUSHLESS_3_DIR_PIN_Direction at TRISC.B0; 03 sbit BRUSHLESS_3_PWM_PIN at LATC.B1; 04 sbit BRUSHLESS_3_PWM_PIN_Direction at TRISC.B1; 05 uint8_t motorParameters [12] = { 0x39, 0x1E, 0x3A, 0x08, 0x50, 0xDA, 0x8B, 0x10, 0x27, 0x37, 0x04, 0x0C} ; 06 uint16_t Velocity; 07 char text[10]; 08 void systemInit() 09 { 10 ANCON0 = 0x00; 11 ANCON1 = 0x00; 12 ANCON2 = 0x00; 13 BRUSHLESS_3_DIR_PIN_Direction = 0; 14 BRUSHLESS_3_PWM_PIN_Direction = 0; 15 I2C1_Init (100000); 16 Delay_ms(100); 17 BRUSHLESS_3_I2CdriverInit( I2C1_Start, I2C1_Stop, I2C1_Repeated_Start, I2C1_Wr, I2C1_Rd); 18 UART1_Init(9600); 19 Delay_ms(100); 20 UART1_Write_Text("Init"); 21 } 22 void Brushless_3_Init() 23 { 24 BRUSHLESS_3_DIR_PIN = 0; 25 BRUSHLESS_3_PWM_PIN = 1; 26 writeParameters(motorParameters); 27 } 28 void Brushless_3_Task() 29 { 30 getSpeed(&Velocity); 31 IntToStr(Velocity,text); 32 UART1_Write_Text( "Motor freq :" ); 33 UART1_Write_Text(text); 34 UART1_Write_Text( "Hzrn" ); 35 delay_ms(1000); 36 } 37 void main() 38 { 39 systemInit(); 40 Brushless_3_Init(); 41 while( 1 ) 42 { 43 Brushless_3_Task(); 44 } 45                                                 https://shop.mikroe.com/brushless‐3‐click 9‐29‐17
MIKROE-2766 价格&库存
很抱歉,暂时无法提供与“MIKROE-2766”相匹配的价格&库存,您可以联系我们找货
MIKROE-2766
  • 1+183.66885
  • 5+179.99276
库存:7
