MIKROE-2781
MIKROE-2781
    MIKRO
    MCP6022,PD-V11 微波 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2781 数据手册
    Microwave click PID: MIKROE-2781 Weight: 30 g       Microwave click detects movement, thanks to the PD-V11 a 24GHz microwave motion sensor. The typical use for Microwave click is a proximity or motion detector in various applications and devices. The Microwave click can detect movement or proximity by using the Doppler effect. The onboard microwave motions sensor transmits waves, and picks them back as they hit an object, with their frequency changed. Microwave click does not need optical visibility to work, and the waves can penetrate many kinds of barriers and obstacles. What's on the Microwave click How the Microwave click works Microwave click detects movement of objects utilizing Doppler effect. When the PD-V11 microwave sensor is powered on, it starts transmitting radio waves of fixed frequency. As the waves hit a moving object they are reflected back toward PD-V11 microwave motion sensor, with their frequency changed, depending on speed and direction of object's movement. The Doppler effect - a change in frequency of a wave for the observer and object move closer or further apart from one another. A typical example of the Doppler effect is when a vehicle with siren passes and you hear the pitch drop of the siren. The PD-V11 microwave motion sensor low power consumption, low noise, and a low wireless power output. See the datasheet to learn more. https://download.mikroe.com/documents/datasheets/PD-V11.pdf The PD-V11 microwave motion sensor picks up reflected waves and converts them to a voltage signal. This signal has the magnitude of several hundred microvolts, so it's sent to the MCP6022 which amplifies the signal, in order to make it readable over the Analog pin on the mikroBUS™. This signal is amplified up to 3.3V. Once amplified, the signal is routed to the Analog pin (OUT) on the mikroBUS™ line. The proximity of the object can be determined by measuring the amplitude of this signal, and speed/direction by determining its frequency. The range at which Microwave click can detect movement depends on the way the algorithm is written (see the Software Support section). Specifications Type Motion Key Features Frequency: 24GHz; Radiated power (EIRP): 2.5mW; noise: 4.5 mVrms; current consumption: 35 mA; Interface Analog Input Voltage 5V Click board size L (57.15 x 25.4 mm) Pinout diagram This table shows how the pinout on Microwave click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Amplified sensed signal output OUT 1 AN PWM 16 NC NC 2 RST INT 15 NC NC 3 CS TX 14 NC NC 4 SCK RX 13 NC NC 5 MISO SCL 12 NC NC 6 MOSI SDA 11 NC NC 7 3.3V 5V 10 +5V Power supply GND 8 GND GND 9 GND Ground Ground Pin Onboard settings and indicators Label Name Default PWR Power - Description Power LED, lights green when the power supply is established properly. Notes Software Support We provide a demo application for the Microwave click on LibStock, as well as a demo application (example), developed using MikroElektronika compilers. The demo application can run on all the main MikroElektronika development boards with minimal change to the code depending on the microcontroller used. Examples Description The application is composed of three sections : 1. System Initialization - GPIO, UART, and MCU ADC module initialization 2. Application Initialization - Measurement of initial reference ADC value used for comparison and movement calculation 3. Application Task - (code snippet) Sequential operation:  Takes exact amount of samples  Calculation of difference between taken samples and reference ADC value  Reports movement if difference is greater than threshold value void applicationTask() { char txt[ 50 ]; uint16_t counter = uint16_t single = uint16_t sampler = uint32_t sum = uint16_t detector = 0; 0; 0; 0; 0; // SAMPLING for (sampler = 0; sampler < _SAMPLES_COUNT; sampler++ ) { single = ADC1_Get_Sample( 8 ); if (single < reference) { sum += single; counter++; } } LATD = 0x00; measurement // CALCULATION if (0 != counter) // Turn off D port before next { detector = sum / counter; // REPORTING if ((detector + _THRESHOLD) < reference) { WordToStr( detector, txt ); UART2_Write_Text( "rnMOVE " ); UART2_Write_Text( txt ); LATD = 0xFF; // Turn on D port to report movement Delay_1ms(); } } } The threshold value and number of samples taken per sequence can be easy adjusted by changing the _SAMPLES_COUNT and _THRESHOLD constants. Setting the samples count to values greater than 500 may slow down your application. The optimal value for this kind of application is 100. The optimal threshold value depends on the resolution of the MCU's internal ADC module. A small threshold will make the application more sensitive and extend the range of the detection. This example demonstrates how the click board™ can detect human movement up to 1,5m. Note that this is a simple demonstration - a more accurate movement detection requires real digital signal processing. The board used for this demo must be still during the initialization process (power on). The full application code, and ready to use projects can be found on LibStock. Other mikroE Libraries used in the example:   UART Conversions Additional notes and information Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all Mikroelektronika compilers, or any other terminal application of your choice, can be used to read the message.                                          https://shop.mikroe.com/microwave‐click 11‐3‐17
MIKROE-2781 价格&库存
很抱歉,暂时无法提供与“MIKROE-2781”相匹配的价格&库存,您可以联系我们找货
MIKROE-2781
  • 1+263.916131+34.24290
库存:3
