MIKROE-2801
MIKROE-2801
    MIKRO
    PROXIMITY 3 CLICK
MIKROE-2801 数据手册
  Proximity 3 click PID: MIKROE-2801 Weight: 22 g Proximity and light sensing Proximity 3 click is an intelligent proximity and light sensing device, which features the VCNL4200 sensor from Vishay - high sensitivity long distance proximity sensor (PS), ambient light sensor (ALS) and 940 nm IRED, all in one small package. With its smart sensing and light conditioning properties, the Proximity 3 click can be used in a wide range of applications: adjusting the brightness of the TFT screen depending on ambient light, turning off the TFT background light if it is covered, very accurate lux meters, reliable security sensors and so on. How the Proximity 3 click works Proximity 3 click uses the VCNL4200 sensor, which combines matched 940 nm IR emitter and a photodiode for proximity measurement and ambient light sensing. VCNL4200 offers programmable measurement by utilizing the advanced signal processing techniques, allowing the sensor to operate in various conditions. Communication with the microcontroller is done via the I2C interface so that the host controller can set the measurement parameters and request results back from the sensor. Both low and high threshold values for the measured property can also be set via the I2C so that the interrupts can be generated every time the threshold value is exceeded. This allows for the reduced need of the sensor polling, which can result in better power management. With MikroElektronika library functions, setting up the registers is really easy and the tedious task of initializing the sensor is taken care of with a few simple function calls. More information about the sensor's registers and addresses can be found in the VCNL4200 datasheet. The Filtron™ technology used in the ALS, allows the sensor to match the ambient light spectral sensitivity to human eye response and it's immune to fluorescent light flicker. This ensures the accuracy of the measurements. The maximum detection range is selectable (197 / 393 / 786 / 1573 lux) with highest sensitivity 0.003 lux / step. The proximity sensor uses advanced ambient and background light cancellation schemes, so it is fairly immune to interferences that might occur in this case. This allows for a quite precise proximity detection. The sensor can work either in 12-bit or 16-bit mode, selectable by I2C command. The click's range is up to 1.5m. VCNL4200 input voltage is 3V3, while the separate 5V supply rail is used to supply power for the IR emitter pulses, generated by the small external P-channel MOSFET (Q1). This way, the power dissipation of the IRED drive is displaced from the chip, and the high-current IRED drive pulses are isolated from the sensitive integrated circuit sections, connected to the 3V3 rail. Specifications Type  Proximity  Applications  Adjusting the brightness of the TFT screen depending on ambient light, turning off the  TFT background light if it is covered, very accurate lux meters, reliable security sensors,  etc.  On‐board  modules  VCNL4200 sensor ‐ high sensitivity long distance proximity sensor (PS), ambient light  sensor (ALS) and 940 nm IRED, intelligent background light cancellation   Proximity distance up to 1.5 m, immunity to the red glow (940 nm IRED) and fluorescent  Key Features  light flickering, selectable maximum detection range (197 / 393 / 786 / 1573) lux with  highest sensitivity 0.003 lux/step  Interface  I2C  Input Voltage  3.3V,5V  Click board  size  S (28.6 x 25.4 mm)  Pinout diagram This table shows how the pinout on Proximity 3 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes  Pin  Pin  Notes    NC  1  AN  PWM  16  NC  NC  2  RST  INT  15  INT  NC  3  CS  TX  14  NC  NC  4  SCK  RX  13  NC  NC  5  MISO  SCL  12  SCL  I2C clock  NC  6  MOSI  SDA  11  SDA  I2C data    Interrupt output            Power supply  +3.3V  7  Ground  GND  8  3.3V  5V  10  +5V  Power supply  GND  GND  9  GND  Ground  Proximity 3 click maximum ratings Description  Min  Typ  Max  Unit Supply voltage  2.5  3.3  3.6  V  Supply voltage for IRED  3.8  5.0  5.5  V  Operation temperature range  ‐40  +85 °C  Supply current  350 µA   IRED driving current  800   Full ALS counts  mA   65535 steps 4095/65535 steps   Full PS counts    I2C clock (std mode / fast mode)  10/10 100/400 kHz Measurement distance  1.5   m    Onboard settings and indicators Label  Name  Default   Description  ‐  Power LED indicates that the click is powered on PWR  Power LED  Software Support We provide a demo application for the Proximity 3 click on our LibStock page, developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards with minimal change to the code depending on the microcontroller used. Library Description This library contains a set of functions, necessary to work with the Proximity 3 click. Key functions uint16_t prox3_readALS() - Reads value from ALS register uint16_t prox3_readPS() - Reads value from PS register uint16_t prox3_getDistance() - Calculating distance uint16_t prox3_getIlluminance() - Calculating illuminance Examples Description This is a simple demonstration of sensor functionality, where the user can read the distance and illuminance data from Proximity 3 click. Distance and illuminance values are sent via UART. The application is composed of three sections:    System Initialization ‐ I2C and UART module initialization  Application Initialization ‐ Sends HAL pointers, and initializes the VCNL4200  Application Task ‐ Sequential reading of the distance, proximity and ambient light data from the  sensor and logging it to UART, every second  void applicationTask() { // DISTANCE READ AND CONVERT VALUE TO STRING resultPS = prox3_getDistance(); IntToStr( resultPS, txt1 ); // WRITES INFORMATION UART1_Write_Text( UART1_Write_Text( UART1_Write_Text( TO UART "Proximity: ~ " ); txt1 ); " cmrn" ); // AMBIENT LIGHT READ AND CONVERT VALUE TO STRING resultALS = prox3_getIlluminance(); IntToStr( resultALS, txt2 ); // WRITES INFORMATION UART1_Write_Text( UART1_Write_Text( UART1_Write_Text( TO UART "Ambient Light: " ); txt2 ); " luxrn" ); Delay_ms(1000); } The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example:    I2C  UART  Conversions  Additional notes and information Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message.                                               https://www.mikroe.com/proximity‐3‐click 12‐5‐17
MIKROE-2801
物料型号:Proximity 3 click,型号为MIKROE-2801。
器件简介:Proximity 3 click是一款智能接近和光照感测设备,集成了Vishay的VCNL4200传感器,具备高灵敏度长距离接近传感器(PS)、环境光传感器(ALS)和940nm红外发射二极管(IRED)。
引脚分配:该板通过mikroBUS插座与微控制器通信,包括PWM、RST、INT、TX、RX、SCL、SDA等引脚,以及3.3V和5V的电源和地线。
参数特性:Proximity 3 click可检测距离最远1.5米,对红光(940nm IRED)和荧光灯闪烁具有免疫力,可选择最大检测范围(197/393/786/1573)勒克斯,最高灵敏度为0.003勒克斯/步。
功能详解:通过VCNL4200传感器,Proximity 3 click可以进行接近度测量和环境光感测,支持通过I2C接口进行参数设置和结果读取。它还具有智能背景光消除功能,提高了接近检测的准确性。
应用信息:适用于调整TFT屏幕亮度、关闭被覆盖时的背景光、高精度勒克斯表、可靠的安全传感器等。
封装信息:Click板尺寸为S(28.6 x 25.4 mm),供电电压为3.3V和5V,操作温度范围为-40℃至+85℃。
软件支持:MikroElektronika提供了一个演示应用程序,可在LibStock页面上找到,使用MikroElektronika编译器开发,可在所有主要的MikroElektronika开发板上运行,代码更改最小。
MIKROE-2801 价格&库存
很抱歉,暂时无法提供与“MIKROE-2801”相匹配的价格&库存,您可以联系我们找货
MIKROE-2801
  • 1+149.89677
  • 5+146.89759
库存:1
