Buck-Boost click
PID: MIKROE-2806
Weight: 25 g
High-efficiency buck-boost DC/DC converter
Buck-Boost click™ features LTC3129-1, a buck-boost DC/DC conversion integrated circuit
from Linear Technology®. The click supports a wide input voltage range and can output eight
discrete regulated output voltage levels, selectable by the digital output voltage selection pins,
ranging from 2.5V to 15V.
The main features of this converter are its very low noise and low ripple at the output, as well as
very high regulating efficiency and low quiescent current. A proprietary switch control algorithm
allows the buck-boost converter to maintain output voltage regulation with input voltages that
are above, below or equal to the output voltage. Transitions between the step-up or step-down
operating modes are seamless and free of transients and sub-harmonic switching. Manufacturing
quality and the design of the Buck-Boost click PCB, ensures that the electrical characteristics are
kept within the specs.
Those features make the Buck-Boost click a perfect solution for the regulators and postregulators for harvested energy, solar panel post-regulators/chargers, rechargeable battery output
voltage regulators, wireless low noise applications and similar.
How the click works
The active component of this click board™ is LTC3129-1, a buck-boost DC/DC conversion
integrated circuit from Linear Technology®. The LTC3129-1 uses an ultra-low noise 1.2MHz
PWM switching architecture, that minimizes the solution footprint by allowing for the low
profile inductors and ceramic capacitors to be used.
Buck-Boost click is able to work in two different modes of operation, depending on the nature of
the application it is used in - PWM mode and Burst mode.
When the PWM mode is selected, LTC3129-1 operates in a fixed 1.2MHz PWM mode, using an
internally compensated average current mode control loop. In PWM mode, ripple and the noise
level of the output voltage are minimal.This mode can be selected by setting the PWM pin to
logic high level (e.g. connected to VCC). The PWM mode is suitable for working with higher
loads connected to the converter output and when the extremely low output noise is required.
For high-efficiency operation at light loads, automatic Burst Mode operation can be selected,
reducing the quiescent current down to 1.3µA. Burst mode can be selected if the PWM pin is set
to a logic low level (e.g. connected to GND). If the connected load is light enough, the converter
will remain working in burst mode, running only when necessary to maintain voltage regulation.
Otherwise, the PWM mode will be automatically engaged, providing enough current for the
connected heavier load.
The Buck-boost click powers itself completely from the VIN terminal. Once the power is applied
to the VIN terminal, the circuit also has to be enabled by setting the RUN pin to a high logic
level. This will power up the converter, which will be indicated by the PWR LED.
The RUN pin function can be utilized to prolong the battery life - for example - the converter can
be turned off, preventing draining of the LiPo battery below a certain voltage.
Selection of the desired output voltage is done by setting the output voltage selection pins, as in
the table below:
Voltage selection pins settings
VS3 / CS
VS2 / AN
VS1 / INT
VOUT
2.5V
3.3V
4.1V
1
5.0V
1
6.9V
1
8.2V
1
1
12V
1
1
1
15V
Specifications
Type
Boost,Buck
Applications
Regulators and post‐regulators for harvested energy, solar panel post‐
regulators/chargers, rechargeable battery output voltage regulators, wireless low noise
applications, etc.
On‐board
modules
LTC3129‐1
Key Features
Low noise and ripple on the output voltage, high efficiency, wide range of input
voltages, selectable stabilized voltage values on the output
Interface
Analog,GPIO
Click board
size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on Buck-Boost click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
Output voltage select
pin
VS2
1
AN
PWM
16
PWM
Mode select pin
Enable pin
RUN
2
RST
INT
15
VS1
pin
pin
VS3
3
CS
TX
14
NC
NC
4
SCK
RX
13
NC
NC
5
MISO
SCL
12
NC
NC
6
MOSI
SDA
11
NC
NC
7
3.3V
5V
10
NC
Ground
GND
8
GND
GND
9
GND
Buck‐Boost click electrical specifications
Description
Input voltage range (VIN)
Min
Typ
1.92
Output voltage range (VOUT) 2.425
Max
Unit
15
V
15.50
V
Quiescent current
1.3
1.9
3
µA
Inductor average current limit
80
200
350
mA
Ground
Onboard settings and indicators
Label
Name
Default
Description
PWR Power LED
Power LED indicates that the click is powered on
TB1
VIN
Input voltage connector
TB2
VOUT
Output voltage connector
Software support
We provide a library for the Buck-Boost Click on our LibStock page, as well as a demo
application (example), developed using MikroElektronika compilers. The demo can run on all
the main MikroElektronika development boards.
Library provides the functions that set the voltage level. You can choose between 8 available
voltage levels, from 2.5V to 15V.
Key functions
void buckboost_set_2500mV() - Sets Vout to 2.5V
void buckboost_set_2300mV() - Sets Vout to 3.3V
void buckboost_set_4100mV() - Sets Vout to 4.1V
void buckboost_set_5000mV() - Sets Vout to 5.0V
void buckboost_set_6900mV() - Sets Vout to 6.9V
void buckboost_set_8200mV() - Sets Vout to 8.2V
void buckboost_set_12000mV() - Sets Vout to 12.0V
void buckboost_set_15000mV() - Sets Vout to 15.0V
Examples description
The application is composed of three sections:
System initialization ‐ GPIO initialization
Application initialization ‐ Sends HAL pointers and initializes the click
Application task ‐ Cycling VOUT through all of the available voltage levels, in 3 seconds steps.
void applicationTask()
buckboost_set_2500mV();
Delay_ms(3000);
buckboost_set_3300mV();
Delay_ms(3000);
buckboost_set_4100mV();
Delay_ms(3000);
buckboost_set_5000mV();
Delay_ms(3000);
buckboost_set_6900mV();
Delay_ms(3000);
buckboost_set_8200mV();
Delay_ms(3000);
buckboost_set_12000mV();
Delay_ms(3000);
buckboost_set_15000mV();
Delay_ms(3000);
https://www.mikroe.com/buck‐boost‐click 12‐5‐17
很抱歉,暂时无法提供与“MIKROE-2806”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.759651+1.78105
- 国内价格
- 1+191.66667
- 5+187.83438
