Thermo J click
PID: MIKROE-2811
Weight: 25 g
Thermo J click is a temperature measurement click board™, which uses a thermocouple type-J
probe, connected to a PPC-SMP-J onboard connector. The active part of the Thermo J click
is MCP9600 by Microchip - a thermocouple EMF to temperature converter, with 1.5°C of
maximum accuracy. The onboard PCC-SMP-J connector ensures the secure connection and
accurate readings for the connected thermocouple.
The main advantage of the thermocouples over some other types of temperature measuring
devices is a wide range of temperatures that they can measure. With the addition of four
programmable ALERT lines routed to the mikroBUS™ pins, Thermo J click is an ideal solution
for the temperature measurements in extreme conditions, hard to reach places, machinery, and
similar applications.
How does the click work?
Thermo J click utilizes the thermoelectric principles for measuring the temperature. When the
thermocouple joint, made of two different conductive materials, is exposed to a measuring
temperature (hot end), a potential difference will be generated at the open ends of the circuit
(cold end). The generated electromotive force (EMF) at the open ends of the circuit can be
measured and converted into a digital form, by the 18-bit delta-sigma AD converter section of
the MCP9600 IC.
To obtain the desired measurement of the temperature, the cold end temperature needs to be
known, too. Since the MCP9600 features an integrated measurement of the ambient temperature
(cold junction compensation), error corrected value can be read directly from the registers, using
the I2C bus protocol.
The generated EMF depends on the materials that are used for the thermocouples.Those
materials are standardized and categorized by types. This click uses the type-J thermocouples,
composed of iron and constantan. The measuring range of this device for the type J probes, is
from -150°C to 1200°C, but it depends on the used probes. Thermo J click uses a specially
constructed PPC-SMP-J onboard connector for easy and secure thermocouple connection.
There are four ALERT lines present on the MCP9600. Those lines can be programmed by the
I2C to be set to a HIGH logic level when certain temperature thresholds are reached. The lines
are routed to the AN, RST, PWM and INT pins of the mikroBUS™.
The I2C address can be selected with the ADDR SEL onboard SMD jumper. The I2C address
can be changed by this jumper, allowing for more than one of these click boards to be used on a
system, each with the different I2C address.
The click board™ can be set to work with both 3.3V or 5V, selectable from the mikroBUS™.
This can be done by the onboard SMD jumper, labeled as PWR SEL. This allows for this click
board™ to be used on a wide range of different MCUs, both 3.3V and 5V tolerant.
Note: Thermo J click needs Thermocouple Type-J probes which are sold separately.
Specifications
Type
Temperature
Applications
Ideal solution for the temperature measurements in extreme conditions, hard to reach
places, machinery, and similar applications.
Key Features Measuring wide range of temperatures, ranging from ‐150°C to 1200°C ‐ depending on the
used probes, comes with the PCC‐SMP‐Type‐J connector for the secure connecting of the
thermocouple probes, integrated cold junction compensation.
Interface
GPIO,I2C
Input
Voltage
3.3V or 5V
Click board
size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on Thermo J click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
Alert 4 output ALERT4
1
AN
PWM
16
ALERT2
Alert 2 output
Alert 3 output ALERT3
2
RST
INT
15
ALERT1
Alert 1 output
3
CS
RX
14
NC
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
SCL
I2C clock
NC
6
MOSI
SDA
11
SDA
I2C data
Power supply 3V3
7
3.3V
5V
10
5V
Power supply
8
GND
GND
9
GND
Ground
Ground
GND
Thermo J click electrical specifications
Description
Min
Typ
Max
Unit
I/O pins voltage ratings
2.7
5.5
V
I2C clock frequency
10
100
kHz
‐150
1200
°C
Measuring range for the Type J probes
Onboard settings and indicators
Label
Name
Default
Description
JP1 PWR SEL
Left Power supply voltage selection. Left position 3.3V, right position 5V
JP2 ADDR SEL
Left I2C address selection. Left position is 1100000x, right position is 1100111x.
PWR Power LED
Power LED indicates that the click is powered on
Software support
We provide a library for the Thermo J click on our LibStock page, as well as a demo application
(example), developed using MikroElektronika compilers. The demo can run on all the main
MikroElektronika development boards.
Library Description
The library contains functions which are used to communicate and control the Thermo J click.
Temperature read and write functions require the I2C slave address as an argument - so that more
than one device with the different slave addresses can be used on the same I2C bus.
Key functions
float THERMOJ_getTemperature(uint8_t slaveAddress) - Returns current temperature in
Celsius
void THERMOJ_write_byte(uint8_t slaveAddress, uint8_t registerAddress,
uint8_t value) - Writes single byte to any register
uint8_t THERMOJ_read_byte(uint8_t slaveAddress, uint8_t registerAddress) -
Reads single byte from any register
Examples Description
The application is composed of three sections:
System Initialization ‐ Initializes pins, I2C peripheral, UART used for logging
Application Initialization ‐Initializes driver and configures module
Application Task ‐ (code snippet) Sequential temperature measurement every 500 milliseconds.
Measurement readings will be logged to UART
The full application code, and ready to use projects can be found on our LibStock page.
void applicationTask()
temperature = THERMOJ_getTemperature(_THERMOJ_ADDRESS_GND);
FloatToStr(temperature,text);
LOG_write("Current temperature: ", _LOG_TEXT);
LOG_write(text, _LOG_LINE);
Delay_ms(500);
Other MikroElektronika libraries used in the example:
UART
Conversions
Additional notes and information
Depending on the development board you are using, you may need USB UART click, USB UART 2 click
or RS232 click to connect your PC for development systems with no UART to USB interface available on
the board. The terminal available in all MikroElektronika compilers, or any other terminal application of
your choice can be used to read the message.
https://www.mikroe.com/thermo‐j‐click 12‐5‐17
