MIKROE-2817
MIKROE-2817
    MIKRO
    MAX11300 ADC/DAC 模块 数据采集 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2817 数据手册
      PIXI™ click PID: MIKROE-2817 Weight: 28 g PIXI™ click is equipped with MAX11300 IC from Maxim Integrated, which features Maxim Integrated's versatile, proprietary PIXI™ technology - it is the industry's first configurable 20channel mixed-signal data converter. Besides the 12bit multichannel SAR ADC and buffered DAC, it also features one internal and two external temperature sensors for tracking the junction and the environmental temperatures. Adjacent pairs of ports can be configured as logic-level translators for open-drain devices or analog switches. Each port is individually configurable with up to four selectable voltage ranges within -10 V to +10 V. PIXI™ ports provide highly flexible hardware configuration for 12-bit mixed-signal applications. The MAX11300 is best suited for applications that demand a mixture of several analog and digital functions, such as monitoring and adjusting the bias on the power amplifiers, digital level shifters, automatic fan speed controllers, etc. Actually, it can easily adapt to specific application requirements, allowing for an easy reconfiguration, which makes it usable in virtually any embedded application. How does it work? The main component of PIXI™ click is the MAX11300 integrated circuit. The main feature of this IC is the proprietary PIXI™ technology. PIXI™ is an abbreviation for the Programmable mIXed signal In/Out, a technology that allows very flexible routing of both digital and analog signals. The MAX11300 IC has 20 configurable mixed-signal I/O ports. Each port can be independently configured as a DAC output, an ADC input, a GPI, a GPO, or an analog switch terminal. User-controllable parameters are available for each of those configurations. The device also features one internal and two external temperature sensors with the ±1˚C accuracy. The device uses the SPI Mode 0 interface for the communication with the controller, with the clock up to 20MHz.   Analog to Digital Converter The MAX11300 device features a12bit successive approximation (SAR) ADC module, which can sample signals on a single port up to 400Ksmp/S. Like all the segments of this device, it also offers great flexibility; the signal can be both unipolar or bipolar. Each ADC-configured port can be programmed for one of four input voltage ranges: 0V to +10V, -5V to +5V, -10V to 0V, and 0V to +2.5V. There are two inputs for the reference voltage, but also internal reference voltage of 2.5V can be used, instead. The converter can be triggered by the CNVT# pin, routed to the PWM pin of the mikroBUS™. This pin has to stay in the LOW logic state for at least 0.5 µs to trigger the conversion. There are several modes of conversion, which include sampling on a single port, or sweeping through all the configured ADC ports. ADC offers the averaging feature, too. It can average readings of the ADC-configured ports to blocks of 2, 4, 8, 16, 32, 64, or 128 conversion results. Digital to Analog Converter The buffered DAC converter is also 12bit, which can output up to 25Ksmp/s on a single port. The output stage of the DAC is equipped with the driver, which offers ±10V on output and high current capability, by using the dedicated power supplies (AVDDIO, AVSSIO pins of the PIXI™ header). The DAC module also uses internal or external reference voltage. The flexibility of the PIXI™ routing also allows monitoring of the DAC configured ports by utilizing the ADC module. All the DAC ports are protected from overcurrent and such events can generate an interrupt on the INT pin, routed to the INT# pin on the mikroBUS™. General‐Purpose Inputs and Outputs (GPIO) Each of the PIXI™ ports can be configured either to be the general purpose input or general purpose output pin (GPI/GPO). When set as the GPI pin, the programmable threshold can be set by its data register, from 0 up to the AVDD voltage. The events like rising edges, falling edges or both can be sensed this way, generating an interrupt. A GPO pin can have a programmed HIGH logic level, up to four times of the DAC referent voltage. The host can set the logic state of GPO-configured ports through the corresponding GPO data registers. By combining GPI and GPO configured ports, unidirectional and bidirectional level translator paths can be formed, allowing all kinds of level shifters to be built. Bidirectional level translators are built using adjacent pairs of pins and are meant to work as the open drain drivers, so the pullup resistors should be used to achieve proper voltage levels. Analog Switch Operation Mode Two adjacent PIXI™ ports can form an analog switch with the internal resistance of 60Ω, which is controlled in two ways:   The signal flow through the two adjacent ports can be controlled by any other GPI PIXI™ port,  that is used as the switch.  The internal switching PIXI™ port is programmed to be permanent ON until that port is set to a  high‐impedance mode by the host controller.  Temperature sensors The MAX11300 device also features two external sensors and one internal sensor, covering the range from -40°C to +150°C with a good accuracy of ±1˚C. The external sensor can be a simple diode-connected NPN transistor such as 2N3904, which can be used to measure the die temperature of some other integrated circuits. The MAX11300 device also features the parasitic resistance cancellation mode, for the connected temperature sensing element. Temperature can be read from the temperature registers, with the 0.125°C per LSB value. Other features There are several other useful features on the MAX11300 device, such as the advanced interrupt management that triggers an interrupt for many various events. Interrupts can also be masked, allowing only the desired interrupts to affect the INT pin state of the click. The separate pins for the analog GND and digital GND contribute to the signal quality, especially when it comes to mixed-signal applications, where analog signal paths can easily be influenced by the digital signal interferences. Features such as the Burst Transaction Address Incrementing Modes, simplify the firmware development. While using the simple address incrementing mode, the initial register address pointer will keep incrementing automatically after each read/write cycle, as long as the device stays asserted by the CS pin and the serial clock keeps running. The contextual incrementing mode works similar to the previous mode, with the added ability to loop back to the initial start address, after one group of registers has been cycled through. The contextual incrementing mode works only for DAC and ADC configured port registers. For more information about the registers, please refer to the datasheet of the MAX11300. Specifications   Type  ADC,DAC  Best suited for applications that demand a mixture of several analog and digital  Applications  functions, such as monitoring and adjusting the bias on the power amplifiers, digital level  shifters, automatic fan speed controllers, etc.  On‐board  modules  Maxim Integrated MAX11300  Maxim Integrated proprietary PIXI™ technology featuring versatile routing of all of the 20  Key Features  PIXI™ ports, allowing realization of many different mixed signal applications with a single  IC, wide range of input and output voltages, both bipolar and unipolar.  Interface  GPIO,SPI  Input Voltage  3.3V or 5V  Click board  size  L (57.15 x 25.4 mm)  Pinout diagram This table shows how the pinout on PIXI™ click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes  Pin  Pin  Notes    NC  1  AN  PWM  16  CNV  ADC trigger control  NC  2  RST  INT  15  INT  Interrupt output  Chip select  CS  3  CS  TX  14  NC  SPI clock   SCK  4  SCK  RX  13  NC  SPI data output  SDO  5  MISO  SCL  12  NC  SPI data input  SDI  6  MOSI  SDA  11  NC  Power supply  +3.3V  7  3.3V  5V  10  +5V  Power supply  Ground  GND  8  GND  GND  9  GND  Ground      PIXI™ click electrical specifications Description  Min  Typ  Max  Unit  Analog power supply voltage (AVDD)  4.75  5  5.25  V  Digital power supply voltage (DVDD)  2.50  3.3  5.50  V  External supply positive voltage AVDDIO  AVDD  15.75 V  External supply negative voltage AVSSIO  ‐12  0 V  AVDD  24 V  External supply AVDDIO to AVSSIO  Note: For the correct setting of the AVDDIO and AVSSIO voltages, please refer to the MAX11300 datasheet Onboard settings and indicators Label  Name  Default   Description  LD1  PWR  ‐  Power LED indicator  HD1  Port  header  ‐  20 pin PIXI™ ports connection  HD2  Port  header  ‐  External power, diode temp sensors, analog, references, +5V on board and  common GND connection pins  JP1  Logic Sel  Left  Logic voltage level selection, left position 3V3, right position 5V  Software Support We provide a library for PIXI™ click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description Key functions void pixi_writeRegister(uint8_t registerAddress , uint16_t registerData) - Generic function for writing to registers. uint16_t pixi_readRegister(uint8_t registerAddress)- Generic function for reading from registers. Examples Description Simple example of LED blinking off all PIXI™ click pins, ports are configured by writing messages to the appropriate registers via the SPI interface. The low-level communication is taken care of inside the MikroElektronika functions. Registers can be easily accessed with two simple functions: pixi_writeRegister is the register writing function, which accepts two parameters. The first parameter of the function is the 8bit register that needs to be written, while the second parameter is the 16bit data that is written to the register provided with the first parameter. This function does not return any value pixi_readRegister is used to read the content of a certain register, which is forwarded as an 8bit parameter. This function returns 16bit data which represents the contents of the register, forwarded as the parameter. The simple application example periodically sets all the GPIO pins to 5V and then to 0V, with one second delay. More information about the registers and their functions can be found in the MAX11300 datasheet. void applicationTask() { pixi_writeRegister(0x0D, pixi_writeRegister(0x0E, Delay_ms(1000); pixi_writeRegister(0x0D, pixi_writeRegister(0x0E, Delay_ms(1000); } 0xFFFF); //setting all GPIO to 5V 0x000F); 0x0000); //setting all GPIO to 0V 0x0000); The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example:  SPI  Additional notes and information Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message.        https://www.mikroe.com/pixi‐click 12‐20‐17
MIKROE-2817 价格&库存
很抱歉,暂时无法提供与“MIKROE-2817”相匹配的价格&库存,您可以联系我们找货
MIKROE-2817
  • 1+384.133101+48.92430
库存:23
