MIKROE-2871
MIKROE-2871
    MIKRO
    MCP2122T-E/SN,TFDU4101 收发器 RF mikroBUS™ Click™ 平台评估扩展板
MIKROE-2871 数据手册
IrDA 3 click PID: MIKROE-2871 IrDA 3 click is an intelligent IR transceiver device that can both send and receive UART commands via the IR interface. IrDA 3 click features both the IR transceiver and the encoder/decoder IC, used to convert the UART data and send or receive it in IrDA® compatible format. IrDA 3 click also has an onboard clock generator for the fastest possible UART performance of 115,200 bps, so it does not need an additional clock signal to be generated by the MCU. IrDA 3 click provides a direct and easy to use UART to IrDA interface. The device can be used for various applications that use the short-range remote communication, such as fax machines, photocopiers, screen projectors, TV boxes, Data loggers, GPS, various system controllers and many other IRDA standard compatible applications. How does it work? IrDA 3 click is composed of two integrated devices. The first one is the TFDU4101 transceiver from Vishay, an infrared transceiver module compliant to the latest IrDA® physical layer standard. It supports IrDA speeds up to 115.2 Kbps. The transceiver module is composed of the IRED (infrared emitter) and the photodiode IR receiver, which is used to both emit and receive the IR light commands. The range of this device is more than 1m and it depends on several factors. To ensure maximum possible range, the power supply is decoupled with proper capacitors, also the used oscillator is very stable and accurate, resulting with the range of about 4m. The second IC device is the MCP2122, an infrared half duplex encoder/decoder from Microchip that takes care of the proper conversion of the UART signals to TFDU4101 acceptable IrDA standard compliant data format. The MCP2122 has its UART interface pins routed to the mikroBUS™, and IrDA interface pins routed to the TFDU4101 IrDA module. The maximum communication speed for the UART interface is determined by the onboard oscillator that works at 1.8432MHz. The MCP2122 has the 16XCLK input that acts as a bit clock. The state of the bit is determined within 16 clock cycles of the 16XCLK input. This means that for every bit of the UART information, 16-bit clock cycles are needed - so the UART frequency is the bit clock frequency divided by 16, as shown by this formula: 1,843,200 / 16 = 115,200. At the same time, 115,200 is the maximum baud rate that can be used for the TFDU4101 IrDA transceiver. The click also has a voltage selection jumper for selecting the voltage between 3.3V and 5V. Besides the UART RX and UART TX signals routed to the mikroBUS™, it also has the RESET signal routed to the RST pin of the mikroBUS™. The RESET pin is used to reset the MCP2122 device. The LOW logic state on this pin will reset the device, while the HIGH state is used for a normal operation. The device can be put in a low power state if the RST pin is held LOW. Working with this click board is easy and the demo application that comes with the click board™ can be used as a reference for future designs. Besides the demo application example, the library provides functions for simplified workflow with the IrDA 3 click. Specifications Type Optical Applications IrDA 3 click can be used for various applications that use the short-range remote communication, such as fax machines, photocopiers, screen projectors, TV boxes, Data loggers, GPS, various system controllers and many more. On-board modules MCP2122 - Infrared Encoder/Decoder, TFDU4101 transceiver Key Features Simple and easy to use UART to IRDA communication, the onbard encoder/decoder IC takes care of all the communication between the IR transceiver and the MCU. Interface GPIO,UART Input Voltage 3.3V or 5V Click board size M (42.9 x 25.4 mm) Pinout diagram This table shows how the pinout on IrDA 3 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin Notes NC 1 AN PWM 16 NC RST 2 RST INT 15 NC NC 3 CS RX 14 TX UART Transmit NC 4 SCK TX 13 RX UART Receive NC 5 MISO SCL 12 NC NC 6 MOSI SDA 11 NC Power Supply +3.3V 7 3.3V 5V 10 +5V Power Supply Ground GND 8 GND GND 9 GND Ground Reset IrDA 3 click electrical specifications Description Min Input logic LOW level voltage GND Typ Unit 0.2 x VCC V Input logic HIGH level voltage 0.8 x VCC UART baud rate Max VCC 115,200 V bps Onboard settings and indicators Label Name Default LD1 PWR JP1 PWR SEL Left Description Power LED indicator Power supply voltage selection: left position 3V3, right position 5V Software support We provide a library for IrDA 3 click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers and mikroSDK. The provided click library is mikroSDK standard compliant. The demo application can run on all the main MikroElektronika development boards. Library description The library contains functions that perform UART reading and writing. Key functions: void irda3_writeByte(uint8_t input); - Function writes (sends) one byte to the UART RX buffer uint8_t irda3_readByte(); - Function reads (receives) one byte from the UART RX buffer uint8_t irda3_byteReady(); - Function checks state of the RX buffer (new data is placed in) void irda3_reset(); - Function resets the and sets back in normal operating mode Example description • • • System Initialization - Initializes peripherals and pins. Application Initialization - Initializes click driver. Application Task - Checks if new data byte has been received in the RX buffer (ready for reading), and if ready than reads one byte from the RX buffer. In second case application task writes message data via UART and IR interface. void applicationTask() { uint8_t tmp; uint8_t rdyFlag; // RECEIVER - UART polling #ifdef __RX__ rdyFlag = irda3_byteReady(); if (1 == rdyFlag) { tmp = irda3_readByte(); mikrobus_logWrite( &tmp, _LOG_BYTE ); } #endif // TRANSMITER - TX each 2 sec #ifdef __TX__ for (tmp = 0; tmp < 9; tmp++) { irda3_writeByte( MESSAGE_DATA[tmp] ); mikrobus_logWrite( "MESSAGE SENT", _LOG_LINE ); } Delay_ms(2000); #endif } The full application code, and ready to use projects can be found on our LibStock page. Additional notes and information Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message. mikroSDK This click board is supported with mikroSDK - MikroElektronika Software Development Kit. To ensure proper operation of mikroSDK compliant click board demo applications, mikroSDK should be downloaded from the LibStock and installed for the compiler you are using. For more information about mikroSDK, visit the official page. Downloads mikroBUS™ Standard specification LibStock: mikroSDK MCP2122 datasheet IrDA 3 click schematic LibStock: IrDA 3 click library IrDA 3 click - 2D and 3D files https://www.mikroe.com/slider-click 1-18-18
MIKROE-2871 价格&库存
很抱歉,暂时无法提供与“MIKROE-2871”相匹配的价格&库存,您可以联系我们找货
MIKROE-2871
  • 1+247.55774
  • 5+242.61117
库存:32
