ATA663254 click
PID: MIKROE-2872
Weight:
ATA663254 click is a fully integrated LIN transceiver device with an integrated 5V LDO
voltage regulator. The combination of voltage regulator and bus transceiver makes it possible to
develop simple but powerful slave nodes in LIN bus systems. The integrated LDO can be used to
provide power to the host MCU so that no additional voltage regulators are required, only the
power supply connected to the LIN connector is needed. ATA663254 click features the
undervoltage protection, short-circuit protection, TXD time-out timer and its LIN physical layer
complies with LIN 2.0, 2.1, 2.2, 2.2A and SAEJ2602-2 standard specifications.
These features make ATA663254 click a perfect solution for realizing small and portable LIN
based networks that are commonly used in automotive applications for communicating with the
vehicle sensor peripherals, but also for any application where robust and interference-free
communication up to 20Kbps is needed.
How does it work?
LIN (Local Interconnect Network) is a serial network protocol used for communication between
components in vehicles. LIN networks are cheaper than CAN networks and since the LIN
network can have up to 15 slave nodes, it is often used as a subnetwork of CAN.
ATA663254 click uses the ATA663254 integrated LIN bus transceiver with the 5V voltage
regulator from Microchip. The ATA663254 communicates with the MCU by using the UART
RX and TX signals. Besides for communication, these pins also serve to signal the failsafe
condition. The failsafe condition can be caused by the undervoltage on the LIN connector: less
than 3.9V will cause the undervoltage condition, signaled by the LOW logic state on RX pin and
HIGH logic state on the TX pin. A wake-up event from either silent or sleep mode is signaled by
the LOW logic state on both of the RX and TX pins. This event is being received via the LIN bus
and it is used to switch the ATA663254 click to an active state. RX and TX signals are also
routed to the header on the edge of the click board™ so they can be used independently of the
mikroBUS™ socket.
The NRES pin of the ATA663254 IC is routed to the RST pin on the mikroBUS™. RST pin is
used to signal the undervoltage condition on the LDO regulator section. When the LDO voltage
falls under the predefined threshold, the RST pin will be set to a LOW logic state, signaling this
condition to the MCU. The LDO output is routed to a header located on the edge of the click so
that the LDO can be used independently of the mikroBUS™ socket. Also, there is an SMD
jumper that can be shorted if powering up the MCU via the mikroBUS™ 5V pin is required, on a
custom board design. Note that the MikroElektronika development systems are not meant to be
powered up by the mikroBUS™ power supply pins, so the ATA663254 click comes without the
SMD jumper, by default.
The EN pin is used to enable the functionality of the device. When the EN pin is set to a HIGH
logic level, the device is set to work in the normal mode, with the transmission paths from TXD
to LIN and from LIN to RXD both active. When the EN pin is set to a LOW state, the device is
put into silent mode, depending on the TX pin state. The EN pin has a pull-down resistor, so it is
pulled to Ground if it is left afloat.
Besides the 5V LDO output header and the external UART header, the click is equipped with the
three pole connector for an easy and secure connection to the LIN network and the 12V battery
power supply.
Specifications
Type
LIN
Applications
It can be used for small and portable LIN based networks, that are commonly
used in automotive applications, but also for any application where robust and
interference-free communication up to 20Kbps is needed.
On-board modules
ATA663254 integrated LIN bus transceiver with the 5V voltage regulator from
Microchip
Key Features
Complete integrated LIN solution, with a 5V LDO that can be used for powering
up other LIN nodes in the network, as well as the MCU. The onboard
connector provides a secure and easy connection to the LIN network.
Interface
GPIO,UART
Input Voltage
5V
Click board size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on ATA663254 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
NC
1
AN
PWM
16
NC
Reset
RST
2
RST
INT
15
NC
Enable
EN
3
CS
RX
14
TX
Transmit
NC
4
SCK
TX
13
RX
Receive
NC
5
MISO
SCL
12
NC
NC
6
MOSI
SDA
11
NC
NC
7
3.3V
5V
10
5V
Power Supply
GND
8
GND
GND
9
GND
Ground
Ground
ATA663254 click electrical specifications
Description
LIN operating voltage range
Min
Typ
Max
Unit
5
13.5
28
V
Integrated LDO output current
Integrated LDO output voltage
85
4.9
Additional pins
Name
I/O
Description
+5V
O
+5V Supply Output
GND
Power Ground
RXD
I/O
External UART RX Pad
TXD
I/O
External UART TX Pad
mA
5.1
V
Onboard settings and indicators
Label Name
LD1
PWR
Default
JMPR1 JMP 5V Unpopulated
Description
Power LED indicator
Connects +5V output to mikroBUS™
socket
JMPR2 L-PULL Unpopulated External LIN pull up resistor
Note: The JMP 5V SMD jumper should not be populated if used with MikroElektronika development
systems. It is reserved for powering up the custom-made systems via the 5V connector
Software support
We provide a library for ATA663254 click on our LibStock page, as well as a demo application
(example), developed using MikroElektronika compilers and mikroSDK. The provided click
library is mikroSDK standard compliant. The demo application can run on all the main
MikroElektronika development boards.
Library Description
Defines and initializes driver's UART bus. Declares and defines driver's functions for sending
and receiving data bytes,
also for checking if the data byte is ready for reading.
void ata663254_enable(uint8_t state);- Function enables and disables click
void ata663254_writeByte(uint8_t input);- Function writes (sends) one byte in the RX
buffer
uint8_t ata663254_readByte();- Function reads (receives) one byte from the RX buffer
uint8_t ata663254_ready();- Function checks if new data placed in the RX buffer
uint8_t ata663254_getRstState();- Function checks RST pin if undervoltage detection
happens
Examples Description
System Initialization - Initializes peripherals and pins
Application Initialization - Initializes click driver
The receiver part of the task logs each received byte to the UART bus, used for data logging.
Transmitter part of the task sends a message every two seconds.
void applicationTask()
// RECEIVER
#ifdef __RX__
if(ata663254_ready())
tmp = ata663254_readByte();
mikrobus_logWrite(&tmp, _LOG_BYTE);
#endif
// TRANSMITER
#ifdef __TX__
uint8_t cnt;
for (cnt = 0; cnt < 9; cnt++)
ata663254_writeByte(MESSAGE_DATA[cnt]);
Delay_ms(2000);
#endif
The full application code and ready to use projects can be found on our LibStock page.
Additional notes and information
Depending on the development board you are using, you may need USB UART click, USB UART 2 click or
RS232 click to connect to your PC, for development systems with no UART to USB interface available on
the board. The terminal available in all MikroElektronika compilers, or any other terminal application of
your choice, can be used to read the message.
mikroSDK
This click board is supported with mikroSDK - MikroElektronika Software Development Kit. To
ensure proper operation of mikroSDK compliant click board demo applications, mikroSDK
should be downloaded from the LibStock and installed for the compiler you are using.
For more information about mikroSDK, visit the official page.
Downloads
mikroBUS™ Standard specification
LibStock: mikroSDK
ATA663254 click schematic
ATA663254 datasheet
LibStock: ATA663254 click library
ATA663254 click - 2D and 3D files
https://www.mikroe.com/ata663254-click 1-15-18
很抱歉,暂时无法提供与“MIKROE-2872”相匹配的价格&库存,您可以联系我们找货
