GeoMagnetic click
PID: MIKROE-2935
Weight: 23 g
Three-axis geomagnetic sensor
GeoMagnetic click is a digital magnetometric click board which can measure the
geomagnetic field in three perpendicular axes. The onboard sensor uses FlipCore - a
proprietary technology from Bosch, which results with a carefully tuned performance,
tailored for demanding 3-axis mobile applications, such as a tilt-compensated electronic
compass, gaming controllers, augmented reality applications and similar applications
which require reliable and precise 3-axis magnetometric measurement.
Besides the magnetic field measurement functions, GeoMagnetic click also provides an
advanced programmable interrupt engine, which allows for a flexible design and
responsiveness of the application. GeoMagnetic click can use either SPI or I2C interface to
communicate with the host controller. All these features make GeoMagnetic click an easy to
use and reliable solution for a rapid development of geomagnetic based applications.
How does it work?
GeoMagnetic click carries the BMM150, a three-axis geomagnetic sensor from Bosh
Sensortec. Featuring the proprietary FlipCore technology from Bosch, low power
consumption, and noise, as well as thermally compensated measurements, this device is
specially tuned and tailored to be used in demanding 3-axis mobile applications.
The BMM150 module is able to work in four power modes: Power Off mode, Suspend
mode, Sleep mode and Active mode. The overall power consumption is greatly affected by
the selection of power modes. All modes except the Power Off mode can be set by
programming the appropriate registers. Additionally, while working in Active mode, the
power consumption depends on the measurement rate, which can be either timed with the
programmed output data rate (Normal mode) or forced by the user (Forced mode).
The sensor output noise is processed by the internal integrator, so setting more
measurement repetitions for the same axis will yield output results with less noise. This
also affects the overall power consumption in the Active mode.
There are four interrupt engines available on this device: low threshold, high threshold and
overflow and data ready (DRDY). Every interrupt engine can be enabled independently. If
the interrupt is enabled, it will set the corresponding status bit in the status register. For
this interrupt to appear on the INT pin of the BMM150 IC, a corresponding bit should be set
in the configuration register. This pin is routed to the mikroBUS™ INT pin and can be used
for triggering external events. Data ready pin is not physically available on the click
board™, but still, its status bit can be read from the status register.
The temperature compensation is based on a hall plate sensor measurement. This IC
outputs raw values for the measurements: DATAX, DATAY, DATAZ, and RHALL. The data
width for the X and Y axes is different than the one for the Z and RHALL. DATAX and DATAY
data fields are 13 bits wide, while DATAZ field is 15 bits wide. RHALL data field is 14 bits
wide. The manufacturer recommendation is to read all the axes at once. The output
registers are refreshed all at once after all the measurements are finished. While reading
registers, a new measurement is not stored in the same registers, but buffered to shadow
registers, instead. This prevents axes data mixing, so it is also recommended to read the
whole register sequence in one burst. To further control the data reading sequence, two
additional bits are used to indicate the data ready status and data overrun status.
GeoMagnetic click can use either SPI or I2C communication interface. The selection
between the interfaces can be done by switching the SMD jumper positions. There are two
group of SMD jumpers. The first group is labeled as COM SEL and it is used to select the
required interface type. It should be noted that all the jumpers need to be switched either
left for SPI interface type or right for I2C interface type. Mixed positions are not allowed.
The second group of SMD jumpers is labeled as ADD SEL and it is used to set the two least
significant bits (LSB) of the I2C address. These jumpers are disregarded if the SPI interface
is selected. More information about the registers and their settings can be found in the
datasheet link, below.
The provided GeoMagnetic click library offers simple and easy to use functions, which are
demonstrated in the demo application. These functions allow easy and simple
configuration management and data reading, speeding up the development process.
Specifications
Type
Magnetometer
On-board modules
BMM150 geomagnetic sensor from Bosch
Interface
GPIO,I2C,SPI
Input Voltage
3.3V
Click board size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on GeoMagnetic click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
NC
1
AN
PWM
16
NC
NC
2
RST
INT
15
INT
CS
3
CS
RX
14
NC
SPI Clock
SCK
4
SCK
TX
13
NC
SPI Data Out
SDO
5
MISO
SCL
12
SCL
I2C Clock
SPI Data In
SDI
6
MOSI
SDA
11
SDA
I2C Data
+3.3V
7
3.3V
5V
10
NC
GND
8
GND
GND
9
GND
SPI Chip Select
Power supply
Ground
Interrupt
Ground
GeoMagnetic click specifications
Description
Min
Typ
Max
Unit
I2C Clock
400
kHz
SPI Clock (SDI, SDO load < 25pF)
10
MHz
Onboard settings and indicators
Label
JP1 JP5
JP6 JP7
LD1
Name
Default
COM SEL
LEFT
ADD SEL
LEFT
PWR
Description
Communication protocol selection: Left position SPI, right position - I2C
I2C Address selection: Left position - 0, right
position - 1
Power LED indicator
Software support
We provide a library for GeoMagnetic click on our Libstock page, as well as a demo
application (example), developed using MikroElektronika compilers and mikroSDK. The
provided click library is mikroSDK standard compliant. The demo application can run on all
the main MikroElektronika development boards.
Library Description
Initializes and defines the SPI and I2C bus driver and driver functions, which has the ability
of writing on registers and reading from registers. The functions also offer a choice to
reading x, y and z axis data and hall resistance data when data is ready for reading. For
more details check the documentation.
Key functions:
GEOMAG_RETVAL_T geomag_writeReg( uint8_t dataIn, const uint8_t
registerAddress ) - The function writes one byte data in the register.
GEOMAG_RETVAL_T geomag_readReg( uint8_t *dataOut, const uint8_t
registerAddress, const uint8_t nBytes ) - The function reads the determined number
of bytes from registers.
void geomag_readData( uint16_t *dataX, uint16_t *dataY, uint16_t *dataZ,
uint16_t *resHall ) - The function reads 13-bit x and y axis data, 15-bit z axis data and
14-bit hall resistance data from data registers.
Examples Description
The application is composed of three sections:
System Initialization - Initializes peripherals and pins.
Application Initialization - Initializes SPI driver, performs power-on reset and configures the device
so that all channels (x, y and z) is enabled and Data Ready bit is active on high (Data Ready bit must
be configured that is active on high).
Application Task - (code snippet) - Reads axis data after each 500ms and logs results on
USB UART.
void applicationTask()
geomag_readData( &axisX, &axisY, &axisZ,
WordToStr( axisX, text );
mikrobus_logWrite( "X axis: ", _LOG_TEXT
mikrobus_logWrite( text, _LOG_LINE );
WordToStr( axisY, text );
mikrobus_logWrite( "Y axis: ", _LOG_TEXT
WordToStr( axisZ, text );
mikrobus_logWrite( "Z axis: ", _LOG_TEXT
mikrobus_logWrite( "", _LOG_LINE );
Delay_ms( 500 );
&RHall );
The full application code, and ready to use projects can be found on our LibStock page.
Other mikroE Libraries used in the example:
Conversions
SPI
UART
Additional notes and information
Depending on the development board you are using, you may need USB UART click, USB
UART 2 click or RS232 click to connect to your PC, for development systems with no UART
to USB interface available on the board. The terminal available in all
MikroElektronika compilers, or any other terminal application of your choice, can be used
to read the message.
mikroSDK
This click board is supported with mikroSDK - MikroElektronika Software Development
Kit. To ensure proper operation of mikroSDK compliant click board demo applications,
mikroSDK should be downloaded from the LibStock and installed for the compiler you are
using.
For more information about mikroSDK, visit the official page.
Downloads
mikroBUS™ Standard specification
LibStock: mikroSDK
BMM150 datasheet
Libstock: GeoMagnetic click library
GeoMagnetic click schematic
GeoMagnetic click: 2D and 3D files
https://www.mikroe.com/geomagnetic-click 3-9-18
