MIKROE-2938
MIKROE-2938
    MIKRO
    HDC1010 湿度,温度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2938 数据手册
Temp-Hum 4 click PID: MIKROE-2938 Weight: 23 g Smart environmental temperature and humidity sensor Temp-Hum 4 click is a smart environmental temperature and humidity sensor Click board™, packed with features which allow easy and simple integration into any design that requires accurate and reliable humidity and temperature measurements. The sensor IC itself has integrated sensing elements placed on the bottom of the die, so they are not directly exposed to the environmental contamination, which translates to a prolonged life of the Click board™. Temp-Hum 4 click is a perfect solution for a wide range of applications that depend on accurate temperature and humidity readings. With its low power consumption and programmable interrupt requests capability, it is also a perfect choice for various temperature and relative humidity based IoT applications, such as smart home applications, smart thermostats, gas sensing, smoke and heat sensors, and similar. How does it work? The sensor IC used on the Temp-Hum 4 click is the HDC1010, a Low Power Humidity and Temperature Digital Sensor from Texas Instruments. This sensor is factory calibrated to 2% relative humidity and 0.2°C temperature accuracy. It has an integrated heating element that is used to evaporate condensation, protecting the sensor that way. The heating element can be simply activated by setting a bit in the appropriate register. In the case when the heater is powered on, the power consumption might rise to about 130mA. Internally, two sensors are connected to the ADC section, which can be set to sample the measurement with the resolution of 9, 11 or 14 bits, based on the measurement time. OTP memory holds the calibration coefficients that are applied to the measured value and the results are stored on the output registers, in the MSB/LSB format. These values are then used in formulas found in the HDC1010 datasheet so that the final temperature or relative humidity data can be calculated. HDC1010 IC uses the I2C protocol to communicate with the host MCU. Its I2C bus pins are routed to the mikroBUS™ I2C pins and are pulled to a HIGH logic level by the onboard resistors. Two ADDR pins of the HDC1010 are routed to the CS and the RST pin of the mikroBUS™ and they represent the least significant bits of the I2C address. The final I2C address of this IC is determined by setting these pins either to HIGH logic level for 1, or a LOW logic level for 0. Temp-Hum 4 click supports programmable interrupt engine, saving the host MCU from having to constantly poll the IC for data. An interrupt signal with a selectable polarity and behavior can be generated on the DRDY/INT pin of the HDC1010. It can be triggered by several event sources: it can be triggered by the temperature Lo/Hi threshold events, Humidity Lo/Hi events, as well as the readiness of the measurement data. Setting up the interrupts can be achieved by programming the appropriate IC registers via the I2C bus. More information about these registers can be found in the HDC1010 datasheet. HDC1010 IC is a very low power consuming device and it can work in two modes: sleep and active (measurement) mode. The device enters the sleep the mode as soon possible, to save power. While in active mode, measurement can be either automatic with predefined output data rate (ODR) or on-demand. In the automatic mode, the measurement is triggered in predefined time segments - continuously, while on-demand measurement happens whenever the I2C command is sent. As soon as the single measurement is finished, the device falls back to sleep mode. Onboard SMD jumper is used to select the power supply voltage. This allows Temp-Hum 4 click to be used with both 3.3V and 5V MCUs. The provided click board™ library contains simple and easy to use functions, which simplify configuring and reading of the measurement data. These functions are demonstrated in the included example application and can be used as a reference for custom projects. These functions can be used in mikroC, mikroBASIC and mikroPASCAL compilers for all MCU architectures supported by MikroElektronika. Specifications Type Applications On-board modules Temperature / Humidity Environmental monitoring, home automation, weather stations, HVAC systems, etc. HDC1010 Low Power Humidity and Temperature Digital Sensor The click board measures the relative humidity range from 0% to Key Features 100% with acc. of ±2%, temp acc ±0.2 °C, and it features an integrated heating element, used to evaporate condensation, smart sensor IC design, and low power consumption. Interface I2C Input Voltage 3.3V or 5V Click board size S (28.6 x 25.4 mm) Pinout diagram This table shows how the pinout on Temp-Hum 4 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin Notes NC 1 AN PWM 16 NC I2C Address LSB 0 AD0 2 RST INT 15 INT I2C Address LSB 1 AD1 3 CS RX 14 NC NC 4 SCK TX 13 NC NC 5 MISO SCL 12 SCL I2C Clock NC 6 MOSI SDA 11 SDA I2C Data Power Supply +3V3 7 3.3V 5V 10 +5V Power Supply Ground GND 8 GND GND 9 GND Ground Interrupt output Temp-Hum 4 click maximum ratings Description Min Typ Max Unit Temperature Accuracy -0.2 - 0.2 °C -2 - 2 % RH Humidity Accuracy Operating temperature -40 - 85 °C Relative Humidity Operating Range 0 - 100 % RH I2C clock frequency 10 - 400 kHz Onboard settings and indicators Label Name Default JP1 - Left LD1 PWR Description Power Supply Voltage Selection: Left position 3V3, right position 5V PWR indication LED Software support We provide a library for Temp-Hum 4 click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers and mikroSDK. The provided click library is mikroSDK standard compliant. The demo application can run on all the main MikroElektronika development boards. Library Description The library covers all functionalities of the click board. Key functions: float temphum4_getTemperature() - Read temperature form sensor float temphum4_getHuminidy() - Read humidity from sensor void temphum4_Configuration(uint16_t _data) - Configure sensor Examples Description The application is composed of three sections: • System Initialization - Initializes I2C module and CS pin, RST pin as OUTPUT and INT pin as INPUT. • Application Initialization - Initializes Driver init and settings chip mode ACTIVE and configuration measurement. • Application Task - (code snippet) - Reads the temperature and humidity and logs to the USBUART every 500 ms. void applicationTask() { Temperature = temphum4_getTemperature(); Huminidy = temphum4_getHuminidy(); FloatToStr(Temperature,temp_txt); mikrobus_logWrite("Temperature : ",_LOG_TEXT); mikrobus_logWrite(temp_txt,_LOG_LINE); FloatToStr(Huminidy,hum_txt); mikrobus_logWrite("Huminidy : ",_LOG_TEXT); mikrobus_logWrite(hum_txt,_LOG_LINE); Delay_ms( 500 ); } The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example: • I2C • UART • Conversions Additional notes and information Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message. mikroSDK This click board is supported with mikroSDK - MikroElektronika Software Development Kit. To ensure proper operation of mikroSDK compliant click board demo applications, mikroSDK should be downloaded from the LibStock and installed for the compiler you are using. For more information about mikroSDK, visit the official page. Downloads mikroBUS™ Standard specification LibStock: mikroSDK Libstock: Temp-Hum 4 click library Temp-Hum 4 click: 2D and 3D files HDC1010 datasheet Temp-Hum 4 click schematic https://www.mikroe.com/temp-hum-4-click 3-14-18
MIKROE-2938 价格&库存
很抱歉,暂时无法提供与“MIKROE-2938”相匹配的价格&库存,您可以联系我们找货
MIKROE-2938
    • 1+125.65336
    • 5+123.14363
    库存:9
    MIKROE-2938
    • 1+141.230341+18.32912
