MIKROE-3442
MIKROE-3442
    MIKRO
    CAT34TS02 温度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3442 数据手册
    TEMP-LOG 5 CLICK PID: MIKROE-3442 Weight: 23 g Temp-Log 5 click is a temperature measuring Click board™ featuring the CAT34TS02, an accurate temperature sensor IC with integrated Serial Presence Detect EEPROM. Temperature Sensor measures and store temperatures at least 10 times in second. Temperature measurement results can be retrieved by the host MCU via I2C interface, and are compared to critical limits stored into internal registers. It also features programmable event output function and supports three modes. Temp-log 5 click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. HOW DOES IT WORK? The sensor IC used on the Temp-Log 5 click is CAT34TS02 from ON semiconductor that combines a JC42.4 compliant Temperature Sensor (TS) with 2 Kb of Serial Presence Detect (SPD) EEPROM. Temperature sensor measures and stores temperatures at least 10 times in second, allowing it to be retrieved by the host MCU via the I2C interface. The result can be compared to critical limits, stored into internal registers. This allows the sensor to reduce the processing workload of the host MCU by employing the trigger limits mechanism: by asserting the EVENT line to a LOW logic level, the CAT34TS02 is able to wake up the host MCU, reducing the power consumption. The EVENT pin is routed to the INT pin of the mikroBUS™. The CAT34TS02 IC can be configured to trigger an EVENT in three different modes: Interrupt mode, Comparator mode, and Critical Temperature mode. When set in the Interrupt Mode, the EVENT output will be asserted every time the temperature crosses one of the alarm limits. Once the temperature exceeds the critical limit, the EVENT remains asserted as long as the temperature stays above the critical limit. The EVENT can be cleared by setting a bit in a corresponding register (must be cleared by the software). However the pin will remain asserted as long as the temperature exceeds the critical limits. In the Comparator mode, the EVENT pin is asserted whenever the temperature is outside the predefined limit values, and deasserted as soon as the temperature drops under the limit (no need to clear the bit by the software). If set in the Critical Temperature Mode, the EVENT pin will be asserted only if the temperature exceeds a critical threshold limit. The limit values can be programmed via the corresponding registers. CAT34TS02 IC uses the I2C/SMBus protocols to communicate with the host MCU. Its I2C bus pins are routed to the mikroBUS™ I2C pins and are pulled to a HIGH logic level by the onboard resistors. The I2C slave address of the CAT34TS02 IC can be selected by ADDR pins A0, A1 and A2: LOW logic level clears the corresponding address bit (GND), while HIGH logic level sets the bit (VCC). This can be done using a group of onboard jumpers, positioned under the label ADDR SEL. The provided click board™ library contains simple and easy to use functions, which simplify configuring and reading of the measurement data. These functions are demonstrated in the included example application and can be used as a reference for custom projects. These functions can be used in mikroC, mikroBasic and mikroPascal compilers for all MCU architectures, supported by MikroElektronika. SPECIFICATIONS Type Temperature Applications Temp-Log 5 is a great solution for the development of various embedded applications based on temperature measurement and data logging. On-board modules CAT34TS02, a digital output temperature sensor with SPD EEPROM, by ON semiconductor Key Features A very high measurement accuracy and repeatability, programmable thresholds and hysteresis, a dedicated EVENT pin with a programmable function, selectable resolution, 256 bytes of integrated EEPROM, and more Interface I2C Input Voltage 3.3V Click board size M (42.9 x 25.4 mm) PINOUT DIAGRAM This table shows how the pinout on Temp‐Log 5 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin NC Pin 1 AN PWM 16 NC Notes NC 2 RST INT 15 INT NC 3 CS RX 14 NC NC 4 SCK TX 13 NC NC 5 MISO SCL 12 SCL I2C Clock NC 6 MOSI SDA 11 SDA I2C Data Power Supply 3.3V 7 3.3V 5V 10 NC Ground GND 8 GND GND 9 GND Interrupt output Ground TEMP-LOG 5 CLICK ELECTRICAL SPECIFICATIONS Description Min Typ Temperature Accuracy - +/-0.2 +/-0.4 °C Temperature resolution - - 0.0625 °C Operating temperature -45 - 130 °C Active range - - ±1.0 °C Monitor range - - ±2.0 °C Sensing range - - ±3.0 °C 10 - 400 kHz I2C clock frequency Max Unit ONBOARD SETTINGS AND INDICATORS Label Name Default LD1 PWR - Description PWR indication LED SOFTWARE SUPPORT We provide a library for the Temp‐Log 5 click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description The library initializes and defines the I2C bus driver and drivers that offer a choice for writing data in TS register and read data form TS register. The library contains function for reading Temperature data, functions for writing and reading EEPROM, functions for reading Interrupt status and temperature status. The library provides full control of all the registers that the modules contain. Key functions:    float templog5_getTemperature() - Temperature Data void templog5_writeEEPROM(uint8_t start_addr, uint8_t *dataIn, uint8_t nByte)- Write EEPROM void templog5_readEEPROM(uint8_t start_addr, uint8_t *dataOut, uint8_t nByte)- Read EEPROM Examples description The application is composed of the three sections :  System Initialization - Initialization I2C module and set INT pin as INPUT.  Application Initialization - Initializes driver init, Test comunication, EEPROM write/read test and configuration device for measurement.  Application Task - Reads Temperature data and logs data to the USBUART every 1 sec. void applicationTask()  {      float Temperature;        Temperature = templog5_getTemperature();      FloatToStr(Temperature, demoText);      mikrobus_logWrite("‐‐‐ Temperature: ", _LOG_TEXT);      mikrobus_logWrite(demoText, _LOG_LINE);            mikrobus_logWrite("‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐", _LOG_LINE);      Delay_1sec();  }    The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example:    I2C UART Conversions Additional notes and informations Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message. MIKROSDK This click board is supported with mikroSDK - MikroElektronika Software Development Kit. To ensure proper operation of mikroSDK compliant click board demo applications, mikroSDK should be downloaded from the LibStock and installed for the compiler you are using. For more information about mikroSDK, visit the official page.        https://www.mikroe.com/hall‐current‐6‐click//4‐9‐19
MIKROE-3442 价格&库存
很抱歉,暂时无法提供与“MIKROE-3442”相匹配的价格&库存,您可以联系我们找货
MIKROE-3442
  • 1+123.189631+15.98376
库存:1
