AUDIOAMP 6 CLICK
PID: MIKROE-3448 Weight: 23 g
Audio Amp 6 click is a mono/subwoofer audio amplifier, capable of delivering up to
18.5W per channel with the 4Ω load. It is based on the TPA3138D2, a class-D
integrated amplifier, which utilizes a highly efficient switching scheme. With about 20mA
in idle mode, it allows for longer operation and improved thermal performance, making it
a perfect choice for various battery-powered applications. Advanced EMI Suppression
with Spread Spectrum Control allows using ferrite bead filters instead of bulky inductors,
still maintaining the required EMC levels. The TPA3138D2 IC is equipped with a set of
protection features, allowing a reliable operation.
Audio Amp 6 click is supported by a mikroSDK compliant library, which includes
functions that simplify software development. This Click board™ comes as a fully tested
product, ready to be used on a system equipped with the mikroBUS™ socket.
This Click board™ is configured to drive a single speaker, using its outputs tied in
parallel. It requires an external Power Supply Unit (PSU) for its operation. It can use a
wide range of power supply voltages, from 3.5V up to 14.4V. Audio Amp 6 click is
designed to be used along with the Audio Amp 5 click, for building home theater 2.1, 4.1,
5.1 or 7.1 systems. It is a perfect solution for the development of battery-powered
Bluetooth® and wireless speakers, TV sets and PC monitors, and other types of
consumer audio equipment applications. Due to its high efficiency, it can even be used
as a sound reinforcement solution for various IoT applications.
HOW DOES IT WORK?
The main component of Audio Amp 6 click is the TPA3138D2, a stereo class-D audio
amplifier, from Texas Instruments. It has many features which make this IC a very
attractive solution for battery-powered and stand-alone active speakers. It is very
flexible regarding the PSU voltage: it can work with voltages within the range from 3.5V
to 14.4V. With only 3.5V at the PSU connector, it can still deliver 1W of power to the 6Ω
load (per channel). However, its nominal operating voltage is 12V, reaching up to 18.5W
of power to the single connected 4Ω speaker, with 10% of Total Harmonic Distortion
(THD).
The TPA3138D2 IC features a set of protections, including output short circuit, overtemperature, under-voltage, and over-voltage protection. If any of these protections are
activated, they will be reported at the SD/FAULT (EN) I/O pin. The TPA3138D2 IC can
also detect a constant DC current at the output. When a DC detection event occurs, the
outputs are turned OFF, protecting the connected speakers that way. Very often, a DC
detection event can be triggered when the circuit is powered up, so it is advisable to
hold the EN pin to a LOW logic level for a short period, preventing faulty DC detection
reports, as well as loud pops.
The output stage of the TPA3138D2 operates in Bridge-Tied Load (BTL) topology. This
means that there are two outputs per channel: one inverted and one non-inverted
(OUTN and OUTP). In the case of the Audio Amp 6 click, both of these differential
outputs are tied in a bridge topology (PBTL), yielding even more power on a single
speaker, at the cost of somewhat higher THD, which is still acceptable tradeoff in
subwoofer/central speaker applications. The amplifier does not process the input in any
way, therefore it should be connected to a pre-processed sound output from the active
crossover or a dedicated SW/Center output from the audio playback device.
The class-d amplifier produces the sound by modulating the pulse-with of the output
voltage. It offers a choice of two PWM modulation schemes, selectable by the
MODE_SEL pin of the IC. This pin is routed to the mikroBUS™ RST pin, labeled as
MDS on this Click board™. By default, MDS pin is pulled to a HIGH logic level by a
resistor.
When the MDS pin is set to a LOW logic level, the TPA3138D2 uses the BD Modulation
scheme. This modulation scheme is less power-efficient, but it yields better THD ratio.
When set to a HIGH logic level, TPA3138D2 will operate using the 1SPW Modulation
scheme, which is set for this Click board™ by default (pull-up resistor). This modulation
scheme allows for very low idle current and better overall efficiency, at the expense of
somewhat increased THD.
The SD/FAULT pin allows the host MCU to enable/disable outputs. By pulling this pin to
a LOW logic level, the outputs are muted and the TPA3138D2 IC enters the low-current
state, reducing the supply current to the absolute minimum level. Muting the
TPA3138D2 before cutting down the power supply reduces pops and clicks that might
appear in this case. The SD/FAULT pin is routed to the mikroBUS™ CS pin labeled as
EN on this Click board™, and it is pulled to a HIGH logic level by a resistor.
There is a selectable input gain on Audio Amp 5 click. By applying a LOW logic level to
the GAIN_SEL pin, the input gain is set to 20dB. A HIGH logic level sets the input gain
to 26dB. This allows matching the input signal so that the optimal output level can be
reached. This pin is routed to the mikroBUS™ PWM pin labeled as GS, and it is pulled
to the LOW logic level by a resistor.
The external PSU should be connected to the VIN terminal. A line-level audio source
can be connected to the LINE IN 3.5mm jack stereo connector, while the speaker
should be connected to the OUT terminal. These terminals have their polarities marked
on the top overlay.
Although the TPA3138D2 IC requires an external PSU, it still uses power from the
mikroBUS™ for the logic levels of its control pins. There is a logic voltage level selection
SMD jumper labeled as VCC SEL, which allows interfacing with both 3.3V and 5Vtolerant pins of the host MCU.
SPECIFICATIONS
Type
Amplifier
Applications
This Click board™ is designed to be used along with the Audio Amp
5 click, for building home theater 2.1, 4.1, 5.1 or 7.1 systems. It is a
perfect solution for the development of battery-powered Bluetooth®
On-board
modules
TPA3138D2, a stereo class-D audio amplifier, from Texas
Instruments.
Key Features
High efficiency, low power dissipation with no extra heat-sinks
required, a set of protection features for reliable operation, it can be
operated with the wide range of voltages, etc.
Interface
GPIO
Input Voltage
3.3V or 5V
Click board
size
L (57.15 x 25.4 mm)
PINOUT DIAGRAM
This table shows how the pinout on AudioAmp 6 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Mode Selection
Pin
Pin
NC
1
AN
PWM
16
GS
MDS
2
RST
INT
15
NC
Notes
Gain Select
EN
3
CS
RX
14
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
NC
NC
6
MOSI
SDA
11
NC
Power Supply
3V3
7
3.3V
5V
10
5V
Ground
GND
8
GND
GND
9
GND
Chip Enable/Fault
Power Supply
Ground
AUDIOAMP 6 CLICK ELECTRICAL SPECIFICATIONS
Description
Min
Typ
Max
Unit
External PSU Voltage
3.5
14.4
V
Minimum load Impedance
3.2
Ω
Continuous output power
18.5
W
Total Harmonic Distortion (THD) at 18.5W; 4Ω; 12V
10
Signal-to-Noise Ratio (SNR)
102
dB
ONBOARD SETTINGS AND INDICATORS
Label
Name
Default
PWR
PWR
Description
Power LED indicator
Logic voltage level selection: left position 3.3V, right
position 5V
JP1
VCC SEL
Left
CN1
LINE IN
3.5mm stereo jack for audio input
OUT
OUT
Left speaker connector
VIN
VIN
External PSU connector
SOFTWARE SUPPORT
We provide a library for the AudioAmp 6 click on our LibStock page, as well as a demo
application (example), developed using MikroElektronika compilers. The demo can run
on all the main MikroElektronika development boards.
Library Description
Library contains all the necessary functions for control to the AudioAmp 6 click.
Key functions:
void audioamp6_setMode(uint8_t mode) - Sets MODE BD or 1SPW.
void audioamp6_setOutput(uint8_t out) - Enable or Disable output.
void audioamp6_setGain(uint8_t gain) - Sets Gain 20dB or 26dB.
Examples description
The application is composed of the three sections :
System Initialization - Sets the necessary gpio pins to control the click.
Application Initialization - Initializes the driver init and sets initial settings for the chip.
Application Task - Waits for valid user input and executes functions based on set of valid
commands.
Note: Sets the input voltage from 3.5V to 14.4V. Use the UART to control the amplification
or reduction of sound.
Commands : 'e' - Enable/disable output 'g' - Changes the gain settings (20dB - 26dB)
void applicationTask()
uint8_t dataReady_;
char receivedData_;
dataReady_ = UART_Rdy_Ptr();
if (dataReady_ != 0)
receivedData_ = UART_Rd_Ptr();
switch (receivedData_)
case 'e' :
/* Device enable or disable */
if(fEnable == _AUDIOAMP6_OUTPUT_ENABLE)
audioamp6_setOutput(_AUDIOAMP6_OUTPUT_DISABLE);
mikrobus_logWrite("‐‐‐‐ OUTPUT DISABLED ‐‐‐‐", _LOG_LINE);
fEnable = _AUDIOAMP6_OUTPUT_DISABLE;
else
audioamp6_setOutput(_AUDIOAMP6_OUTPUT_ENABLE);
mikrobus_logWrite("‐‐‐‐ OUTPUT ENABLED ‐‐‐‐", _LOG_LINE);
fEnable = _AUDIOAMP6_OUTPUT_ENABLE;
break;
case 'g' :
/* Gain 20dB or 26dB*/
if(fGain == _AUDIOAMP6_GAIN_26dB)
audioamp6_setGain(_AUDIOAMP6_GAIN_20dB);
mikrobus_logWrite("‐‐‐‐ Gain [20 dB] ‐‐‐‐", _LOG_LINE);
fGain = _AUDIOAMP6_GAIN_20dB;
else
audioamp6_setGain(_AUDIOAMP6_GAIN_26dB);
mikrobus_logWrite("‐‐‐‐ Gain [26 dB] ‐‐‐‐", _LOG_LINE);
fGain = _AUDIOAMP6_GAIN_26dB;
break;
The full application code, and ready to use projects can be found on our LibStock page.
Other mikroE Libraries used in the example:
GPIO
UART
Additional notes and informations
Depending on the development board you are using, you may need USB UART
click, USB UART 2 click or RS232 click to connect to your PC, for development systems
with no UART to USB interface available on the board. The terminal available in all
MikroElektronika compilers, or any other terminal application of your choice, can be
used to read the message.
MIKROSDK
This click board is supported with mikroSDK - MikroElektronika Software Development
Kit. To ensure proper operation of mikroSDK compliant click board demo applications,
mikroSDK should be downloaded from the LibStock and installed for the compiler you
are using.
For more information about mikroSDK, visit the official page.
https://www.mikroe.com/audioamp‐6‐click/4‐23‐19
