MIKROE-3466
MIKROE-3466
    MIKRO
    PRESSURE 12 CLICK
MIKROE-3466 数据手册
        PRESSURE 12 CLICK PID: MIKROE-3466 Weight: 19 g Pressure 12 click is a barometric gauge pressure measuring Click board™, equipped with the  Amplified Basic Pressure sensor series (ABP), which features a ratiometric analog output, which  is proportional to the applied pressure. It features a very low Total Error Band of 1.5% of FS, a  specification used to describe all the measurement errors and deviations within the sensor  itself. The ABP series sensor uses a calibrated and thermally compensated ASIC, providing a  ratiometric output updated at a frequency of 1kHz. It can be directly used by the A/D  conversion section of the host MCU, but it can also be directly used in a control feedback loop,  for low latency operations.    Pressure 12 click is supported by a mikroSDK compliant library, which includes functions that  simplify software development. This Click board™ comes as a fully tested product, ready to be  used on a system equipped with the mikroBUS™ socket.  Besides a very low error margin of only 1.5% across the full scale span (including errors caused  by the offset, hysteresis, non‐linearity, and other factors…), the sensor also features long‐term  stability (±0.25% FSS), low power consumption, very low count of additional components (a  single bypass capacitor for supply filtering, in most cases), making it very cheap and simple  solution which can be used to measure the gauge pressure in the range from 0 to 600 mbar.  Pressure 12 click is a very well suited for the development and prototyping of many different  applications based on the gauge pressure measurement, including HVAC systems, pneumatic  control, and regulation, air/gas pressure monitoring, but also some low‐power IoT applications,  such as weather IoT nodes, and similar.  HOW DOES IT WORK? Pressure 12 click is based on the ABP series gauge pressure sensor, labeled as ABPLLNN600MGAA3, made by Honeywell. The entire ABP series sensors are very similar in design, so minor differences specific for a particular sensor are actually encoded into its label. The ABP series datasheet offers a detailed explanation of each code of the label. The specific sensor used on the Pressure 12 click is a piezoresistive silicon pressure sensor, which can be used for non-corrosive and non-ionic dry gas media and should not be exposed to moisture and corrosion. The sensor itself is based on a piezoresistive silicon membrane sensitive to pressure, which is backed up by an ASIC. The ASIC applies temperature compensation and calibration to the signal. The ratiometric voltage at the output pin is updated once per one ms (1kHz), allowing it to be used either by the A/D converter of the host MCU or directly within the control feedback loop, ensuring the least possible latency. The thermal compensation covers the range between 0⁰C and 50 ⁰C, where the sensor has the smallest TEB value. The datasheet introduces TEB (Total Error Band) term as the most realistic representation of the sensor's accuracy, taking many factors into an account, including errors caused by the offset, hysteresis, non-linearity, and other factors… Honeywell uses the TEB to illustrate the overall sensor's accuracy, since no single parameter can exist without being influenced by some other parameters (thermal effect on the offset, hysteresis, just to name few). This helps to paint a more realistic picture of the sensor's performance. The sensor contains a single axial barbless port, adequate for secure interfacing with various pipes, hoses or gas-filled containers of some pressurized system which needs to be controlled or monitored. No barbed port is required for this sensor, as the maximum gauge pressure, it can measure goes up to 600mbar. The voltage at the output changes proportionally with the applied pressure. The ABP series datasheet provides a simple conversion formula, which can be used to calculate the pressure value for a given output voltage. This formula is simple to be calculated by the firmware that runs on the host MCU, as the output voltage is already conditioned by the sensor's ASIC. Since the sensor uses only an analog output voltage, which changes proportionally with the applied pressure (as described previously), there are no setup registers, or any user-configurable parameters. However, the Click board™ is supported by a mikroSDK compatible library with functions that allow using an internal ADC module of the MCU, and an example that demonstrates their use. The demo example utilizes the aforementioned conversion formula to output pressure value based on the sensor's output voltage. SPECIFICATIONS Type Pressure / Altitude Applications Perfect for the development and prototyping of many different applications based on the gauge pressure measurement, including HVAC systems, pneumatic control, and regulation, air/gas pressure monitoring, but also some low-power IoT applications, such as weather IoT nodes, and similar On-board modules ABPLLNN600MGAA3, by Honeywell Key Features Low error margin of 1.5% across the full-scale span (including errors caused by the offset, hysteresis, non-linearity, and other factors…), excellent long-term stability, low power consumption, low count of additional components required, can be used in the range from 0 to 600 mbar Interface Analog Input Voltage 3.3V Click board size M (42.9 x 25.4 mm) PINOUT DIAGRAM This table shows how the pinout on Pressure 12 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin AN 1 AN PWM 16 NC NC 2 RST INT 15 NC NC 3 CS RX 14 NC NC 4 SCK TX 13 NC NC 5 MISO SCL 12 NC NC 6 MOSI SDA 11 NC Power Supply 3.3V 7 3.3V 5V 10 NC Ground GND 8 GND GND 9 GND Analog Output ONBOARD SETTINGS AND INDICATORS Label Name Default LD1 PWR - Description Power LED Indicator Notes Ground PRESSURE 12 CLICK ELECTRICAL SPECIFICATIONS Description Min Typ 0 - 600 mbar Operating temperature range -40 - +85 ⁰C Calibrated temperature range 0 - +50 ⁰C Output voltage update frequency - 1 - kHz Pressure range Max Unit SOFTWARE SUPPORT We provide a library for the Pressure 12 click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description The library contains all the necessary functions for converting ADC values to real voltages and pressure values. Key functions:    float pressure12_getPressure(uint16_t adcValue) - Convert ADC value to Pressure data in mBar. float pressure12_getVoltage(uint16_t adcValue) - Convert ADC value to Voltage in mV. void pressure12_setMaxVoltage(float volt) - Sets max output voltage on the AN pin. Examples description The application is composed of three sections :  System Initialization - Initializes LOG for logging data.  Application Initialization - ADC init.  Application Task - Reads ADC value, Convert ADC data to Voltage[mV] on the AN pin and convert to Pressure data in mBar. All data logs to the USBUART every 1sec.   void applicationTask()  {      uint16_t ADC_value;      float Voltage;      float Pressure;      char demoText[ 50 ];        ADC_value = pressure12_adcRead();      Voltage = pressure12_getVoltage(ADC_Value);      Pressure = pressure12_getPressure(ADC_Value);        WordToStr(ADC_value, demoText);      mikrobus_logWrite(" ADC value: ", _LOG_TEXT);      mikrobus_logWrite(demoText, _LOG_LINE);        FloatToStr(Voltage, demoText);      mikrobus_logWrite(" Voltage: ", _LOG_TEXT);      mikrobus_logWrite(demoText, _LOG_TEXT );      mikrobus_logWrite(" mV", _LOG_LINE );        FloatToStr(Pressure, demoText);      mikrobus_logWrite(" Pressure: ", _LOG_TEXT);      mikrobus_logWrite(demoText, _LOG_TEXT);      mikrobus_logWrite(" mBar", _LOG_LINE );        mikrobus_logWrite("‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐", _LOG_LINE);      Delay_ms( 1000 );  }    The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example:  ADC Library  Conversion Library Additional notes and informations Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message. MIKROSDK This click board is supported with mikroSDK - MikroElektronika Software Development Kit. To ensure proper operation of mikroSDK compliant click board demo applications, mikroSDK should be downloaded from the LibStock and installed for the compiler you are using. For more information about mikroSDK, visit the official page.                                     https://www.mikroe.com/pressure‐12‐click/6‐5‐19
MIKROE-3466 价格&库存
很抱歉,暂时无法提供与“MIKROE-3466”相匹配的价格&库存,您可以联系我们找货
