H-BRIDGE 3 CLICK
PID: MIKROE-3613 Weight: 31 g
H-Bridge 3 Click is designed for the control of small DC motors and inductive loads, it
features TLE9201SG a general purpose 6A H-Bridge perfectly suited for industrial and
automotive applications. This IC meets the harsh automotive environmental conditions
and it is qualified in accordance with the AEC-Q100 standard, also has set of features
such as the short circuit and over-temperature protection, under-voltage protection,
detailed SPI diagnosis or simple error flag and fully 3.3/5.5V compatible logic inputs.
H-bridge 3 click is supported by a mikroSDK compliant library, which includes functions
that simplify software development. This Click board™ comes as a fully tested product,
ready to be used on a system equipped with the mikroBUS™ socket.
H-Bridge 3 click can be used to drive a H-Bridge motor by changing output states. The
outputs can be pulse width modulated at frequencies up to 20kHz by means of
PWM/DIR control. While the signal at the direction input defines the direction of the DC
motor, the PWM signal controls the duty cycle. PWM/DIR control reduces the number of
PWM capable pins needed at the microcontroller.
For load currents above the current limitation threshold (7A typ.) the H-Bridge switches
into chopper current limitation mode. The H-bridge 3 click is protected against short
circuits and over temperature and provides diagnosis via SPI or basic error feedback via
status flag. Open load can be detected when the bridge is disabled or during PWM
operation of inductive loads.
HOW DOES IT WORK?
The main component used on the H-Bridge 3 click is the TLE9201SG, an H-Bridge DC
motor driver, with up to 28V and 6A, from Infineon. This IC is an efficient integrated Hbridge driver, with very low RDS ON output per switch. H-bridge in general, allows the
current to flow in one or another direction.
All internal supply voltages are derived from the external VIN conector. A charge pump
provides the gate voltage for the high side switches. The output buffer of the digital
output SO is supplied by the pin VSO. Therefore the output logic level at SO can be
easily configured for 3.3 V or 5 V logic by moving VCC SEL jumper to the respective
voltage.
The output stages consist of four n-channel mosfets in H-bridge configuration. The
outputs are protected against short circuits and over temperature. The bridge is
controlled using the inputs PWM and DIR. The signal at DIR is defining the direction of
the driven DC motor whereas the PWM signal sets the duty cycle. The outputs can be
set tristate (i.e. high side and low side switches are turned off) by setting DIS to high
level.
For diagnosis purposes the TLE9201SG is equipped with a “Serial Peripheral Interface“
(SPI). The H-bridge 3 click is configured as a “slave” device. This means that the host
microcontroller as the master is providing the chip select (CS) and clock signal (SCK).
A data transfer on the SPI bus is initiated with a falling edge on CS and is terminated by
a rising edge on CS. The data on the serial input pin SI is sampled with the falling edge
of SCK, the serial data output at MISO is determined by the rising clock edge. The data
is transferred “MSB first”. The word length of the SPI is 8 bit. Please note that there is
no check for the number of clocks within a SPI frame. Any low pulse at CS line will be
regarded as one frame.
The H-Bridge 3 click comes with a mikroC, mikroBASIC, and mikroPASCAL compilers
compatible library, which contains functions for easy and simple operating of this Click
board™. The provided example application demonstrates their usage and can be used
as a reference for custom projects.
SPECIFICATIONS
Type
Brushed
Applications
This click board can be used for exhaust gas recirculation (ERG), idle
speed control, auxiliary water pump or any industrial DC applications
On-board
modules
TLE9201SG is a general purpose 6 A H-Bridge, designed for (but not
limited to) the control of DC motors or other inductive loads in automotive
applications.
Key Features
TLE9201SG are equipped with fault diagnostic functions as: short to battery
voltage (SCB), short to ground (SCG), open load (OL), over-temperature
(OT)
Interface
GPIO,SPI
Input Voltage
3.3V or 5V
Click board
size
L (57.15 x 25.4 mm)
PINOUT DIAGRAM
This table shows how the pinout on H-Bridge click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Direction Input
DIR
1
AN
PWM
16
PWM
Output Disable
DIS
2
RST
INT
15
NC
Chip Select
CS
3
CS
RX
14
NC
Serial Clock
SCK
4
SCK
TX
13
NC
Serial Data Output
SDO
5
MISO
SCL
12
NC
Serial Data Input
SDI
6
MOSI
SDA
11
NC
Power Supply
3.3V
7
3.3V
5V
10
5V
Ground
GND
8
GND
GND
9
GND
Notes
Speed control
Power Supply
Ground
ONBOARD SETTINGS AND INDICATORS
Label
Name
Default
Description
JP1
VCC SEL
Left
PWR
PWR
Power LED indicator
VIN
VIN
Terminal for connecting external power supply +/-
Logic level voltage selection: left position 3.3V,
right position 5V
MOTOR
Terminal for connecting motor power OUT1 and
OUT2
H-BRIDGE 3 CLICK ELECTRICAL SPECIFICATIONS
Description
Min
Typ
Max
Voltage at the VIN terminal
4.5
28
V
6
8
10
A
3.6
4.4
5.2
V
kHz
Current Limit
Undervoltage threshold
PWM Frequency
Unit
OUTPUT TRUTH TABLE
DIS
PWM
DIR
OUT1
OUT2
1
X
X
Z
Z
disable, outputs tristate
1
H
L
forward/clockwise
L
H
reverse/counterclockwise
H
Z
freewheeling HS (forward)
Z
H
freewheeling HS (reverse)
H=High;
L=Low;
Z=High impedance;
X=Disregarded;
Comment
SOFTWARE SUPPORT
We provide a library for the H-Bridge 3 on our LibStock page, as well as a demo
application (example), developed using MikroElektronika compilers. The demo can run
on all the main MikroElektronika development boards.
Library Description
The library contains all the necessary functions for converting ADC values to real
voltages and pressure values.
Key functions:
void hbridge3_anSet( uint8_t pin_state ) - sets AN pin state.
void hbridge3_rstSet( uint8_t pin_state ) - sets RST pin state.
uint8_t hbridge3_spi( uint8_t spi_command ) - sends SPI command and receives response to
command sent.
Examples description
The application is composed of three sections :
System Initialization - Initializes SPI and LOG modules, AN, RST, CS and PWM pins .
Application Initialization - Initializes SPI driver and PWM module, sets minimum PWM duty cycle and
starts PWM .
Application Task - Checks for user input and based on entered character executes one of additional
functions. Checks for diagnosis register change and if it had changed, logs status message.
void applicationTask( )
uart_flag = UART_Data_Ready( );
if ( uart_flag == 1 )
uart_char = UART_Read( );
switch (uart_char)
case '+' :
hbridge3_casePlus( );
break;
case '-' :
hbridge3_caseMinus( );
break;
case 'd' :
hbridge3_caseDiagnosis( );
break;
case '1' :
hbridge3_caseDirection1( );
break;
case '2' :
hbridge3_caseDirection2( );
break;
case '0' :
hbridge3_caseOnOff( );
break;
default :
mikrobus_logWrite( "> Invalid command", _LOG_LINE );
break;
spi_response = hbridge3_spi( _HBRIDGE3_CMD_RD_DIA );
diagnosis_new = spi_response & 0x0F;
if (diagnosis_new != diagnosis_old)
hbridge3_logDiagnosis( diagnosis_new );
diagnosis_old = diagnosis_new;
if (( spi_response & 0x40 ) == 0x00 )
mikrobus_logWrite( "> Overtemperature shutdown", _LOG_LINE );
if (( spi_response & 0x10 ) == 0x00 )
mikrobus_logWrite( "> Current limitation active", _LOG_LINE );
Additional Functions :
void hbridge3_casePlus( ) - Increments duty cycle
void hbridge3_caseMinus( ) - Decrements duty cycle
void hbridge3_caseDiagnosis( ) - Gets diagnosis register content and logs status message
void hbridge3_caseDirection1( ) - Changes rotation direction to direction 1
void hbridge3_caseDirection2( ) - Changes rotation direction to direction 2
void hbridge3_caseOnOff( ) - Switches oputput MOSFETs on and off
The full application code, and ready to use projects can be found on our LibStock page.
Other Mikroe Libraries used in the example:
SPI
UART
Conversions
Additional notes and informations
Depending on the development board you are using, you may need USB UART
click, USB UART 2 click or RS232 click to connect to your PC, for development systems
with no UART to USB interface available on the board. The terminal available in all
MikroElektronika compilers, or any other terminal application of your choice, can be
used to read the message.
MIKROSDK
This Click board™ is supported with mikroSDK - MikroElektronika Software
Development Kit. To ensure proper operation of mikroSDK compliant Click board™
demo applications, mikroSDK should be downloaded from the LibStock and installed for
the compiler you are using.
For more information about mikroSDK, visit the official page.
DOWNLOADS
mikroBUS™ Standard specification
LibStock: mikroSDK
Click board catalog
H-Bridge 3 click Libstock
TLE9201SG Datasheet
H-Bridge 3 click 2D and 3D files
H-Bridge 3 click schematic
https://www.mikroe.com/h-bridge-3-click/7-12-19
很抱歉,暂时无法提供与“MIKROE-3613”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+380.297931+49.43750
