MIKROE-3634
MIKROE-3634
    MIKRO
    AEDR-8300 旋转编码器 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3634 数据手册
OPTO ENCODER 2 CLICK PID: MIKROE-3634 Weight: 18 g Opto Encoder 2 click is a linear incremental optical sensor/encoder click which can be used for the movement or rotation encoding. Encoders of this type are widely used for many applications, which involve precise detection of the position, speed, or rotational angle of an object. Rotary encoders are often used for various types of controllers on many different devices. Whether it be a rotary encoder knob controller or an angle encoder on a motor shaft, the principle is the same - it includes an optical sensor, just like the one found on Opto Encoder 2 click. Opto Encoder 2 click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. This Click board™ features a very small optical encoder employing reflective technology for motion control purposes. The encoder houses an LED light source and a photodetecting circuitry in a single package. It can be used as an optical sensor in automotive applications, motion, speed, and direction sensor, for precise motor shaft positioning applications, knob encoder applications, and similar applications, where dual channel optical sensing can be utilized. HOW DOES IT WORK? The optical sensor used on the Opto Encoder 2 click is the AEDR-8300, reflective Surface Mount Optical Encoder from Avago Technologies. This sensor combines an emitter and a detector in a single surface mount leadless package. the AEDR-8300 consists of three major components: a light emitting diode (LED) light source, a detector IC consisting photodiodes and lens to focus light beam from the emitter as well as light falling on the detector. The operation of the encoder is based on the principle of optics where the detector photodiodes sense the absence and presence of light. In this case, the rotary/linear motion of an object being monitored is converted to equivalent light pattern via the use of codewheel/codestrip. Opto Encoder 2 click offers options of either single channel or two-channel quadrature digital outputs. Being TTL compatible, the outputs of the AEDR-8300 series can be interfaced directly with MCU. Hence the Opto Encoder 2 click provides great design-in flexibility and easy integration into existing systems. A and B pins are routed to the routed to the mikroBUS™ PWM and INT pins, thus providing the quadrature digital signal. Signal encoding itself is done by the host MCU. Having two optical sensing channels, Opto Encoder 2 click has the ability of both speed and direction encoding. The most common usage is encoding of the step motor position: a cylinder with slits is physically mounted above the sensor so that the LED can illuminate the photodiodes only when light hits the reflective surface of the codewheel. By rotating this cylinder, the light beam will be blocked periodically. The single sensor output will be a pulse train, while the cylinder is rotating. Having two photo sensors physically distanced by a small amount, allows the pulse signal of the first sensor to be either delayed or expedited with respect to the pulse on the second sensor, depending on the rotational direction. Since the sensors recomended operating voltage is 5V, the Opto Encoder 2 click uses the 5V rail for power supply. The other pins it utilizes are the, before mentioned, Interrupt and PWM pins on mikroBUS™ socket. This click also has a Power LED indicator. This Click Board™ is designed to be operated only with 5V logic level. A proper logic voltage level conversion should be performed before the Click board™ is used with MCUs with logic levels of 3.3V. SPECIFICATIONS Type Optical Applications Automotive optical sensors, accurate position sensor for encoder, sensor for motion, speed, and direction, etc. On-board modules Reflective Surface Mount Optical Encoder from Avago Technologies Key Features The Opto Encoder 2 click features a precise detection of the position, speed, or rotational angle of an object. It is able to detect the direction of the movement since it features two photo-sensing elements. Interface GPIO Input Voltage 5V Click board size S (28.6 x 25.4 mm) PINOUT DIAGRAM This table shows how the pinout on Opto Encoder 2 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin NC Pin 1 AN PWM 16 B Notes Output B Ground NC 2 RST INT 15 A NC 3 CS RX 14 NC NC 4 SCK TX 13 NC NC 5 MISO SCL 12 NC NC 6 MOSI SDA 11 NC NC 7 +3.3V 5V 10 +5V Power Supply GND 8 GND GND 9 GND Ground Output A OPTO ENCODER 2 CLICK SPECIFICATIONS Description Min Typ Max Supply Voltage 4.5 5 5.5 V LED Current 13 15 18 µs Count Frequency - - 30 kHZ Resolution - 75 - LPI ONBOARD SETTINGS AND INDICATORS Label Name Default LD1 PWR - Description Power LED Indicator Unit SOFTWARE SUPPORT We provide a library for the Opto Encoder 2 click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description Library contains functions for getting INT(Channel A) and PWM(Channel B) pin states Library contains function for incrementing/decrementing encoder position Library contains function for reseting encoder position counter to 0(zero) Library contains function for getting current encoder position Key functions: • • • int32_t optoencoder2_getPosition(void) - returns current encoder position. void optoencoder2_zeroCounter(void) - resets encoder counter to 0(zero). uint8_t optoencoder2_isr( uint8_t n_cycles ) - checks for rising edge on Channel A (INT pin), within specified number of cycles (n_cycles), and increments or decrements encoder position. Examples Description The application is composed of three sections : • System Initialization - Initializes LOG, initializes PWM and INT pins. • Application Initialization - Initializes GPIO driver and resets encoder counter to 0(zero) . • Application Task - If encoder is moving - increments or decrements encoder position on every rising edge on Channel A (INT pin) and logs encoder position . • void applicationTask( ) { stop_flag = optoencoder2_isr(100); encoderPosition = optoencoder2_getPosition( ); if (stop_flag == 0) { LongToStr( encoderPosition, text ); mikrobus_logWrite( "> pos : ", _LOG_TEXT ); mikrobus_logWrite( text, _LOG_LINE ); } } The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example: • UART • Conversions Additional notes and informations Depending on the development board you are using, you may need USB UART click, USB UART 2 Click or RS232 Click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all Mikroelektronika compilers, or any other terminal application of your choice, can be used to read the message. MIKROSDK This click board is supported with mikroSDK - MikroElektronika Software Development Kit. To ensure proper operation of mikroSDK compliant click board demo applications, mikroSDK should be downloaded from the LibStock and installed for the compiler you are using. For more information about mikroSDK, visit the official page. DOWNLOADS mikroBUS™ Standard specification LibStock: mikroSDK Click board catalog Opto Encoder 2 click Libstock AEDR-8300 Datasheet Opto Encoder 2 click 2D and 3D files Opto Encoder 2 click schematic https://www.mikroe.com/opto-encoder-2-click/7-3-19
MIKROE-3634 价格&库存
很抱歉,暂时无法提供与“MIKROE-3634”相匹配的价格&库存,您可以联系我们找货
MIKROE-3634
  • 1+235.828181+30.65690
库存:2
MIKROE-3634
  • 1+273.191181+35.51397
库存:2
