MIKROE-3659
MIKROE-3659
    MIKRO
    ST25DV16K 近场通信(NFC) RF mikroBUS™ Click™ 平台评估扩展板
MIKROE-3659 数据手册
NFC TAG 4 CLICK PID: MIKROE-3659 Weight: 19 g NFC Tag 4 Click is NFC tag device, offering 16 Kbit of electrically erasable programmable memory (EEPROM). This Click Board™ offer two communication interfaces. The first one is an I2C serial link and can be operated from a DC power supply. The second one is a RF link activated when Click Board™ act as a contactless memory powered by the received carrier electromagnetic wave. It is perfectly suited for using in wide variety of applications, such as NFC enabled business cards, stickers, wristbands, key fobs, pens, movie passes, hang tags, medication bottles, and many more. NFC Tag 4 click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. NFC Tag 4 click is NFC tag device, featuring ST25DV16K - the compact NFC tag IC from STMicroelectronics. This IC includes a full set of features, like Fast data transfer between I2C and RF interfaces, half-duplex 256-byte dedicated buffer, energy harvesting, data protection features, and more. NFC Tag 4 click also features the onboard trace antenna, ensuring that no external components are required in order to use this Click Board™. HOW DOES IT WORK? The active NFC tag component on NFC Tag 4 click is the ST25DV16K - the compact NFC tag IC from STMicroelectronics. The Click board™ itself has a reasonably small number of components because most of the interface and EEPROM memory circuitry is already integrated on the ST25DV16K IC. The I2C / SMBus compatible serial interface lines, along with the GPO pin, which also works in the open drain configuration, are pulled up by the onboard resistors. The 2-Wire lines are routed to the respective I2C lines of the mikroBUS™ (SCK and SDA), while the GPO pin of the main IC is routed to the INT pin of the mikroBUS™ The ST25DV16K uses the I2C/SMBus compatible communication interface, offering a fast transfer mode (FTM), to achieve a fast link between RF and contact worlds, via a 256 byte buffer called Mailbox. This mailbox dynamic buffer of 256 byte can be filled or emptied via either RF or I2C. There is also the INT pin available, which indicates incoming event to the contact side, like RF Field changes, RF activity in progress, RF writing completion or Mailbox message availability. The built in energy harvesting element can deliver µW of power when external conditions make it possible. The integrated RF management allows the NFC Tag 4 click to ignore RF requests. All these features can be programmed by setting static and/or dynamic registers of the ST25DV16K. ST25DVxxx can be partially customized using configuration registers located in the E2 system area. More information about all the registers can be found in the ST25DV16K datasheet. However, provided library contains functions that simplify the use of the NFC Tag 4 click. The included application example demonstrates their functionality and it can be used as a reference for custom design. In order to make sure that no external components are required in order to use it, this Click Board™ contains the integrated trace antenna on the PCB. The antenna coil is correctly tuned and can be used to power and access the device using the ISO/IEC 15693 and ISO 18000-3 mode 1 protocols. Power is transferred to the ST25DV16K by radio frequency at 13.56 MHz via coupling antennas of the NFC Tag 4 click and the NFC Reader being used. The ISO 15693 standard defines the carrier frequency (fC) of the operating field as 13.56 MHz ±7 kHz. The Click board™ can be supplied and interfaced with both 3.3V and 5V without the need for any external components. The onboard SMD jumper labeled as VCC SEL allows voltage selection for interfacing with both 3.3V and 5V MCUs. SPECIFICATIONS Type NFC Applications NFC enabled business cards, stickers, wristbands, key fobs, pens, movie passes, hang tags, medication bottles, and many more. On-board modules ST25DV16K - the compact NFC tag IC from STMicroelectronics Key Features Fast data transfer between I2C and RF interfaces, half-duplex 256-byte dedicated buffer, energy harvesting, data protection features, integrated antenna onboard Interface I2C Input Voltage 3.3V or 5V Compatibility mikroBUS Click board size L (57.15 x 25.4 mm) PINOUT DIAGRAM This table shows how the pinout on NFC Tag 4 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin Notes NC 1 AN PWM 16 NC NC 2 RST INT 15 INT NC 3 CS RX 14 NC NC 4 SCK TX 13 NC NC 5 MISO SCL 12 SCL I2C Clock NC 6 MOSI SDA 11 SDA I2C Data Power Supply 3.3V 7 3.3V 5V 10 5V Ground GND 8 GND GND 9 GND Interrupt output Power Supply Ground ONBOARD SETTINGS AND INDICATORS Label Name Default JP1 VCC SEL Left Description Power supply voltage selection: left position 3V3, right position 5V LD1 PWR - Power LED indicator SOFTWARE SUPPORT We provide a library for the NFC Tag 4 click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description Library contains function for getting INT pin state Library contains function for setting CS pin state Library contains function for getting register values Library contains function for setting register values Library contains function for device initialization Library contains function for getting temperature value Library contains function for getting axes values Library contains function for software reset Library contains functions for setting power mode and full scale range Key functions: • • • uint8_t nfctag4_password_present( uint8_t * password_bytes ) - presents password to device in order to open I2C security session. uint8_t nfctag4_init( void ) - initializes the device. uint8_t nfctag4_enable_mailbox( uint8_t enable_mailbox ) - enables or disables mailbox functionality. Examples description The application is composed of three sections : • System Initialization - Initializes GPIO pins, I2C and LOG modules. • Application Initialization - Initializes I2C driver, presents password to the device and initializes the device. • Application Task - Checks if RF placed a message to mailbox and if it did, checks message length and logs message bytes. void applicationTask( ) { nfctag4_wait_for_int( ); nfctag4_i2c_get( _NFCTAG4_MEMORY_DYNAMIC, _NFCTAG4_DYNAMIC_REG_MB_CTRL, &aux_buffer[0], 1 ); if (( aux_buffer[0] & 0x04 ) == ( 0x04 )) { nfctag4_wait_for_int( ); nfctag4_i2c_get( _NFCTAG4_MEMORY_DYNAMIC, _NFCTAG4_DYNAMIC_REG_MB_LEN, &aux_buffer[0], 1 ); message_length = aux_buffer[0]; message_length++; nfctag4_wait_for_int( ); nfctag4_i2c_get( _NFCTAG4_MEMORY_MAILBOX, _NFCTAG4_MAILBOX_REG_BYTE_0, &aux_buffer[0], message_length ); mikrobus_logWrite( " ", _LOG_LINE ); mikrobus_logWrite( "> ********* MESSAGE ********* Message length : ", _LOG_TEXT ); mikrobus_logWrite( text, _LOG_TEXT ); mikrobus_logWrite( " [Bytes]", _LOG_LINE ); for (i = 0; i < message_length; i ++) { ByteToStr( i, text ); mikrobus_logWrite( text, _LOG_TEXT ); mikrobus_logWrite( " : ", _LOG_TEXT ); ByteToHex( aux_buffer[ i ], text ); mikrobus_logWrite( "0x", _LOG_TEXT ); mikrobus_logWrite( text, _LOG_LINE ); } mikrobus_logWrite( "> *********** END ***********
MIKROE-3659 价格&库存
很抱歉,暂时无法提供与“MIKROE-3659”相匹配的价格&库存,您可以联系我们找货
