MIKROE-3709
MIKROE-3709
    MIKRO
    STEP UP CLICK
MIKROE-3709 数据手册
        STEP UP CLICK PID: MIKROE-3709 Weight: 21 g Step Up Click is a fixed frequency DC-DC step-up (boost) regulator, which can be obtained from any low voltage input - such as NiCd, NiMH or one cell Li-Po/Li-Ion batteries. This click features very high efficiency, low noise and anti-ringing voltage output and inrush current limiting with the internal soft-start, as well as true disconnect option for minimized power drain, when in shutdown mode. These features allow this device to be used as the power source for various battery-operated devices, such as microcontrollers, various portable embedded electronic devices, handheld instruments, GPS modules, or various battery-operated USB emergency backup chargers. Very good switching efficiency factor ensures prolonged battery life for any application this device is used in. Step Up click board™ is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Step Up click carries the MCP1665, a high-voltage, 3.6A, integrated switch PFM/PWM boost regulator, available in a 2mm x 2mm VQFN® package, from Microchip. Boost click provides an adjustable output voltage through the onboard DAC that drives the FB pin of the MCP1665 to set desired output voltage. The input voltage can be in range from 2.9V to 5V V from an external DC source connected to VIN screw terminal. The output voltage can be set up to 32V. HOW DOES IT WORK? Step Up click utilizes the MCP1665, a 500 kHz, compact, high-efficiency, fixedfrequency, nonsynchronous step-up DC-DC converter that integrates a 36V, 100 mΩ NMOS switch, from Microchip. This IC is targeted towards boosting the voltage from NiCd, NiMH, Li-Po/Li-Ion batteries and as such it has a great efficiency factor, that allows for prolonged battery life. The MCP1665 IC uses the fixed switching frequency of 500 kHz and has the overvoltage protection to ensure safe operation. Thanks to the undervoltage lockout feature, the voltage step-up process starts with the input voltage as low as 2.7V. MCP1665 features an UVLO that prevents fault operation below 2.7V, which corresponds to the value of three discharged primary Ni-Cd cells. The device starts its normal operation at 2.85V (typical) input. For the optimal efficiency, the device should be powered with at least 2.85V at the input terminal. Output current depends on the input and desired output voltageFor example, when powered with 4V at the input, Step Up click will be able to deliver about 1A @ 12V to the connected load. As with the most step-up regulators, the input voltage should always be less than the voltage at the output to maintain the proper regulation. On the diagram below, the dependence of the maximum output current (Iout) on the input and typical output voltages is given. The MCP1665 step-up regulator actively damps the oscillations typically found at the switch node of a boost converter. This removes the high-frequency radiated noise, ensuring low noise operation. Besides the MCP1665, Step Up 2 click also contains the D/A converter (DAC) labeled as MCP4921, 12-Bit DACs with the SPI Interface by Microchip, which is used in feedback loop. The DACs is connected to the feedback loop of the boost converter and therefore, the DAC signal which commonly ranges from 0 to +VREF, influences the voltage on the feedback midpoint. That way, the output voltage can be set to a desired value, up to 30V. The mentioned DAC uses SPI communication so the SDI, SDO, SCK, and CS pin of the mikroBUS™ are used for communication with the main MCU. The device also features the mode pin, labeled as MOD, which is constructed as the open-drain output, that is pulled HIGH by the onboard 10K resistor. This allows an easy interfacing with the MCU and a simple solution to have the control over the switching mode. When the MOD pin is set to logic high level, the device is switching in PFM for light load. The MOD pin is routed to the mikroBUS™ RST pin Besides the mode pin, the EN pin used to enable the device is routed to the mikroBUS™ CS pin. When pulled LOW, this pin will engage the true disconnect of the output load option, resulting in very low quintessential currents, suitable for the batteryoperated devices. This pin is also pulled HIGH by the onboard resistor. SPECIFICATIONS PINOUT DIAGRAM This table shows how the pinout on Step Up click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin NC 1 AN PWM 16 EN MOD 2 RST INT 15 NC CS 3 CS RX 14 NC SPI Clock SCK 4 SCK TX 13 NC SPI Data Out SDO 5 MISO SCL 12 NC SPI Data In SDI 6 MOSI SDA 11 NC NC 7 3.3V 5V 10 5V GND 8 GND GND 9 GND Mode input SPI Chip Select Ground Notes Enable Input Power Supply Ground ONBOARD SETTINGS AND INDICATORS Label Name Default Description LD1 PWR - Power LED Indicator TB1 VIN - Input voltage terminal TB2 VOUT - Output voltage terminal SOFTWARE SUPPORT We provide a library for the Step Up click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description Library contains functions for setting states of RST and PWM pins Library contains function for setting configuratoin word Library contains function for setting output value Library contains function for calculating output value expressed in percent Library contains function for device initialization. Key functions:    uint8_t stepup_setConfig( uint16_t config ) - sets first 4 bits in command word. uint8_t stepup_setOut( uint16_t out_value ) - sets output value. void stepup_init(void) - initializes the device. Examples description The application is composed of three sections :  System Initialization - Initializes SPI, LOG, RST, CS and PWM pins  Application Initialization - Initializes SPI driver, sets config word, initializes the device, sets and log output value  Application Task - Checks for user input in UART terminal, if user enters + or - output value is increased or decreased respectively void applicationTask( )  {      if (UART_Data_Ready( ) == 1)      {          uart_char = UART_Read( );          switch ( uart_char )          {              case '‐' :              {                  if (out_value  0)                  {                      out_value‐‐;                  }                  stepup_setOut( out_value );                  stepup_logPercent( out_value );                  break;              }              default :              {                  mikrobus_logWrite( "error : invalid command", _LOG_LINE );                  break;              }          }      }  }      Additional Functions :  stepup_logPercent() - calls 'stepup_getPercent()' function to get output value in expressed as percentage and logs that value The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example:  SPI  UART  Conversions Additional notes and informations Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message. MIKROSDK This Click board™ is supported with mikroSDK - MikroElektronika Software Development Kit. To ensure proper operation of mikroSDK compliant Click board™ demo applications, mikroSDK should be downloaded from the LibStock and installed for the compiler you are using. For more information about mikroSDK, visit the official page.     https://www.mikroe.com/step‐up‐click/8‐20‐19
MIKROE-3709 价格&库存
很抱歉,暂时无法提供与“MIKROE-3709”相匹配的价格&库存,您可以联系我们找货
MIKROE-3709
  • 1+201.338851+25.83405
MIKROE-3709
    • 1+183.66885
    • 5+179.99276
    库存:3
