MIKROE-3711
MIKROE-3711
    MIKRO
    SKRHABE010 操纵杆 人机接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3711 数据手册
          JOYSTICK 2 CLICK PID: MIKROE-3711 Weight: 19 g Joystick 2 Click is a smart navigation key concept based on SKRHABE010 by Alps, a 4-direction joystick switch with Center-push Function. Alps switches, also known as microswitches, are well renowned for their reliability and endurance. Joystick switches of this kind are widely used in many different applications. Joystick 2 click can be used in numerous different applications, as a humanmachine interface device (HMI), such as cell phones, tablets, terminals, video games, toys, and many more. Joystick 2 click board™ is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket.   Joystick 2 click includes the SKRHABE010 by Alps, which is the omni directional joystick switch with center-push function. The mentioned joystick switch have 5 output pins – each for a single switch direction. With its body height of 1.85mm, it is very easy to implement it in various designs and thanks to the simple principles of operation, users have the ability to adapt it in a desired way. Its long-life (of 1 million life cycles) guarantees the rigidity and durability of the product. HOW DOES IT WORK? Joystick 2 click contains a SKRHABE01, a 4-direction joystick switch with Center-push Function by Alps. It is positioned on the board so it is easily accessible for interacting and the lever could be pressed, activating the microswitch that way. The microswitch is actuated by applying very little physical force, using a tipping-point mechanism which results in fast and reliable snap-in action. It has both NO (Normal open) contacts routed to the mikroBUS™ over the port expander. The switch lines are equipped with the RC filters, which serve as debouncing elements for the switch and also to pull-up the lines when they are left afloat. This way, the contact bouncing is reduced even further, resulting in an accurate detection of the switching event. As already mentioned above, this click board™ contains the port expander, relatively large number of needed GPIO pins for the joystick switch. Used IC is PCA9538A, Lowvoltage 8-bit I2C-bus I/O port with interrupt and reset, from NXP Semiconductors. It uses the I2C communication for interfacing with the main MCU, which simplifies the number of needed pins, and therefore the design itself. The Active LOW reset input (RESET) and Open-drain active LOW interrupt output (INT) pins helps simplifying the design even further. The click board™ also features an onboard jumper selector, which is used to select the voltage level that is connected to the microswitch input pin, making it usable for both 3V3 and 5V capable microcontoller pins. SPECIFICATIONS Type Pushbutton/Switches Applications Cell phones, tablets, terminals, video games, toys, and many more. On-board modules SKRHABE010 4-direction joystick switch with Center-push Function by Alps and Port Expander IC from NXP, PCA9538A Key Features High-quality microswitch, high mechanical and electrical durability, debouncing features Interface GPIO,I2C Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V PINOUT DIAGRAM This table shows how the pinout on Joystick 2 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Reset IN Pin Pin NC 1 AN PWM 16 NC RST 2 RST INT 15 INT NC 3 CS RX 14 NC Notes Interrupt Out NC 4 SCK TX 13 NC NC 5 MISO SCL 12 SCL I2C Clock NC 6 MOSI SDA 11 SDA I2C Data Power Supply 3.3V 7 3.3V 5V 10 5V Ground GND 8 GND GND 9 GND Power supply Ground ONBOARD SETTINGS AND INDICATORS Label Name Default Description JP1 VCC SEL Left Power supply voltage selection. Left position 3V3, right position 5V LD1 Power LED - Power LED indicates that the click is powered on JS1 SWITCH - Onboard switch JOYSTICK 2 CLICK ELECTRICAL SPECIFICATIONS Description Min Typ Max Unit Contact resistance - - 100 mΩ Mechanical durability (30 operations/min) - - 1 milion cycles SOFTWARE SUPPORT We provide a library for the Joystick 2 click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description The library initializes and defines the I2C bus driver and drivers that offer a choice for writing data in register and reads data from register. The library includes function for Joystick position. The user also has the function for configuration joystick, reset module and function for read interrupt state. Key functions:    uint8_t joystick2_getJoystickPosition() - Functions for get Joystick position void joystick2_configuration(uint8_t cfgData) - Functions for configuration joystick void joystick2_reset() - Functions for reset module Examples description The application is composed of three sections :  System Initialization - Initializes the I2C module and all the necessary GPIO pins  Application Initialization - Initializes the driver init, resets the module, and enables all joystick positions  Application Task - It reads the position of the joystick, if it detects that the joystick has moved from the zero position, it prints a message about the current position   void applicationTask()  {      uint8_t joystickPos;      char demoText[ 50 ];            joystickPos = joystick2_getJoystickPosition();        switch(joystickPos)      {          case _JOYSTICK2_BUTTON_ACTIVE:          {              mikrobus_logWrite("‐‐‐ Button is pressed!!! ‐‐‐", _LOG_LINE );              Delay_ms( 300 );              break;          }          case _JOYSTICK2_POSITION_RIGHT:          {              mikrobus_logWrite("‐‐‐ Joystick position [RIGHT] ‐‐‐", _LOG_LINE );              Delay_ms( 300 );              break;          }          case _JOYSTICK2_POSITION_LEFT:          {              mikrobus_logWrite("‐‐‐ Joystick position [LEFT] ‐‐‐", _LOG_LINE );              Delay_ms( 300 );              break;          }          case _JOYSTICK2_POSITION_UP:          {              mikrobus_logWrite("‐‐‐ Joystick position [UP] ‐‐‐", _LOG_LINE );              Delay_ms( 300 );              break;          }          case _JOYSTICK2_POSITION_DOWN:          {              mikrobus_logWrite("‐‐‐ Joystick position [DOWN] ‐‐‐", _LOG_LINE );              Delay_ms( 300 );              break;          }      }  }    The full application code, and ready to use projects can be found on our LibStock page. Other mikroE Libraries used in the example:  I2C Library  UART Library Additional notes and informations Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to USB interface available on the board. The terminal available in all MikroElektronika compilers, or any other terminal application of your choice, can be used to read the message. MIKROSDK This Click board™ is supported with mikroSDK - MikroElektronika Software Development Kit. To ensure proper operation of mikroSDK compliant Click board™ demo applications, mikroSDK should be downloaded from the LibStock and installed for the compiler you are using. For more information about mikroSDK, visit the official page.           https://www.mikroe.com/joystick‐2‐click/8‐29‐19
MIKROE-3711
物料型号:PCA9538A
器件简介: - 该器件是Joystick 2 Click,基于Alps的SKRHABE010,是一个带有中心推动功能的4方向摇杆开关。Alps开关以其可靠性和耐用性而闻名,广泛应用于手机、平板电脑、终端机、电子游戏、玩具等多种应用。
引脚分配: - 该Click板™通过mikroBUS™插座与主控制器通信,包括3V3和5V电源引脚、GND地线、I2C通信的SCL和SDA引脚、复位输入(RST)和中断输出(INT)。
参数特性: - 具有高机械和电气耐久性,寿命周期达100万次。 - 支持3.3V或5V输入电压。 - 板上有跳线选择器,可为微动开关输入引脚选择电压水平。
功能详解: - 包含SKRHABE010,一个全方位摇杆开关,通过施加很小的物理力激活微动开关。 - 使用PCA9538A,一个低电压8位I2C总线I/O端口,具有中断和复位功能,简化设计。
应用信息: - 可用于手机、平板电脑、终端机、电子游戏、玩具等多种应用。
封装信息: - Click板尺寸为M(42.9 x 25.4 mm)。
软件支持: - 提供了与MikroElektronika编译器兼容的库,包括初始化I2C总线驱动程序的函数,以及用于读取和写入寄存器数据的驱动程序。 - 库中包括获取摇杆位置、配置摇杆、重置模块和读取中断状态的函数。
电气规格: - 接触电阻最大100mΩ,机械耐久性(30次操作/分钟)可达100万次。
附加信息: - 根据使用的开发板,可能需要USB UART Click、USB UART 2 Click或RS232 Click连接到PC。
MIKROE-3711 价格&库存
很抱歉,暂时无法提供与“MIKROE-3711”相匹配的价格&库存,您可以联系我们找货
