MIKROE-3744
MIKROE-3744
    MIKRO
    MAX1501 电池充电器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3744 数据手册
      CHARGER 12 CLICK  PID: MIKROE-3744 Weight: 18 g Charger 12 Click is a single lithium-ion (Li+) cell or three-cell NiMH/NiCd battery charger. This click can be used for Low-Cost Li-Ion battery chargers, or Power Tools, toys, backup energy storage solutions, etc. Charger 12 click is based on MAX1501 controller which has some extra features enabling charging without too much hassle. This click board has charging current control which uses SPI interface through MCP4161 IC, which is an 8-bit digital potentiometer. On the board, there is a Power LED and two extra LED’s which can be used for charging indications. Charger 12 click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. As a Lithium Ion batteries require a very accurate current and voltage for charging, Charger 12 click can be a perfect solution for such a task. Charger 12 click is equipped with a highly integrated Li-Ion battery charger, supporting intelligent, constant-current, constant voltage (CCCV), temperature-regulated battery charger charges a single lithium-ion (Li+) cell or three- cell NiMH/NiCd batteries. This click has a charging current control IC over SPI interface which  ensures perfect and efficient charging. Charger 12 click can be used as a part of the power  supply and distribution system in many applications: different kinds of handheld appliances,  portable media players, portable audio players, and other general‐purpose battery‐operated  electronic devices.  HOW DOES IT WORK?  Charger 12 click is based on the MAX1501 ‐ highly Integrated, linear battery charger with  thermal regulation for portable applications, from Maxim Integrated. MAX1501 is an efficient  Lithium ion battery charger, thanks to Microprocessor‐Controlled specific charge algorithms for  Li‐Ion batteries to achieve optimal capacity and safety in shortest charging time possible. Along  with its small physical size, the low number of external components makes this IC ideally  suitable for various applications. The 4.2V factory preset reference voltage simplifies design.  The fast charge constant current is set by a digital potentiometer. On this Click it is MCP4161 –  an 8‐bit digital potentiometer from Microchip, with external 1.5KΩ resistor in series. Thanks to  proprietary programmable die temperature regulation, MAX1501 can limit the charge current  based on the temperature during high power or high ambient conditions. This thermal  regulation optimizes the charge cycle time while maintaining device reliability.    The MAX1501 IC is designed with reliability in mind: the IC prevents draining the battery below  the critical level, protects it from overheating (if thermistor is used), offers prequel charging (for  deeply depleted batteries), features an overvoltage protection, charging status monitoring and  so on. The Click board™ itself is equipped with a set of indicators used to monitor both charging  process and power distribution.   CHARGE LED indicates the charge‐in‐progress status.   FAULT LED indicates an error during charging process.  The digital potentiometer on Charger 12 click is MCP4161 which offers a wide range of product  offerings using a SPI interface. WiperLock technology allows application‐specific calibration  settings to be secured in EEPROM. This digital pot is tied with charger IC over its wiper (P0W)  pin. By assigning values on MCP4161 from 0 to 10 kilo ohms battery charging can be controlled.  As there is a 1.5K resistor in series it can never be 0 ohms on MAX1501 chargers PROG pin.  However, maximum resistance cannot exceed 11.5 kiloohms. Fast charging can be regulated  with 10K on PROG pin to get 130 mA. To get 1000 mA digital potentiometer needs to go down  to 0 ohm, along with external resistor, which makes 1,5 K. Communication with digital  potentiometer on this Click and that way controlling the charger is done through SPI interface.  On the left side of the click board is an input screw terminal with corresponding markings,  where the recommended external voltage of 6V can be applied. The left screw terminal is  reserved for a Lithium Iron Phosphate battery with GND and VBAT+ markings. When connected  to power source, the green PWR LED will indicate it. Red LED1 and green LED2 can be used for  visual charge monitoring. As those two LEDs are multipurpose, they can be used for various  things.  The voltage range which can be used to power up the BATT‐MON click, allows for it to work  with both 3.3V and 5V capable MCUs. It can be selected by soldering a small SMD jumper,  labeled as VCC SEL to the correct position.  SPECIFICATIONS  Type  Battery charger  Applications  Charger 12 is a perfect choice for development lithium‐ion (Li+) cell or  three‐cell NiMH/NiCd battery charging applications.  On‐board  modules  MAX1501, highly Integrated, linear battery charger with thermal  regulation for portable applications, from Maxim Integrated.  Key Features  Intelligent, constant‐current, constant voltage (CCCV), temperature‐ regulated battery charger  Interface  GPIO,SPI  Click board size  M (42.9 x 25.4 mm)  Input Voltage  3.3V,5V  PINOUT DIAGRAM  This table shows how the pinout on Charger 12 click corresponds to the pinout of the  mikroBUS™ socket (the latter shown in the two middle columns).  Notes  Pin  Pin  Notes    NC  1  AN  PWM  16  MOD  Mode Select Input  Charging Enable  CHE  2  RST  INT  15  VOK  Input Voltage Range  Chip Enable  SDN  3  CS  RX  14  NC     Serial Clock  SCK  4  SCK  TX  13  NC        NC  5  MISO  SCL  12  NC     Serial Data In  SDI  6  MOSI  SDA  11  NC     Power Supply  3.3V  7  3.3V  5V  10  5V  Power Supply  Ground  GND  8  GND  GND  9  GND     Ground  SOFTWARE SUPPORT  We provide a library for the Charger 12 click on our LibStock page, as well as a demo  application (example), developed using MikroElektronika compilers. The demo can run on all  the main MikroElektronika development boards.  Library Description  Library contains functions for getting and setting GPIO pin states Library contains function for  mode selection Library contains function for SPI transfer operation Library contains function for  SPI get register operation Library contains functions for incrementing and decrementing wiper  position  Key functions:   uint8_t charger12_mode_select( uint8_t mode_select ) ‐ selects device operation mode by setting  RST(CHGEN) and PWM(MODE) pins   void charger12_spi_increment_wiper( void ) ‐ increments wiper position by sending 8bit increment  wiper command   void charger12_spi_decrement_wiper( void ) ‐ decrements wiper position by sending 8bit decrement  wiper command  Examples description  The application is composed of three sections :   System Initialization ‐ Initializes GPIO pins, SPI and LOG modules   Application Initialization ‐ Iniztializes SPI driver   Application Task ‐ Executes additional functions based on user input    void applicationTask( )  {      uart_ready = UART_Data_Ready( );        if (uart_ready == 1)      {          uart_char = UART_Read( );            switch (uart_char)          {              case '+' :              {                  charger12_case_Plus( );                  break;              }              case '‐' :              {                  charger12_case_Minus( );                  break;              }              case '1' :              {                  charger12_case_One( );                  break;              }              case '2' :              {                  charger12_case_Two( );                  break;              }              case '3' :              {                  charger12_case_Three( );                  break;              }              case '4' :              {                  charger12_case_Four( );                  break;              }              default :              {                  mikrobus_logWrite( "> Invalid command", _LOG_LINE );                  break;              }          }      }  }    Additional Functions :   charger12_case_Plus() ‐ Increments Wiper position   charger12_case_Minus() ‐ Decrements Wiper position   charger12_case_One() ‐ Selects 1st mode of operation   charger12_case_Two() ‐ Selects 2nd mode of operation   charger12_case_Three() ‐ Selects 3rd mode of operation   charger12_case_Four() ‐ Selects 4th mode of operation  The full application code, and ready to use projects can be found on our LibStock page.  Other mikroE Libraries used in the example:   SPI   UART   Conversions  Additional notes and informations   Depending on the development board you are using, you may need USB UART click, USB UART 2 click or RS232 click to connect to your PC, for development systems with no UART to  USB interface available on the board. The terminal available in all MikroElektronika compilers,  or any other terminal application of your choice, can be used to read the message.  MIKROSDK  This Click board™ is supported with mikroSDK ‐ MikroElektronika Software Development Kit.  To ensure proper operation of mikroSDK compliant Click board™ demo applications, mikroSDK  should be downloaded from the LibStock and installed for the compiler you are using.    For more information about mikroSDK, visit the official page.      https://www.mikroe.com/charger‐12‐click/9‐25‐19
MIKROE-3744 价格&库存
很抱歉,暂时无法提供与“MIKROE-3744”相匹配的价格&库存,您可以联系我们找货
MIKROE-3744
  • 1+158.878451+20.58032
MIKROE-3744
  • 1+124.920711+16.18160
库存:2
