MIKROE-3745
MIKROE-3745
    MIKRO
    I/O 扩展 连接性 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3745 数据手册
      TERMINAL CLICK  PID: MIKROE-3745 Weight: 21 g Terminal click is a mikroBUS™ socket expansion board, which provides an easy and elegant solution for adding the external connection capability to the click board™, plugged on a mikroBUS™. Featuring stacking headers makes it easy way for expanding the connectivity of the development system with the mikroBUS™, while keeping the bus free to use with any click board™. Terminal click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Terminal click can be especially interesting for the development systems that are equipped with mikroBUS™ slots only, or small number of GPIO pins available, such as the Clicker family of development systems. Using Terminal click on such system will greatly improve its usability, and yet it will remain small, compact and manageable. Thanks to standard-pitch (2.54mm) header, it is easy to connect a wire jumper, a probe of an oscilloscope for example, or maybe some additional electronic circuit. That way, Terminal click makes it easy monitor signals in realtime, while the click board is present in the system. HOW DOES IT WORK?  Terminal click consists of a high‐quality PCB that can be connected to the mikroBUS™ as any  other click board. On the top of the Terminal click, a 2x8 pin header is placed. Each of the  header pins is corresponding to a pin on the mikroBUS™ being used. These are simply wired in  parallel. Thanks to the stacking headers, the connection with the click board™ remains firm and  stable. Besides . Having this kind of stacking topology, allows for easy pin access and  manipulation of the stacked click boards™, retaining a perfect connection quality at all times.    When there's a need to attach external equipment to the development system, the desired  mikroBUS™ socket can be populated with Terminal click, allowing even more connections. This  makes the stacking capacity almost unlimited. However, attention should be paid not to make  the lines attached to the mikroBUS™ too long. In situations like this, the frequency of the  communication might need to be stepped down a bit, in order to compensate for the  longer mikroBUS™ signal lines.  Lines of the mikroBUS™ to which Terminal click is attached, are shared through the top 16‐pin  header, which mirrors pins of the connected mikroBUS™. Therefore, a care should be taken  when working with the Terminal click and connecting an external device to it, because the same  pins on the mikroBUS™ are shared, either for the communication (SPI, UART, I2C) or for some  other purpose (RST, INT, or other pins used as GPIO).  Since all the stacked click boards™ share the same power rails, a Terminal click also shares the  power rails, which makes it compatible with any click board™ and development systems.  CLICK BOARD™ PRODUCT RANGE  The union of Terminal click with the other click boards™ allows you to reach an unlimited  number of possibilities when it comes to combining different functionalities and adding  external connectivity. You just need to choose the ones you want from our ever‐growing  range: environmental sensors, LEDs, speech recognition, heart rate sensors, motor control,  GSM, GPS, WiFi, analog to digital converters, movement sensors.  More than 700 click boards™ that can be stacked and integrated in a simple and convenient  way are at your disposal.  SPECIFICATIONS  Type  Adapter  Applications  Provides easy, secure and reliable stacking of up to four additional boards  per mikroBUS™ socket.  Interface  GPIO  Click board  size  L (57.15 x 25.4 mm)  Input Voltage  3.3V,5V  PINOUT DIAGRAM  This table shows how the pinout on Terminal Click corresponds to the pinout on the mikroBUS™  socket (the latter shown in the two middle columns).  Notes  Pin  Pin  Notes    Analog Input  AN  1  AN  PWM  16  PWM  PWM Output  RST  2  RST  INT  15  INT  Hardware Interrupt  CS  3  CS  RX  14  TX  UART Transmit  SPI Clock  SCK  4  SCK  TX  13  RX  UART Receive  SPI Slave Data Out  SDO  5  MISO  SCL  12  SCL  I2C Clock  SPI Slave Data In  SDI  6  MOSI  SDA  11  SDA  I2C Data  Power Supply  3V3  7  3.3V  5V  10  5V  Ground  GND  8  GND  GND  9  GND  Reset  SPI Chip Enable  Power Supply  Ground  ONBOARD SETTINGS AND INDICATORS  Label  Name  Default  LD1  PWR  ‐  Power LED Indicator  J1  HM2X8  ‐  J1 Connector (2.54mm pitch, male header) has 16 pins, one for  every mikroBUS™ pin.   Description      https://www.mikroe.com/terminal‐click/9‐25‐19
MIKROE-3745 价格&库存
很抱歉,暂时无法提供与“MIKROE-3745”相匹配的价格&库存,您可以联系我们找货
MIKROE-3745
  • 1+59.93164
  • 5+58.73404
库存:15
