MIKROE-3773
MIKROE-3773
    MIKRO
    BLE 4 CLICK
MIKROE-3773 数据手册
          BLE 4 CLICK PID: MIKROE-3773 Weight: 18 g BLE 4 Click is fully embedded stand-alone Bluetooth 5.0 low energy connectivity module, equipped with the NINA-B312, an ultra-small, high-performing, standalone Bluetooth low energy module for easy integration of Bluetooth low energy connectivity (BLE) into various electronic devices. This module combines a high-performance Arm® Cortex®-M4 CPU microprocessor with FPU, and stateof-the-art power performance. Reliable and easy to use, BLE 4 click is a perfect solution for development of various IoT applications, smart home applications, BLE enabled toys, advanced robotics, and other similar applications. BLE 4 click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket.   BLE 4 click is a Click board™ which provides Bluetooth Low Energy connectivity for any embedded application. It features the NINA-B312, an integrated wireless connectivity solution. The NINA-B312 module itself is based on the nRF52840 chip, a flexible, efficient Bluetooth 5 and Bluetooth mesh multiprotocol SoC. Armed with such a powerful processor, the NINA-B312 can achieve data rates of up to 2 Mbps and up to 5 dBm maximum radiated output power using internal antenna, ensuring a reliable connection and good signal coverage. BLE 4 click is ideal for small smart devices like home automation sensor and fitness applications that need to require really low power consumption and long battery life. HOW DOES IT WORK? BLE 4 click is equipped with the NINA‐B312, Stand-alone Bluetooth 5 low energy module by u‐blox, which is based on the nRF52840 chip. The nRF52840 is the midrange member of the nRF52 Series SoC family. It meets the challenges of a broad range of applications that need Bluetooth 5 feature sets, protocol concurrency and a rich and varied set of peripherals and features. In addition, it offers generous memory availability for both Flash and RAM. It is operated by a set of AT commands, over the UART interface, which makes the BLE 4 click very easy to use. By integrating most of the critical components on the chip, the NINA-B312 allows the module to overcome any imperfections of external discrete components, allowing signal transmission power of up to 10dBm, and -94 dBm sensitivity for the receiver, using the on-chip antenna. The NINA-B312 module is built around an ARM® Cortex™-M4 CPU with floating point unit running at 64 MHz. It has NFC-A Tag for use in simplified pairing and payment solutions, as well as numerous digital peripherals and interfaces such as PDM. Therefore, BLE 4 Click has the onboard 2-pin header, that can be used for connecting the optional NFC antenna. It is also fully multiprotocol capable with full protocol concurrency. It has protocol support for Bluetooth 5, Bluetooth mesh, and 2.4 GHz proprietary stacks. Besides the mikroBUS™ socket, BLE 4 click also features two onboard buttons T1 and T2. These buttons can be used for various purposes and user programmable. This Click Board™ also has an onboard user programmable RGB LED - LD2, which in combination with the mentioned buttons can be used for various purposes for basic user interaction without any external components required besides the BLE 4 click. This Click Board™ is designed to be operated only with 3.3V logic level. A proper logic voltage level conversion should be performed before the Click board™ is used with MCUs with logic levels of 5V. SPECIFICATIONS Type BT/BLE Applications Medical equipment and fitness applications, IoT devices, home automation, smart energy, etc. On-board modules NINA-B312, Stand-alone Bluetooth 5 low energy module by u-blox Key Features ARM® Cortex™-M4 CPU, integrated antenna, support for Bluetooth 5, Bluetooth mesh, ANT and 2.4 GHz proprietary stacks, onboard tacticle switches and RGB LED Interface GPIO,UART Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V PINOUT DIAGRAM This table shows how the pinout on BLE 4 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin Notes Data terminal ready DTR 1 AN PWM 16 DSR Data set ready Reset RST 2 RST INT 15 RTS UART request to send UART clear to send CTS 3 CS RX 14 TX UART Transmit NC 4 SCK TX 13 RX UART Receive NC 5 MISO SCL 12 NC NC 6 MOSI SDA 11 NC Power Supply 3.3V 7 3.3V 5V 10 NC Ground GND 8 GND GND 9 GND Ground ONBOARD SETTINGS AND INDICATORS Label Name Default Description LD1 PWR - Power LED Indicator LD2 STATUS - User programmable RGB LED Indicator T1,T2 - - User programmable tacticle switches J1 - - External NFC Antenna Connection Header SOFTWARE SUPPORT We provide a library for the BLE 4 Click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description The library covers all the necessary functions to control BLE 4 Click board. A library performs the communication with the NINA-B312-00B series Bluetooth® 5 low energy module via UART interface. Key functions:    void ble4_uartWrite( uint8_t *txData ) - UART write function. void ble4_setDeviceName( uint8_t *deviceName ) - Set device name setting function. uint8_t ble4_readByte() - Read Single Byte. Examples description The application is composed of three sections :  System Initialization - Initializes UART, sets AN and INT pin as input and RST, CS and PWM pin as output and start to write log.  Application Initialization - Initialization driver enables - UART, hardware reset BLE module, restores factory settings of the module, set device name, select data mode and start to send data.  Application Task - (code snippet) - This is an example which demonstrates the use of BLE 4 Click board. If 'READ' - repeatedly sends string "mikroE". If 'WRITE' - receives messages from NINA-B3 series Bluetooth® 5 low energy module and LOGs received message. Results are being sent to the Usart Terminal where you can track their changes.   void applicationTask()  {      char tmp;      uint8_t rdyFlag;        if ( moduleMode == _BLE4_READ_MODE )      {          rdyFlag = ble4_byteReady();            if ( 1 == rdyFlag )          {              tmp = ble4_readByte();              mikrobus_logWrite( &tmp, _LOG_BYTE );          }      }      else if ( moduleMode == _BLE4_WRITE_MODE )      {          for ( cnt = 0; cnt
MIKROE-3773 价格&库存
很抱歉,暂时无法提供与“MIKROE-3773”相匹配的价格&库存,您可以联系我们找货
MIKROE-3773
  • 1+351.36287
库存:8
