MIKROE-3791
MIKROE-3791
    MIKRO
    TFT BOARD 4 RESISTIVE
MIKROE-3791 数据手册
        TFT BOARD 4 RESISTIVE TFT Board 4 Resistive is a 4.3" display board which features the standardized 2x20-pin display connector. The display board also integrates a resistive touch panel. The TFT display module supports up to 24-bit pixel format (RGB: 888) and resolution of 480 x 272 pixels. It features an excellent contrast ratio and uniform brightness. TFT Board 4 Resistive, along with other displays from the TFT Board Resistive line of products, is supported by VisualTFT, a software tool for simplified development of visually oriented embedded applications. PID: MIKROE-3791 Weight: 132 g Display size Resolution Graphic controller Touch Screen Active area (mm) 4.3" 480x272px SSD1963 Resistive 95.04 x 53.86   https://www.mikroe.com/tft‐board‐4‐resistive/11‐8‐19
MIKROE-3791
在提供的PDF文档中,关于“物料型号”的相关信息如下:
- 产品ID(PID):MIKROE-3791 - 重量:132g
此外,文档还提供了关于4.3英寸TFT Board 4 Resistive的详细信息,包括显示尺寸、分辨率、图形控制器、触摸屏类型以及活动区域尺寸。
图形控制器使用的是SSD1963芯片,支持24位像素格式(RGB: 888),分辨率为480x272像素,具有优秀的对比度和均匀的亮度。
若需要更详细的器件简介引脚分配参数特性功能详解应用信息封装信息,请提供具体查询的指令或关键词,以便进行更深入的检索和分析。
MIKROE-3791 价格&库存
很抱歉,暂时无法提供与“MIKROE-3791”相匹配的价格&库存,您可以联系我们找货
