RS485 ISOLATOR 2 CLICK
PID: MIKROE-3863
Weight: 22 g
RS485 Isolator 2 Click features ADM2867E a 5.7 kV rms signal and power isolated full
duplex RS-485 transceiver. The device also features cable invert pins, allowing the user
to quickly correct reversed cable connection on A, B, Y, and Z bus pins while
maintaining receiver full receiver fail-safe performance. This full duplex device allows for
independent cable inversion of the driver and receiver for additional flexibility with high
speed 25 Mbps data rate.
RS485 Isolator 2 Click board™ is supported by a mikroSDK compliant library, which
includes functions that simplify software development. This Click board™ comes as a
fully tested product, ready to be used on a system equipped with the mikroBUS™
socket.
HOW DOES IT WORK?
The RS485 Isolator 2 Click is based on ADM2867E from Analog Devices. It includes a
flexible integrated dc-to-dc converter optimized for low radiated emissions (EMI). The
isolated dc-to-dc converter is constructed of a set of chip scale coplanar coils that are
separated by an insulating material. By exciting the upper coil with an ac signal, power
is magnetically coupled across the isolation barrier where it is rectified and regulated.
Because no direct electrical connection exists between the top and bottom coil, the
primary and secondary side of the device remain galvanically isolated.
The integrated dc-to-dc converter is optimized to minimize radiated electromagnetic
interference (EMI), and allows designers to meet the CISPR22/EN55022 Class B
requirements on a 2-layer PCB.
The ADM2867E features a proprietary transmitter architecture with a low driver output
impedance, resulting in an increased differential output voltage. This architecture is
particularly useful when operating the device at lower data rates over long cable runs,
where the dc resistance of the transmission line dominates signal attenuation. In these
applications, the increased differential voltage extends the reach of the device to longer
cable lengths.
The RS485 Isolator 2 features separate digital logic pins, IND and INR, to correct cases
where the driver and/or receiver are wired incorrectly. Use the IND pin to correct driver
functionality when Y and Z are wired incorrectly. Use the INR pin to correct receiver
functionality when A and B are wired incorrectly. When the receiver is inverted, the
device maintains a Logic 1 receiver output with a 30 mV noise margin when inputs are
shorted together or open circuit.
The standard RS-485 receiver input impedance is 12 kΩ (1 unit load), and the standard
driver can drive up to 32 unit loads. The ADM2867E transceiver has a 1/6 unit load
receiver input impedance (72 kΩ), allowing up to 196 transceivers to be connected in
parallel on one communication line. Any combination of these devices and other RS485 transceivers with a total of 32 unit loads or fewer can be connected to the line.
The integrated isoPower isolated dc-to-dc converter requires up to 10 ms to power up to
its set point of 3.3 V or 5 V. During this start-up time, it is not recommended to assert
the DE driver enable signal.
The RS485 Isolator 2 Click board™ can be supplied and interfaced with both 3.3V and
5V without the need for any external components. The onboard SMD jumper labeled as
VCC SEL allows voltage selection for interfacing with both 3.3V and 5V MCUs.
SPECIFICATIONS
Type
RS485,Isolators
Applications
Heating, ventilation, and air-conditioning (HVAC) networks,
Industrial field buses, Building automation, Utility networks
On-board
modules
ADM2867E Power Isolated RS-485 Transceiver from Analog
Devices
Key Features
5.7 kV rms isolated full duplex RS-485/RS-422 transceiver, Cable
invert smart feature, High speed 25 Mbps data rate, Supports 196
bus nodes, Full hot swap support
Interface
GPIO,UART
Compatibility
mikroBUS
Click board
size
L (57.15 x 25.4 mm)
Input Voltage
3.3V or 5V
PINOUT DIAGRAM
This table shows how the pinout on RS485 Isolator 2 Click corresponds to the pinout on
the mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
NC
1
AN
PWM
16
INR
Receiver Inversion
Receiver Enable
RE
2
RST
INT
15
IND
Driver Inversion
Driver Enable
DE
3
CS
RX
14
TX
UART Transmit
NC
4
SCK
TX
13
RX
UART Receive
NC
5
MISO
SCL
12
NC
NC
6
MOSI
SDA
11
NC
Power Supply
3.3V
7
3.3V
5V
10
5V
Ground
GND
8
GND
GND
9
GND
Power supply
Ground
ONBOARD SETTINGS AND INDICATORS
Label
Name
Default
Description
PWR
LED GREEN
Power LED Indicator
RX/TX
LD2
RX/TX LED indicator
JP1
VCC SEL
Left
JP2
DE
Not
Populated
Single pin driver/receiver enable
J3
RE(U1)
Populated
Independent driver/receiver enable/disable
Power supply voltage selection: left position
3V3, right position 5V
J4
Open
A pin bias
J6
Open
B pin bias
J7, J8
Open
Half duplex
J5, J9
Open
Termination selection
SOFTWARE SUPPORT
We provide a library for the RS485 Isolator 2 Click on our LibStock page, as well as a
demo application (example), developed using MikroElektronika compilers. The demo
can run on all the main MikroElektronika development boards.
Library Description
Initializes and defines UART bus driver, and defines drivers for reading, writing and
check for new data between RS485 Isolator 2 clicks. User can also enable or disable
both transmiter and receiver, and to invert receiving or transmitting data.
Key functions:
void rs485isolator2_write_byte ( uint8_t input ) - Writes single byte.
uint8_t rs485isolator2_read_byte( ) - Read received byte.
uint8_t rs485isolator2_byte_ready ( ) - Checks is there a new byte received.
Examples description
The application is composed of three sections :
System Initialization - Initializes UART module and sets RST, CS, PWM and INT pins as an output.
Application Initialization - Initalizes UART driver and makes an initial log.
Application Task - (code snippet) This example covers two cases. First case (receiver mode):
checks for new data and, if available, reads one byte from rx buffer. Second case (transmiter mode):
writes message via UART. An example is setup for noninverted data transmision and receiving.
void application_task ( )
char tmp;
uint8_t drdy_flag;
if ( app_mode == APP_MODE_RECEIVER )
// RECEIVER ‐ UART polling
rs485isolator2_re_state( RS485ISOLATOR2_ENABLE_RE );
drdy_flag = rs485isolator2_byte_ready( );
if ( 1 == drdy_flag )
tmp = rs485isolator2_read_byte( );
mikrobus_logWrite( &tmp, _LOG_BYTE );
rs485isolator2_re_state( RS485ISOLATOR2_DISABLE_RE );
else
// TRANSMITER ‐ TX each 2 sec
rs485isolator2_de_state( RS485ISOLATOR2_ENABLE_DE );
for ( tmp = 0; tmp
很抱歉,暂时无法提供与“MIKROE-3863”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+419.277931+54.24000
- 国内价格 香港价格
- 1+423.554701+54.79327
