MIKROE-3870
MIKROE-3870
    MIKRO
    TLE7268SKXUMA1 LIN 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3870 数据手册
        DUAL LIN CLICK PID: MIKROE-3870 Weight: 19 g The Dual LIN click is a Click board™ based on the TLE7268SKXUMA1, a Dual LIN transceiver from Infineon. Given the features included in this transceiver, the Dual LIN transceiver designed for data transmission rates up to 20 kbps being fully compliant to the ISO17987-4, LIN specification 2.2A and SAE J2602 standards. The Dual LIN click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. HOW DOES IT WORK? The Dual LIN click is a dual transceiver for the Local Interconnect Network (LIN) with integrated wake-up and protection features. The Dual LIN click is designed for in-vehicle networks using data transmission rates up to 20 kbps. This Click board™ contains the TLE7268SKXUMA1 from Infineon, Dual LIN click includes two independent transceivers that operate as bus drivers between the protocol controller and physical LIN networks. The Dual LIN click communicates with the MCU by using the UART RX and TX signals. RX and TX signals are also routed to the header on the edge of the click board™ so they can be used independently of the mikroBUS™ socket. Its most important features are the fact that it is a two separate single-wire LIN transceiver bus for transmission rates up to 20 kbps and it is compliant to ISO 17987-4 and LIN Specification 2.2A. The EN1 and EN2 pins are used to enable the functionality of BUS 1 or BUS 2 of the device. When the EN1 pin is set to a HIGH logic level, the BUS 1 of the device is set to work in the normal mode, with the transmission paths from TXD to LIN and from LIN to RXD both active. When the EN2 pin is set to a HIGH logic level, the BUS 2 of the device is set to work in the normal mode, with the transmission paths from TXD to LIN and from LIN to RXD both active. When the EN1 pin is set to a LOW state, the BUS 1 of the device is put into silent mode, depending on the TX pin state. The EN1 pin has a pull-down resistor, so it is pulled to Ground if it is left afloat. When the EN2 pin is set to a LOW state, the BUS 2 of the device is put into silent mode, depending on the TX pin state. The EN2 pin has a pull-down resistor, so it is pulled to Ground if it is left afloat. The Dual LIN click supports different modes of operation of the two transceivers for minimizing ECU current consumption in low power modes, a common INH output can be used for controlling external circuitry, for example voltage regulators. Based on the Infineon BiCMOS technology. It provides excellent ESD robustness together with very high electromagnetic compliance (EMC). The TLE7268SKXUMA1 reaches a very low level of electromagnetic emission (EME) within a broad frequency range and independent from the battery voltage. The TLE7268SKXUMA1 is AEC qualified and tailored to withstand the harsh conditions of the automotive environment. Some of the key features that are incorporated in the TLE7268SKXUMA1 are overtemperature protection, undervoltage detection. The Dual LIN click is digital I/O levels compatible with 3.3 V and 5 V microcontrollers, that it is optimized for high electromagnetic compliance (EMC) with very low electromagnetic emission and high immunity to interference. It also features two independent single-wire LIN transceivers in one device and gives out a transmission rate of up to 20 kbps. Given the features included in this transceiver, the Dual LIN click can be used for Body Control Modules (BCM) and Gateway. SPECIFICATIONS Type LIN Applications Automotive applications: Body control modules (BCM) and Gateway On-board modules TLE7268SKXUMA1, a Dual LIN transceiver from Infineon Key Features Two independent single-wire LIN transceivers in one device, transmission rate up to 20 kbps, very low electromagnetic emission, High immunity to interference Interface GPIO,UART Compatibility mikroBUS Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V PINOUT DIAGRAM This table shows how the pinout on Dual LIN click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin Notes NC 1 AN PWM 16 NC Output Enable EN1 2 RST INT 15 NC Output Enable EN2 3 CS RX 14 TX UART Transmit NC 4 SCK TX 13 RX UART Receive NC 5 MISO SCL 12 NC NC 6 MOSI SDA 11 NC Power Supply 3.3V 7 3.3V 5V 10 5V Ground GND 8 GND GND 9 GND Power Supply Ground ONBOARD SETTINGS AND INDICATORS Label Name Default Description LD1 PWR - Power LED Indicator TB1 BUS 1 - Terminal block for connecting LIN BUS 1 TB2 BUS 2 - Terminal block for connecting LIN BUS 2 TB2 VS - TB2 VCC SEL Left Terminal block for connecting LIN bus power supply voltage Power supply voltage selection: left position 3.3V, right position 5V DUAL LIN CLICK ELECTRICAL SPECIFICATIONS Description LIN bus supply voltage Min Typ Max Unit 5 - 40 V SOFTWARE SUPPORT We provide a library for the Dual LIN Click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description The library includes functions to write or read data from UART. You can set state of pins (RST - BUS1, CS - BUS2) you want to change it, and get state of pin(INT - INH). Key functions:     void duallin_write_byte ( uint8_t input ) - Write single byte of data uint8_t duallin_read_byte ( void ) - Read single byte of data uint8_t duallin_byte_ready ( void ) - Check for new byte received uint8_t duallin_bus1_status ( uint8_t state ) - Sets state of bus1 pin Examples description The application is composed of three sections :  System Initialization - Intializes UART module  Application Initialization - Driver intialization  Application Task - Choose one mode (read or write) of task. If you reading it checks if data is ready to be read and then reads one byte and if you are wiriting send data via UART. void applicationTask(  )  {      uint8_t tmp;      char rec;      uint8_t rdyFlag;      uint8_t mode = DUALLIN_WRITE_MODE;        if ( mode == DUALLIN_READ_MODE )      {          // RECEIVER ‐ UART polling          rdyFlag = duallin_byte_ready(  );            if ( DUALLIN_DATA_READY == rdyFlag )          {              rec = duallin_read_byte(  );              mikrobus_logWrite( &rec, _LOG_BYTE );          }      }      else if ( mode == DUALLIN_WRITE_MODE )      {          // TRANSMITER ‐ TX each 2 sec          for ( tmp = 0; tmp
MIKROE-3870
物料型号: - TLE7268SKXUMA1
器件简介: - Dual LIN click是一个基于TLE7268SKXUMA1的Click板,该收发器设计用于数据传输速率高达20 kbps,完全符合ISO17987-4和LIN规范2.2A。 - 该Click板包含两个独立的单线LIN收发器,支持高达20 kbps的传输速率,并且符合ISO 17987-4和LIN规范2.2A。
引脚分配: - EN1和EN2引脚用于启用设备的BUS 1或BUS 2的功能。 - 3.3V和5V引脚提供电源,GND为接地点。
参数特性: - LIN总线供电电压:5V至40V - 支持的输入电压:3.3V或5V - 该设备具有过温保护和欠压检测功能。
功能详解: - Dual LIN click通过使用UART RX和TX信号与MCU通信。 - EN1和EN2引脚设置为高电平时,BUS 1或BUS 2进入正常模式。 - EN1和EN2引脚设置为低电平时,BUS 1或BUS 2进入静音模式。
应用信息: - 适用于汽车应用:车身控制模块(BCM)和网关。 - 该Click板支持不同模式的两个收发器,以最小化低功耗模式下的ECU电流消耗。
封装信息: - Click板尺寸:M(42.9 x 25.4 mm) - 该Click板包含电源指示灯和用于连接LIN总线1和LIN总线2的端子块。
软件支持: - 提供了与Dual LIN Click相关的库和演示应用程序(示例),使用MikroElektronika编译器开发。 - 库描述:包括写入或从UART读取数据的函数。 - 示例描述:应用程序由三个部分组成:系统初始化、应用程序初始化和应用程序任务。
MIKROE-3870 价格&库存
很抱歉,暂时无法提供与“MIKROE-3870”相匹配的价格&库存,您可以联系我们找货
MIKROE-3870
  • 1+104.90900
  • 5+102.80540
库存:12
MIKROE-3870
  • 1+123.276721+15.99506
库存:14
