MIKROE-3880
MIKROE-3880
    MIKRO
    MC33702A,VOM452 仪表总线(M 总线) 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3880 数据手册
          M-BUS MASTER CLICK PID: MIKROE-3880 Weight: 20 g The M‐Bus Master is a Click board™ is complete solution for a master node in M-Bus networks. The M-Bus ("Meter-Bus") is a new European standard for remote reading of heat meters and it is also usable for all other types of consumption meters as well as for various sensors and actuators. Given all the features these elements offer, the M-Bus Master click can be used for low cost applications, and low voltage, MCU based, single supply applications. The M-Bus Master click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. HOW DOES IT WORK? The remote reading of heat meters can take place in different ways. Besides the remote reading, the whole collection of various meters can be remotely controlled over M-Bus, making it a complete housing solution. The latter is a logical continuation/extension of the technical development of consumption meters and is realizable with the help of the M-Bus Click. In order to realize an extensive bus network with low cost for the transmission medium, a two-wire cable was used together with serial data transfer. In order to allow remote powering of the slaves, the bits on the bus are represented as follows:  The transfer of bits from master to slave is accomplished by means of voltage level shifts. A logical "1" (Mark) corresponds to a nominal voltage of +36 V at the output of the bus driver (repeater), which is a part of the master; when a logical "0" (Space) is sent, the repeater reduces the bus voltage by 12 V to a nominal +24 V at its output.  Bits sent in the direction from slave to master are coded by modulating the current consumption of the slave. A logical "1" is represented by a constant (versus voltage, temperature and time) current of up to 1.5 mA, and a logical "0" (Space) by an increased current drain requirement by the slave of additional 11-20 mA. The mark state current can be used to power the interface and possibly the meter or sensor itself. As mentioned above, M-Bus standard has predefined voltage levels and principle of work. In order to achieve that, M-Bus Master click has built in complete solution for master node on the network, based on MC33072ADR2G – monolithic, single supply 3 44 V operational amplifier from ON Semiconductor. Besides the operational amplifier, this click board has all other needed components needed to achieve a complete analog solution which, on its output, fulfils the M-Bus voltage and current predefined specifications. This Click board™ also has VOM452 onboard – the analog, high hpeed, high noise immunity, 1 MBd optocoupler, from Vishay Semiconductors. Theese high speed optocouplers, each consists of a GaAlAs infrared emitting diode, optically coupled with an integrated photo detector and a high speed transistor. The photo detector is junction isolated from the transistor to reduce miller capacitance effects. The open collector output function allows circuit designers to adjust the load conditions when interfacing with different logic systems such as TTL, CMOS, etc. All these features improve the reliability of the whole circuit, while enabling the galvanic isolation. M-Bus Master click offers a selection between 3.3V and 5V operation, with the onboard SMD jumper, labeled as PWR SEL. This allows both 3.3V and 5V MCUs to be interfaced with this Click board™. SPECIFICATIONS Type RS232 Applications Remote sensor reading, remote control over M-Bus, smart house On-board modules MC33072ADR2G, a monolithic operational amplifier from ON Semiconductor Key Features Galvanicaly isolated, Master node Interface UART Compatibility mikroBUS Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V PINOUT DIAGRAM This table shows how the pinout on the M-Bus Master click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes Pin Pin Notes NC 1 AN PWM 16 NC NC 2 RST INT 15 NC NC 3 CS RX 14 TX UART TX NC 4 SCK TX 13 RX UART RX NC 5 MISO SCL 12 NC NC 6 MOSI SDA 11 NC Power Supply 3.3V 7 3.3V 5V 10 5V Ground GND 8 GND GND 9 GND Power Supply Ground ONBOARD SETTINGS AND INDICATORS Label Name Default LD1 PWR - JP1 VCC SEL Left Description Power LED Indicator Power supply voltage selection: left position 3.3V, right position 5V SOFTWARE SUPPORT We provide a library for the M-Bus Master Click on our LibStock page, as well as a demo application (example), developed using MikroElektronika compilers. The demo can run on all the main MikroElektronika development boards. Library Description Initializes and defines UART bus driver, and defines driver's functions for writing data on the M-BUS terminal. Key functions:  void mbusmaster_write_byte ( uint8_t input ) - Write one byte data Examples description The application is composed of three sections :  System Initialization - Initializes UART module  Application Initialization - Initializes driver init  Application Task - Sends a message [MikroE] to the M-BUS connector every 2 seconds. void application_task ( )  {      char tmp;        for ( tmp = 0; tmp
MIKROE-3880 价格&库存
很抱歉,暂时无法提供与“MIKROE-3880”相匹配的价格&库存,您可以联系我们找货
MIKROE-3880
    • 1+155.21825
    • 5+152.11492
    库存:13
    MIKROE-3880
    • 1+157.822101+20.24240
    库存:29
    MIKROE-3880
    • 1+157.773271+20.23612
