LTE CAT.1-US CLICK (FOR UNITED STATES)
PID: MIKROE-3885
Weight: 26 g
LTE Cat.1‐US click is a Click board™ based on Thales Cinterion® ELS61 wireless
module that delivers highly efficient Cat 1 LTE connectivity for M2M IoT solutions
offering seamless fall back to 2G and 3G networks. The best in class solution enables
M2M optimized speeds of 10Mbit/s download and 5Mbit/s uplink making it ideal for the
vast number of M2M and industrial IoT applications that are not dependent on speed
but that requires the longevity of LTE networks, while still providing 3G and 2G
connectivity to ensure complete population and geographic coverage as LTE rolls out.
The LTE Cat.1-US click is supported by a mikroSDK compliant library, which includes
functions that simplify software development. This Click board™ comes as a fully tested
product, ready to be used on a system equipped with the mikroBUS™ socket.
HOW DOES IT WORK?
LTE Cat.1-US click is equipped with the ELS61 wireless module from Thales. There are
two click boards to cover two different regions: LTE Cat.1-EU click for the Europe
region, which features the ELS61-E module, and the LTE Cat.1-US click for the North
American region, which features ELS61-US module. The main difference between
these two modules are the supported frequency bands, compliant with the regulations
for each region. A complete list of supported bands for each module, along with other
relevant info about the module itself, can be found in the ELS61 series modem
datasheet.
The Cinterion ELS61 module that is featured on LTE Cat.1-US click comes with a
Java® embedded virtual machine leveraging a powerful ARM11 architecture which
allows device manufacturers to utilize the massive to reduce complexity and speed
application integration. The latest Java ME 3.2 client runtime platform reduces total cost
of ownership (TCO) and time to market by sharing internal resources such as memory,
a large existing code base and proven software building blocks. The module uses Multi
MIDlet Java execution to simultaneously host and run multiple applications and
protocols.
The UART bus of the ELS61 series module is connected to one side of the level shifter,
while the other side (shifted) is connected to the respective mikroBUS™ UART pins.
However, the ELS61 series module is designed as the traditional DCE device (Data
Communication Equipment) offering the full UART pin count, including the hardware
flow control pins (CTS, RTS). These pins are routed to the mikroBUS™ CS (RTS) and
the INT pin (CTS) and can be used in the MCU software if the hardware flow control is
needed.
An extended security concept with the latest TLS/SSL engine provides secure and
reliable TCP/IP connectivity. Its sophisticated sandbox modeling and layered
architectures simplify device management and allow simultaneous progress of network
operator approvals and application code development for a shorter time to market.
Cinterion LTE Cat.1 modules deliver long product lifespans up to seven years, efficient
bandwidth and power utilization plus a feature set that meets the rigorous requirements
of M2M IoT solutions including extended operating temperatures from -40°C to 85°C.
The LTE Cat.1-US click ensures easy integration and a fast time to market for
innovative solutions, and it also provides a dependable connectivity platform with the
support needed for a fast time to market and a value you can trust.
Given all the possibilities these features offer, the LTE Cat.1-US click can be used for
various applications such as metering, tracking and tracing, remote surveillance,
connected signs, fleet management and mHealth.
SPECIFICATIONS
Type
GSM/LTE
Applications
Metering, tracking and tracing, remote surveillance, connected
On-board
modules
Cinterion® ELS61 Wireless Module from Gemalto
Radio Region
America
Key Features
Data rates of up to 10.2 Mb/s for download and up to 5.2 Mb/s for
upload, real time clock with alarm functionality
Interface
I2C,USB,SPI,GPIO
Click board
size
L (57.15 x 25.4 mm)
Input Voltage
3.3V,5V
PINOUT DIAGRAM
This table shows how the pinout on LTE Cat.1-US click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
NC
1
AN
PWM
16
CS
RST
2
RST
INT
15
RTS
Request to send
CS
3
CS
RX
14
TX
UART Transmit
SPI Clock
SCK
4
SCK
TX
13
RX
UART Receive
SPI Slave Data OUT
SDO
5
MISO
SCL
12
SDA
I2C Clock
SPI Slave Data IN
SDI
6
MOSI
SDA
11
SDA
I2C Data
Power Supply
3.3V
7
3.3V
5V
10
5V
Ground
GND
8
GND
GND
9
GND
Reset
Clear to send
Chip select
Power supply
Ground
ONBOARD SETTINGS AND INDICATORS
Label
Name
Default
Description
LD1
PWR
Power LED Indicator
LD2
PWI
Power indication LED
LD3
STAT
Status LED
J1
J1
Disabled
CS Enable/Disable Jumper
J2
J2
Disabled
SCK Enable/Disable Jumper
J3
J3
Disabled
MISO Enable/Disable Jumper
J4
J4
Disabled
MOSI Enable/Disable Jumper
J5
J5
Disabled
SCL Enable/Disable Jumper
J6
J6
Disabled
SDA Enable/Disable Jumper
Note: Pins for SPI and I2C are not connected by default on mikroBUS™ since module is
always acting as master which is not allowed for Click board™, but can be enabled by
adding 0 ohm resistors to jumpers from J1 to J6 on the back side.
SOFTWARE SUPPORT
We provide a library for the LTE Cat.1 Click on our LibStock page, as well as a demo
application (example), developed using MikroElektronika compilers. The demo can run
on all the main MikroElektronika development boards.
Library Description
The library covers all the necessary functions to control LTE Cat.1 click board. Library
carries generic command parser adopted for AT command based modules.
Key functions:
void ltecat1_cmd_single ( uint8_t *p_cmd ) - Sends provided command to the module function.
uint16_t ltecat1_set_handler( uint8_t *p_cmd, uint32_t timeout, ltecat1_handler_t
p_handler ) - Handler assignation to the provied command function.
void ltecat1_module_power ( uint8_t power_state ) - Enables or disables module power
function.
Examples description
The application is composed of three sections :
System Initialization - Initializes all necessary GPIO pins, UART used for the communcation with
GSM module and UART used for infromation logging
Application Initialization - Initializes driver, power on module and sends few command for the default
module configuration
Application Task - running in parallel core state machine and checks for call flag. If call detected
parser will hang up call.
void application_task ( )
char rsp_com[ 50 ] = {0};
// GSM
// CORE STATE MACHINE
ltecat1_process( );
if (0 != call_flag)
ltecat1_cmd_single(
很抱歉,暂时无法提供与“MIKROE-3885”相匹配的价格&库存,您可以联系我们找货
