MIKROE-3932
MIKROE-3932
    MIKRO
    mikroBUS Click 至 LPCXpresso 连接性 LPCXpresso™ 平台评估扩展板
MIKROE-3932 数据手册
    LPCXpresso Click Shield Expand functionalities of your boards Xpressly PID: MIKROE-3932 Weight: 25 g LCPXpresso Click Shield designed to support multiple NXP development platforms which use Arduino connector and equip them with two mikroBUS sockets. Start your development with ease on LPCXpresso platform and get immediate access to hundreds of Click boards in our offer.   OVERVIEW LPCXpresso is the development platform pioneered by NXP® and Embedded Artists. It includes low-cost LPCXpresso target boards which are designed for simple, rapid prototyping and evaluation. LPCXpresso development boards work with the MCU Xpresso or industry-leading partner toolchains and they are equipped with the Arduino expansion socket. LPCXpresso Click Shield is the perfect way to expand the functionalities of your LPCXpresso development boards with Arduino socket to 2 mikroBUS™ sockets and add any functionality from our ever-growing range of Click boards™. We are fully stocked with everything from sensors and WiFi transceivers to motor control and audio amplifiers.You name it we have it! This amount of Click boards gives you a versatile selection of peripheral devices that can be taken off the shelf and used for prototyping in no time. Note: LPCXpresso development board is not included in the package. MAIN FEATURES LCPXpresso Click Shield designed to support multiple NXP platforms which use Arduino connector and equip them with two mikroBUS sockets. This shield is specially designed with high attention to specific of the LPCXpresso pinout, which is slightly distinguishable from the classic Arduino pinout. For this we have provided additional switches which allows you to select digital I/O on the interrupt pins (INT0/INT1). On this board beside Arduino male and mikroBUS female sockets you have also:    1. PROG/UART Switch for enabling or disabling UART pins 2. SW1/SW2 for setting INT1/INT2 to desired LPCXpresso I/O pins 3. PWR LED for the board POWER indication Note: You should avoid adding Click boards with 5V logic output since this boards potentially can damage LPCXpresso base-board input pins. FEATHER TO MIKROBUS PINOUT SPECIFICATION TABLE   Type Shield,Adapter Applications IoT applications with LPCXpresso boards which require additional peripheral devices On‐board modules Arduino connector for connecting compatible Arduino boards or LPCXpresso boards with slightly different pinout, power part for converting 5V USB to the 3.3V Interface I2C,Analog,GPIO,UART,PWM,SPI Compatibility Arduino,mikroBUS GALLERY https://www.mikroe.com/lpcxpresso‐click‐shield/1‐28‐20
MIKROE-3932
PDF文档中的物料型号为:TI公司的LMR33630,是一款同步降压DC/DC转换器。
器件简介显示,LMR33630具有高达95%的效率,支持高达4.5A的输出电流,适用于多种应用场景。
引脚分配详细列出了各个引脚的功能,包括电源、地、使能、输出电压等。
参数特性包括输入电压范围、输出电压范围、最大输出电流等。
功能详解部分深入介绍了LMR33630的工作原理和特性,如同步降压转换、可编程软启动等。
应用信息说明了LMR33630适用于需要高效率和高电流输出的场合,如智能手机、平板电脑等。
封装信息指出,LMR33630采用QFN封装,具有较小的占用空间和良好的散热性能。
MIKROE-3932 价格&库存
很抱歉,暂时无法提供与“MIKROE-3932”相匹配的价格&库存,您可以联系我们找货
MIKROE-3932
    MIKROE-3932
    • 1+234.256281+30.44220
