MIKROE-1120
MIKROE-1120
    MIKRO
    BATTERY LITHIUM 3.7V 2AH
MIKROE-1120 数据手册
Type:SR674361P REV:1.0 Date:2013-3-8 Specification Approval Sheet Mikroe Customer : Model : SR674361P Type : Li-polymer battery Specification: 3.7V/2000mAh signed by client Confirmed Checked Approved signed by manufacturer Prepared : He lu Checked : Approved : Li Jin Yong Page 1/ 12 Type:SR674361P REV:1.0 Date:2013-3-8 Content 1. Battery type and scope ------------------------------------------------------------------3 2. Basic characteristic and components of battery------------------------------------3 2.1: Basic performance parameter of battery -------------------------------------3 2.2: Main components and parts -----------------------------------------------------4 2.3: Reliable performance test --------------------------------------------------------4 2.4: Dimension ----------------------------------------------------------------------------7 3. Specification of parts ----------------------------------------------------------------------8 3.1:PCB--------------------------------------------------------------------------------------8 3.1.1:General electric characteristic--------------------------------------------------8 3.2:Electric schematic diagram --------------------------------------------------------9 3.3: Specification of battery cell ------------------------------------------------------10 4. Attentions ------------------------------------------------------------------------------------11 Page 2/ 12 Type:SR674361P REV:1.0 Date:2013-3-8 1. Battery type and scope This Specification Approval Sheet is for rechargeable Li-polymer battery provided by Shirui Battery Co., LTD. 1.1 model:SR674361P 1.2 scope: 2. .Basic characteristic and components of the battery 2.1 Basic performance parameter S/N 1 2 Details Parameters Rated voltage 3.7V Rated capacity 2000mAh 4 Limited charge voltage Internal resistance 4.2V ≤160mΩ 5 charge mode C.C/C.V. 6 Charge time 6H 7 Max Charge Current 2000mA 8 Max discharge current Continuous: 2000mA 3 Remarks discharge with 0.2C to 2.75V after fully charge within 1h, measuring the discharge time Standard charging 0.2C 400mA charging 0~45℃ discharging -10~60℃ 1 Month -10~35℃ Charge to 40%~50% of 10 Storage temperature capacity when storage 6 months -10~30℃ 11 Storage humidity ≤75% relative humidity 12 Weight Approx.45g Touch discharge ≥ 20000V 13 ESD ability Air discharge≥20000V 14 Cycle life 300 times capacity≥80% Note:If you need the battery protection parameters, please refer to PAGE 8. 9 Working temperature Page 3/ 12 Type:SR674361P REV:1.0 Date:2013-3-8 2.2 Main components and parts Materials Li-Polymer battery cell Protection board Wire Model Quantity SR674361P 1PCS 674361 1PCS JST-XHP-2 UL1007AWG24 Length 50mm 1PCS Related technical parameters Please refer to the battery cell specification Manufacturer / 2.3 Reliable performance test S/N 1 Inspection item High temperature Standard No deformation, no rust, no fire or explosion; Discharge time ≥100mins with 0.5C5A discharge No deformation, no rust, no fire or explosion; Discharge time ≥ 3 hours with 0.2C5A discharge at -20±2℃ 2 Low temperature No deformation, no rust, no fire or explosion; Discharge time ≥ 3.5 hours with 0.2C5A discharge at -10±2℃ 3 Capability Retention Discharge time ≥ 4.25h Page 4/ 12 Testing Method Place the battery in the environment of 55±2℃ for 2 hours after fully charge, then discharge with 0.5C5A to cut-off voltage. After fully charge, place the battery in the environment of -20±2℃ for 16-24h, then discharge with 0.2C5A to cut-off voltage. Then display the battery in 20±5℃ for 2 hours, observe the appearance of the battery. After fully charge, place the battery in the environment of -10±2℃ for 16-24h, then discharge with 0.2C5A to cut-off voltage. Then display the battery in 20±5℃ for 2 hours, observe the appearance of the battery. After fully charged, store the battery at 20±5℃ for 28 days, then discharge with 0.2C5A to cut-off voltage. Type:SR674361P REV:1.0 Date:2013-3-8 4 No deformation, no rust, no smoke Constant humidity or explosion. and heat Discharge time ≥ 36 mins 5 No deformation, no rust, no smoke or explosion. Battery voltage ≥ 3.6V 6 No deformation, no smoke or explosion. Battery voltage ≥ 3.6V Vibration 7 8 9 10 Shock Free Drop Overcharge Protection Over-discharge Protection Short-circuit Protection No leakage, no explosion, but deformation. Discharge time ≥ 0.5C5A discharge smoke or a slight 100mins at No explosion, no fire, no smoke or leakage No explosion, no fire, no smoke or leakage. No explosion, no fire, no smoke or leakage; Batteries voltage is not less than N*3.6V after instantaneous charge. Page 5/ 12 After fully charge, place the battery in the environment of 40±2℃ and 90% - 95% Relative humidity for 48 hours, then place it in 20±5℃ for 2 hours, later, discharge with 1C5A to cut-off voltage. Batteries are vibrated 30 minutes in three mutually perpendicular directions of X, Y, Z with amplitude of 0.38mm (10~55Hz) and the scanning rage of 1oct per minute. Vibration test ended, place the battery in the directions of X.Y.Z three mutually perpendicular axis, and set pulse peak acceleration as 100m//s2. Then shock the battery with frequency of 40 ~ 80 per minute. The duration of pulse is 16ms, Shock times: 2000 ± 10. After shock test, the batteries are dropped on the 18-20mm hardwood on the concrete floor from 2000mm height as per positive and negative 6 direction of X, Y, Z. Each direction should drop one time. After test, batteries can be charged and discharged for at least three cycles. After fully charged, continue to charge the battery for 8 hours with C.C/C.V source. The constant voltage source sets to 2 times nominal voltage and constant current sets 2 C5A. At 20±5℃, discharge the battery discharge with 0.2C5A to cut-off voltage. Then, continuously discharge the battery with a 30Ω load resistance for 24 hours. After fully charge, short-circuit positive and negative electrode with 0.1Ω for 1 hour. Cut-off positive and negative electrode, then charge the battery at 0.5C5A instantaneously for 5S. Type:SR674361P REV:1.0 Date:2013-3-8 11 12 13 14 15 Thermal Shock No fire, No explosion Overcharge No fire, No explosion Short circuit No fire, No explosion. The out side temperature of the battery is less than 130℃. Nail No fire, No explosion Cycle life Cycle life ≥ 300 Page 6/ 12 Battery is heated in a circulating air oven at a rate of (5±2)℃ per minute to 130℃, and then placed for 30 minutes at 130℃. Place battery connected thermocouple in a ventilated cabinet, connect the positive and negative to CC/CV source, and adjust constant current to 3C5A, and constant voltage to N*10V. Charge the battery to N*10V and current to 0 A. Then monitor the changes of temperature. If the temperature of battery drops to about 10℃ lower than the max temperature, test is finished. Place battery connected thermocouple in a ventilated cabinet, short-circuit the positive and negative, then monitor the changes of temperature. If the temperature of battery drops to about 10℃ lower than the max temperature, test is finished. Put battery in the nail test platform. then, use a diameter 8 mm steel tip to poke through into hole. Finally, use a heavy hammer to blow the battery At 20±5℃,charge battery with 0.5 C5A to 4.2V and then charge it with constant voltage to the current less than 20mA. Stop charge and display for 0.5~1 hour. Then discharge it with 1 C5A to cut-off voltage. Display for 0.5 ~1 hour, do next charge and discharge cycle. Repeat these steps. Stop it until the continuous two cycle discharge time is less than 48 minutes. Type:SR674361P REV:1.0 Date:2013-3-8 16 Storage When it is stored for 3 month, fully charge it, then discharge it at 0.2 C5A, discharge time is not less than 4 hours. 2.4 Dimension of the Battery Page 7/ 12 The storage test of battery should be selected a battery which is less than 3 month from production date to the date of experiment. Before storage, battery capacity should be full charged 40%~50% capacity, the ambient temperature is 20℃±5℃ and relative humidity is 45%-85%. After the storage expiration of battery, battery should be charged and discharged according to fully charged and discharged. Type:SR674361P REV:1.0 Date:2013-3-8 3. Specifications of Parts 3.1: PCB: DW01/BMB101B02, 8205A 3.1. 1: General electric characteristic Model of Protection IC:DW01/BMB101B02 Items Specification Over-charging Protection Voltage 4.325V±0.1V Over-charging Return Voltage 4.1V±0.1V Over-discharge Protection Voltage Over-discharge Return Voltage Over-current Protection Output short-circuit Protection Voltage Detection Delay Time of Over-charging Protection Detection Delay Time of Over-discharging Protection Detection Delay Time of Over-current Protection Detection Delay Time of Output short-circuit Protection Internal Resistance of Proper Functioning 2.5V±0.1V 3.0V±0.1V 2-5A -1.2V~ -0.9V ≤1.5S(Typical) ≤144mS(Typical) ≤9mS(Typical) ≤320uS(Typical) ≤2000mΩ Consume Current ≤6.0uA Operating Temperature -20~70℃ Page 8/ 12 Remarks Type:SR674361P REV:1.0 Date:2013-3-8 3.2 Electric schematic diagram of battery 3.3 : Components of the Fender Lists No. 1 2 3 Name of the Position components Precision% Dosage Supplier Remarks 674361 Negative tolerance 1 R1 100Ω±5%/0402 ±5 1 470Ω R2 1KΩ±5%/0402 ±5 1 2KΩ PCB Internal Resistance Internal Resistance Specification Latten 4 Capacity C1 0.1μF/±10%/16V/0402 ±20 1 0.1uF 5 Protect IC U1 DW01/BMB101B02 / 1 SOT-23-6 6 MOS-FET U2 8205A / Page 9/ 12 1 Type:SR674361P REV:1.0 Date:2013-3-8 4 Specifications of the Cells NO. 1 Items Parameters Appearance No mechanical damage, leakage , sink ,drum and so on Length 2 Dimensions Width 4 5 6 7 Voltage Capacity Internal resistance 61.0mm 43.0mm Thickness 3 Tolerance 6.7mm / Max 61.0mm Max 43.0mm Max 6.7m m Term Remark/ condition 50cm distance under 40W daylight lamp Visual Digital caliper ≥3.80V / Multimeter ≥2000mAH / 0.2C ≤80mΩ / 1KHz Consistency Appearance quality is the same Security Correspond to related safety performance Page 10/ 12 VC9801 / Type:SR674361P REV:1.0 Date:2013-3-8 Attentions Danger To prevent battery from weeping, fever, exploding ,please obey the rules as follows: Do not immerse the battery into the water or the sea, Guard against Damp; Do not approach the heat source, like fire or heater; Please use the appointed charger when charging; Do not transposition the +.- poles of the battery to charge; Do not direct-connected the battery to alternating current power supply, or autoignition of the vehicle; Do not discard the battery to the fire or hyperpyretic objects; Do not use the conductor to lead the short circuit of the + -poles of the battery. Do not put the battery with metallic conductors to transport or store, like necklace, hairpin and so on; Do not beat or throw the battery; Do not impale the battery with needle or some other sharp things, do not strike it with weight; As installed safety device in the battery, please do not resolve or change any other sections of the battery to protect the inherent safety functions; Warnings Do not put the battery to the microwave oven or pressure tank; Do not use the battery with some chemical batteries (like dry battery) or different capacities and brands battery together, if the battery emits the smell, heat , changes color, be out of shape or appears any other abnormal phenomena during the charging or stored procedures, please get out the battery from the device or charger and stop using; If can not recharge within the charging period, please not continue charging; Put the battery to where the kids can not touch, if the kids swallow the battery , please seeing the doctor soon; If the electrolyte of the battery into the eyes, do not rub ,should wash the eyes first ,then see the doctor; Page 11/ 12 Type:SR674361P REV:1.0 Date:2013-3-8 Announcements Do not put the battery under the high temperature places (like sunshine irradiation or car in the hot weather), or it will catch fire for the heat , reduce the performance and loss the life; To insure the safety, the battery should install the safety device, please not use when the static electricity is more than we need when produce, or the safety device will lose efficacy and lead the overheating ,fracture, exploding and catching fire; Please use the battery in normal as follows, or it will be overheating, caught fire , reduced performance and shorten the life; Environment condition (Temperature) Charging: 0~+450C Discharging: -10~+600C Store within 30 days: -10~+350C Store within 90 days : -10~+300C If the kids use the battery, they should use as the operation instruction manual and guarantee that it must be use in normal at any time; . If the battery weeps, the electrolytes stick on the skin or cloth, use the water to wash or running water to wash To insure not install the battery wrong or wastage of the battery, please read the instruction carefully to install and dismounting; If the battery will not be used for a long time ,please take out of the battery from the device and store in dry and shady places; If there is sludge on the surface of the battery, please wipe up clean before using, or it will lead bad contact with the device. ! Special Notice Keep the cells in 50% charged state during long period storage. We recommend to charge the battery up to 50% of the total capacity every 3 months after receipt of the battery and maintain the voltage 3.7V~4.1V. And store the battery in cool and dry place. Page 12/ 12
MIKROE-1120 价格&库存
很抱歉,暂时无法提供与“MIKROE-1120”相匹配的价格&库存,您可以联系我们找货
