MAP-AM-265
MAP-AM-265
    NMBTECHNOLOGIESCORPORATION
    DC BRUSH MOTOR WITH MICRO AIR PU
MAP-AM-265 数据手册
MITSUMI Micro Air Pump Motor MAP-AM-265 DC Mini-Motors APPLICATIONS Blood Pressure monitor for Arm type SPECIFICATIONS Items Rated Voltage Voltage Range Specifications 6.0V 5.0~7.0V Pressing Time 11.5sec or less Time to add pressure from 0 to 300mmHg to a tank of 500cc by rated voltage (DC 6V). Current Consumption 430mA or less Maximum current during adding pressure from 0 to 300mmHg to a tank of 500cc by rated voltage(DC 6V). Leakage of Air 3.0mmHg/min or less Decrease of pressure at 30 second after stop pumping to a tank of 500cc up to 40±10mmHg and 300 ± 10mmHg. Maximum Pressure 400mmHg or more 55.0dB or less Noise Conditions Noise at 30cm from the pump. DIMENSIONS (67.1) 1.2 27 32.6 24.6 2−0.3 30.8 1.7 MITSUMI M mark − Terminal 2−2 18.3 6.5 24.4 3− 6.5 4.1 LABEL + Terminal 0.95 Unit : mm • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications.
MAP-AM-265 价格&库存
很抱歉,暂时无法提供与“MAP-AM-265”相匹配的价格&库存,您可以联系我们找货
