CAM-K24HR
HSD Connector 4+2 Vertical Reverse
MODEL NAME
CAM-K24HR
Part Number
R41-B296* (See Coding Chart on Pg. 2)
Description
Coding Direction
Normal
EXTERNAL DIMENSIONS
Height (mm)
14.15
Width (mm)
15.65
Depth (mm)
19.9
Outer Contact Length (mm)
2.25
2.3625
PACKING
Weight/Unit
4.05g
180 pcs/reel; 720 pcs (4 reels)/Carton
Reel
ELECTRICAL PERFORMANCE
Impedence
100Ω
Frequency
DC to 2 GHz
Return Loss
≥20 dB to 1 GHz; ≥17 dB to 2 GHz
H I G H S P E E D DATA C O M M U N I C AT I O N
Insertion Loss
≤0.1 dB to 2 GHz
Skew
≤5ps
Near-end Crosstalk
≤30 dB (1 GHz)
Far-end Crosstalk
≤35 dB (1 GHz)
Insulation Resistance
≥1x103 M Ω
Signal Contact Resistance
≤20 mΩ
Outer Contact Resistance
≤20 mΩ
Test Voltage
250Vrms
Working Voltage
100V rms
Power Current
Max. DC 5A
Signal Current
Max. DC 3A
Differential Shielding Effectiveness
≥75dB up to 1 GHZ; ≥65dB up to 2 GHZ
MECHANICAL PERFORMANCE
Mating Cycles
Engagement Force
≥25
很抱歉,暂时无法提供与“R41-B296H”相匹配的价格&库存,您可以联系我们找货
