R-666939
R-666939
    NMBTECHNOLOGIESCORPORATION
    侧面触动 触摸开关 SPST-NO 表面贴装,直角
R-666939 数据手册
ONLY FOR REFERENCE Mitsumi Model Name Mitsumi Model No. Operating Force/ Boss Pcs/Reel SOU-242HST R66 6939 1.6N / With 5 000 5,000 This specification is only for reference.  If you have any questions for the details, please contact SW engineering division. For your adopting the products, the formal supply specification will be provided.  2‐11‐2,Tsurumaki,Tama‐shi.Tokyo 206‐8657 Japan.  SWITCH ENGINEERING SECTION  1049,Tateiwa,Iizuka‐shi. Fukuoka 820‐8533 Japan. p4 e1 S0 . 5 02 ( 1 / 10 ) APPROVED CHECKED General Specification WRITTEN May.26.'08 May.26.'08 May.26.'08 SW SW SW Terashita Kawaguchi Kikuchi Side Click Type Tactile Switch SOU-242 Series Issued May. 26th, 2008 1. GENERAL SCOPE 1-1 THE SCOPE OF APPLICATION    This specification covers the general requirements of mechanical and electrical characteristics of    Side Click Type Tactile Switch mainly used as signal switch of electric devices. 1-2 TEST CONDITIONS    Tests and measurements shall be made in the following standard conditions unless otherwise specified. Normal temperature : 5 to 35oC Normal humidity: Relative humidity 45 to 85%    In case any question arises from the judgment made, tests shall be conducted the following conditions. Temperature : 20+/-2oC, Humidity: 65 +/- 5% 2. APPEARANCE AND CONSTRUCTION 2-1 Outer dimensions: Refer to the attached drawing. 2-2 Materials: As shown in Table-1.   2-3 Appearance: There should be no critical crack, scratch, dirt, discoloration and contamination which affect the functional characteristics of the switch. If these problems don't affect ff t th the characteristics, h t i ti th the switch it h can bbe jjudged d d as a good d one. * There may be rare occasions when any substance such as a white stain attaches to the top of cover, but this substance is a constituent of quick-drying grease which doesn't affect the performance of switch. 2-4 Cross section (1) Cover (2) Slider (3) Cover Tape (4) Switch Base (5) Spring (6) Terminal △5※The switch with boss type is shown     above as a typical drawing. Part Name Revision 3. RATING △10×2 △9×4 △8×1 SUS Nylon Polyimide Nylon φ2.4 mm, SUS Phosphor bronze Remarks t6 c O1 .0 1 22 (1) Cover (2) Slider (3) Cover Tape (4) Switch base (5) Spring (6) Terminal Table-1 Material Ni + Ag Ag 9 Maximum ratings 50mA, 12V D.C. (Resistive load) Oct.20th,'16 Change the bar code label to QR code label Nakashima Circuit symbol changed. The condition Jan.15th,'15 added to Operating Temperature range. Tsutsui PRECAUTIONS IN USE added. Mar.12th.'14 To 2-4 Addtion Product weight Fujisaki Code Product weight:23mg 8 ID No. File No. S 66 1385 MITSUMI ELECTRIC CO., LTD. 10 S-0115 ( 2 / 10 ) 4. ELECTRICAL CHARACTERISTICS Test conditions Items Criteria 4-1 Contact Applying a below static load to the center of the stem, measurement Refer to the attached drawing. Resistance shall be made. (1)Depression :1.5 to 2 times the operating force of the standard center value (2)Measuring method :To be measured with A.C. 1kHz +/- 200Hz (MAX. 20mV, 50mA) 4-2 Insulation Resistance Measurements shall be made following the test set force below: (1)Test voltage :100 V DC for 1min. (2)Applied position :Between all terminals,between terminal and cover. 10 M ohm min. 4-3 Withstanding Measurements shall be made following the test set force below Voltage (1)Test voltage :100V AC (50/60Hz) for 1min. (2)Leak current :2mA (3)Applied position :Between all terminals,between terminal and cover. There shall be no damage and breakdown. 4-4 Bouncing   ON bounce :10ms. Max. OFF bounce:10ms. Max. Lightly striking the center of the knob at a rate encountered in normal use (3 to 4 operations per sec.), bounce shall be tested at "ON" and "OFF". 9 SW DC5V "ON" 5kΩ Oscilloscope "OFF" t6 c O1 .0 1 22 File No. MITSUMI ELECTRIC CO., LTD. 1385 ( 3 / 10 ) 5. MECHANICAL CHARACTERISTICS Test conditions Items 5-1 Operating Placing the switch such that the direction of switch operation Force is vertical and then gradually increasing the load applied to the center of the stem, the maximum load required for the switch to come to a stop shall be measured. The measurement shall be made just after 10 times pushing. Criteria Refer to the attached drawing. 5-2 Return Force The sample switch is installed such that the direction of switch operation is vertical and, upon depression of the stem in its center the whole travel distance, the force of the stem to return to its free position shall be measured. The measurement shall be made just after 10 times pushing. Refer to the attached drawing. 5-3 Travel Placing the switch such that the direction of switch operation is vertical and then applying a static load to the center of the stem, the travel distance for the switch to come to a stop shall be measured. The measurement shall be made just after 10 times pushing. Refer to the attached drawing. 5-4 Stopper Strength Placing the switch such that the direction of switch operation is vertical and then a below static load shall be applied in the direction of stem operation. 1) Depression: 30 N 2) Time: 15s 3) Push stick shape: As shown below. 0.05mm There shall be no sign of damage mechanically and electrically. 2.5mm 1mm Measurements shall be made following the test set forth below. 1) Acceleration: 735m/s2 2) Acting time: 6 msec 3) Test direction: 6 directions 4) Cycles of test: 3 cycles per direction (18 cycles in total) There shall be no sign of damage mechanically and electrically. 5-6 Vibration Resistance Measurements shall be made following the test set forth below. 1) Range of oscillation: 10 to 55 Hz 2) Amplitude, pk-to-pk: 1.5 mm 3) Cycle of sweep: 10-55-10 Hz in approx. 1minute 4) Mode of sweep: Logarithmically sweep or uniform sweep 5) Direction of oscillation: Three mutually perpendicular directions, including the direction of stem travel 6) Duration of testing: 2 hours each, for a total of 6 hours There shall be no sign of damage mechanically and electrically. t6 c O1 .0 1 22 5-5 Impact Proof File No. MITSUMI ELECTRIC CO., LTD. 1385 ( 4 / 10 ) Items 5-7 Solderability Test conditions Measurements shall be made following the test set force below: 1) Soldering temperature: 230 +/- 5 degrees C 2) Soldering time : 3 +/- 0.5 seconds 3) Solder : Sn-3.0Ag-0.5Cu 4) Soldering flux : Rosin 25%, Alcohol 75% 5-8 Soldering heat 1) Hand soldering 1-1) Temperature of soldering iron tip: 350 +/- 5 degrees C Resistance 1-2) Soldering time: 3 +1/-0 seconds 1-3) The soldering iron should be applied to the terminals. 1-4) Excessive load should not be applied. 1-5) Power of the soldering iron should not exceed 15 W.     2) Reflow soldering 2-1) Heating method: Far-infrared heating 2-2) Temperature-time profile (Maximum value): As shown below. 2-3) Allowable soldering time: 2 times Criteria More than 75% of the dipped part shall be covered with solder. There shall be no damage on appearance. Electrical performance in Section 4 shall be assured. Operating force (Item 5-1) shall be assured. Temp [oC] Max 5sec 250 230 180 150 90+/- 30sec 0 30±10sec Profile of Reflow Soldering (Max) Time [sec] The condition mentioned above is a temperature on the PWB surface on which parts are mounted. There are cases where board's temperature greatly differs from switch's surface temperature, depending on board's material, size, thickness, etc. Please care, therefore, should be used not to allow switch's surface temperature to exceed 250℃. t6 c O1 .0 1 22 The above temperature profile is the conditions for heat resistance test. Therefore, conditions of soldering shall be confirmed under actual production conditions. 5-9 Other precautions for soldering 1) Do not overheat when you solder with soldering iron. 2) Following the soldering process, do no try to clean the switch with a solvent or the like. 3) Safeguard the switch assembly against flux penetration from its top side. 4) As the conditions vary somehow on the kind of reflow soldering equipment, please make sure you have the right one before use. 5) As the click ratio may deteriorate when a high heat load is applied, reflow soldering should be performed in the shortest period and at the lowest temperature possible. 6) Please use the proper amount of solder in order to prevent the flux penetration into the switch. 7) Switch terminals and PWB upper face shall be free from flux prior to soldering. 8) Note that if the load is applied to the terminals during soldering it might cause deformation and defects in electrical performance. File No. MITSUMI ELECTRIC CO., LTD. 1385 ( 5 / 10 ) 6. ENDURANCE Test conditions Items 6-1 Operating life Measurements shall be made following the test set forth below : (1) DC12V 50mA resistive load. (2) Rate of operation: 2 operations per second. (3)Depression: :The maximum load of a specification of the operating force. (4) Cycles of operation: 100,000 cycles (5)Pusher :Material SUS, φ4.0 Tip: flat shape 7. ENVIRONMENTAL Test conditions Items 7-1 Moisture After testing at +60+/-3 ℃and 90 to 96% in relative humidity for Resistance 96 +/-5 hours, the sample is allowed to stand under normal temperature and humidity conditions within an hour, then, measurement shall be made within an hour. *Water drops shall be removed. 7-2 Heat Resistance After testing at +85+/-3 ℃ for 96 +/-5 hours, the sample is allowed to stand under normal temperature and humidity conditions within an hour, then, measurement shall be made within an hour. 7-3 Resistance to   Low Temperature 7-4 Temperature    Cycling Criteria Contact resistance:1ohm max. Insulation resistance:10M-ohm min. Bounce: ON bounce 20 msec max. OFF bounce 20 msec max. Withstanding voltage: Item 4-3 Operating force: -30 to +30% of initial force Travel: Item 5-3 Criteria Contact resistance: 1ohm max. Insulation resistance: 10M-ohm min. Bounce: ON bounce 20 msec max. OFF bounce 20 msec max. Withstanding voltage: Item 4-3 Operating force: -30 to +30% of initial force Travel: Item 5-3 After testing at -40+/-3 ℃ for 96 +/-5 hours, the sample is allowed to stand under normal temperature and humidity conditions within an hour, then, measurement shall be made within an hour. *Water drops shall be removed. Following continuous five cycles of the temperature cycling test set forth below: 85+/-2oC -40+/-3oC 120min 120min 10 to 15min 1cycle 10 to 15min t6 c O1 .0 1 22 File No. MITSUMI ELECTRIC CO., LTD. 1385 ( 6 / 10 ) 8. USE CONDITIONS 8-1 Operating temperature range: -40 to +60oC. No freeze and condensation. (Temperature range which the switch is electrically ON and OFF. ) 8-2 Using Environment   1) Do not expose the switch to corrosive gas such as sulfur gas, and salty wind.   2) Visible dust must be cleared.   3) As the switch may deform and change its quality, please do not apply excessive force to the switch. 9 9. STORAGE CONDITIONS 9-1 Storage temperature: -25 to 85oC. Storage Relative humidity: 10 to 75%. No freeze and condensation. △6 9-2 Using Environment   1) Do not expose the switch to corrosive gas such as sulfur gas, and salty wind.  2) Visible dust must be cleared.  3) As the switch may deform and change its quality, please do not apply excessive force to the switch. 9-3 Storage Method  1) Store the switches in the following condition: Seal up with plastic bags in a taping state, △6  2) Do not stack too many switches for strafe. Shall be free from high temperature and high humidity.  3) The operating part of the switch should be free position in storage. 9-4 Retention period: 1 year △6 10. PRECAUTIONS IN USE 10-1 Do not clean the switch with a solvent or the like. 10-2 Never use the product beyond the rated current and voltage. 10-3 Do not apply excessive load to the terminals and the operating part. 10-4 Larger stress than specified and/or shock shall not be applied to the operating part. 10-5 The stress shall be not applied to the upper face of the switch. 10-6 The switch will be broken, if you give larger stress than specified while operating. Take most care not to give both upward and downward stress to the switch when you operate it. 10-7 10 7 As A the h switch i h may be b broken, b k please l ddo no apply l a load l d off more than h 5N to the h switch i h bbosses. 10-8 After mounting the switches on PWBs, please do not stack too many PWBs in order to avoid excessive load to the switch mounted area. 10-9 The dimensions of a pattern for mounting a printed circuit board shall refer to the recommended dimensions in the outline drawing. 10-10 Use of organic acid flux shall be avoided because it may cause corrosion of the switch. Please make sure the type of flux before you use it. 10-11 As this switch is designed for reflow soldering, if you place it at the edge of PWB for convenience, then flux may get into the sliding part of the switch during automatic dip soldering after being mounted, so do not apply auto dip after being mounted. 10-12 If the switch is given stress from the side, the cover may drop off and it may result in damages to switch functions. Therefore, please handle it with extreme care. 10-13 The operating part should be moved to the appointed position in order to ensure proper operation. 10-14 Do not give stress to the upper face of the switch while operating and use the switch under given stress. 10-15 If you use this product in one of the following environmental conditions, progress of sulfaration and oxidization on the contact part (silver) will be accelerated, which may cause contact failure. Therefore, be careful about the operation environment. 1) Around a sulfarate hot spring where sulfide gas is generated. 2) In case this product is always used in a place where exhaust gas from automobiles exist. 10-16 If you push the edge of the operating part, the switch might not operate properly. Therefore, pressure to the operating part shall be applied to the whole surface equally and avoid the pressured to the specific one portion. t6 c O1 .0 1 22 1.6 NG File No. Figure-4 MITSUMI SU ELECTRIC C C CO., LTD.. 1385 ( 7/10 ) 10-17 Unless provided for otherwise, the products have been designed and manufactured for application in equipment and devices which are sold to end users in the market, including audio-visual (AV) equipment, electrical home appliances, office machines, 9 information and communication equipment, and amusement equipment. The products are not intended for use in, and must not be used for, any application for nuclear equipment, driving equipment for aerospace or any other unauthorized use. With the exception of the abovementioned prohibited applications, please contact our sales representative and/or evaluate the total system regarding applicability for applications involving high levels of safety and liability such as medical equipment, burglar alarm equipment, disaster prevention equipment and undersea equipment. Please also incorporate fail-safe design, protection and redundant circuitry, malfunction protection, and/or fire protection into the complete system to ensure safety and reliability of the total system. t6 c O1 .0 1 22 File No. MITSUMI ELECTRIC CO., CO LTD. LTD 1385 ( 8 / 10 ) 11. MANUFACTURING LOCATION <Sales Section> MITSUMI ELECTRIC CO.,LTD. 2-11-2 Tsurumaki, Tama-shi, Tokyo, Japan <Management Section> MITSUMI ELECTRIC CO.,LTD., Kyushu Business Division 1049 Tateiwa, Iizuka-shi, Fukuoka, Japan <Manufacturing Section> QINGDAO MITSUMI ELECTRIC CO.,LTD. No.3 Industrial Area, Chang Jiang Road Qingdao Economic & Technical Development Zone, Qingdao, The people's Republic of China QINGDAO MITSUMI ELECTRONICS CO.,LTD. △7 No.2, Dayangzhou Road, Qingdao West Coast Export Processing Zone, Qingdao city, Shandong Province, People's Republic of China △7 12. TAPE PACKING SPECIFICATION 12-1 Carrier tape dimensions are shown below. 12-2 Taping Procedure 1) Tape winding direction is in clockwise. (When pulling the tape toward, feeding holes should be located on the right side.) 2) Feeding holes shall not be covered with the cover tape. The cover tape shall not be run off the edge of the carrier tape. 3) 100 to 190 mm from the end of tiller tape part shall be empty and 100 to 140 mm from the end of leader tape part shall be empty. Leader part consists of the part which unstuck with cover-tape (20 to 30 mm) and the cover tape shall be extended 150 to 200 mm. 4) After reeling, stick the leader part of cover tape to the side of the reel with adhesive tape (30 to 50 mm) 5) Peeling strength of cover-tape from carrier-tape is 0.1to 1.3N at 165 to 180deg. angle in reverse. 6) Switch shall be packed in single direction. 7) 5000 switches shall be pack in a reel. 8) The label which indicates our model number, part number, contained quantity and inspection number shall be stuck on the side of the reel reel. 9) The switch shall drop by itself when it is pushed with a force of 0.1 to 0.2 from the back after peeling the cover tape. t6 c O1 .0 1 22 File No. MITSUMI ELECTRIC CO., LTD. 1385 ( 9 / 10 ) 13. Packing Specification 1) Inner Package      Reel Expansion QR Code Label △10 The material of a reel : PS Mitsumi Label 5 reels at maximum shall be packed in a inner bag. PE Bag 2) Outer package      Outer Box Bar Code Label 170 5 reels at maximum shall be packed in a outer package. t6 c O1 .0 1 22 400 400 File No. MITSUMI ELECTRIC CO., LTD. 1385 ( 10 / 10 ) 3) Label      Mitsumi Label PARTNO User Parts No. ************ MODEL Mitsumi Model Name Mitsumi Part No. SOU-****** SPEC.R- G:RoHS Compliant Products Quantity The Country of Origin R66 **** [G] 5000 PCS 5000PCS CHINA M IT S U M IE L E C T R IC C O .,L T D . User Part No. Mitsumi Part No. ************ R66 ****      QR Code Label △10 Model Name R No. - Revision - Quantity - Lot No. a) . QR Code Label description: R663992 R No. Lot No. description 7 O 04 Revision E 010000 - 11 - A - Quantity 01 1 7O04EA011-01 Lot No. - t6 c O1 .0 1 22 a) Example: 01 Production reel No.:1st~9th reel:01~09              10th reel~ :10~ Running time : 2shifts: 1 : 8:00~17:00、2 : 20:00~5:00 3shifts: 1 : 6:00~15:00、2 : 15:00~22:30、 3 : 22:30~6:00 Production line(Equipments) : 1st~9th line:01~09, 10th line~:10~ Production group(operators) : A~C, L~N △7 Production site : Chine (C:CQM, E:CQE) △7 Production date : 01~31 Production month :Jun~Sep:1~9 Oct:O, Nov:N, Dec:D Production year :The last digit of the year File No. 1385 MITSUMI ELECTRIC CO CO., LTD LTD.
R-666939 价格&库存
很抱歉,暂时无法提供与“R-666939”相匹配的价格&库存,您可以联系我们找货
