ONLY FOR REFERENCE
Mitsumi Model Name
Mitsumi Model No.
Operating Force
Pcs/Reel
SOV-168HST
R 66 7842
1.9N
5,000
This specification is only for reference. If you have any questions for the details,
please contact SW engineering division.
For your adopting the products, the formal supply specification will be provided.
2‐11‐2,Tsurumaki,Tama‐shi.Tokyo 206‐8657 Japan.
SWITCH ENGINEERING SECTION
1049,Tateiwa,Iizuka‐shi. Fukuoka 820‐8533 Japan.
n9
u1
J
2
2
(1/9)
General specification
Tactile switches
Approved
Checked
Drawn
Sep. 15.'15 Sep. 15.'15 Sep. 15.'15
SW eng.
SW eng.
SW eng.
Hirahata
Kawaguchi
Higaki
SOV series
Released
Sep. 15. '15
1796
1. General
1.1. Application
This specification is applied to Tactile switches named SOV series.
1.2. Operating temperature range: -40 to +60 deg-C
1.3. Storage temperature range:
-25 to +85 deg-C (Product level)
-20 to +50 deg-C (Taped condition)
1.4. Test conditions
Normal temperature; 5 to 35 deg-C, normal humidity; 45 to 85% RH.
If any doubt arises from judgment, tests and measurements shall be conducted
under the following conditions.
Temperature 20+/- 2deg-C, humidity 65+/-5% RH, and air pressure 86 to 106 kPa.
2. Appearance and Construction
2.1. Dimensions: Specified on Product specifications.
2.2. Materials:
Refer to Table-1.
2.3. Appearance: There shall be no defects that affect the performance of
the products such as crack, scratch, dirt, discoloration,
and contamination.
2.4. Cross section view:
(1) COVER
(2) BUTTON
(3) CLICK SPRING
(4) BASE
(5) TERMINAL
Fig. 1: Cross section of product
Table-1
Components
Material
(1) COVER
Stainless steel
(2) BUTTUN
6T Nylon
(3) CLICK SPRING Stainless steel
(4) BASE
6T Nylon
Phosphor bronze
(5) TERMINAL
Note
Ni+Ag plated
Ag plated
3. Rating
Specified on Product specification.
y
a6
M1
.0
1
12
Revision
Code Division
S 66
1
×1
15.05.05
6.1Operating life item 5 added.
File No.
1796
01
X.Wang
MITSUMI ELECTRIC. CO., LTD.
S-0115
(2/9)
4. Electric Characteristics
Item
Test conditions
Criteria
4.1.
Measurements shall be made under the conditions shown in
Specified on
Contact
Fig. 3.
Product
resistance
1) Load: 2 times of the specified standard operating force. specifications.
2) Measurement conditions: Contact resistance meter at
20 mV Max. and 50 mA Max.
dia. 4.0 mm
Push direction
0.5 mm Max.
Misalignment
Tilt angle
90+/-2 deg
Flat tip
(Material: Stainless steel)
Fig. 2: Push rod
Fig. 3: Measurement conditions
4.2.
Insulation
resistance
Measurements shall be made under the following conditions.
1) Applied voltage: 100 V, DC
2) Duration: 1 min.
3) Applied position: Between terminals.
10 M-ohm Min.
4.3.
Withstanding
1) Applied voltage: 100 V, AC (50/60 Hz)
voltage
2) Duration: 1 min.
min
3) Leak current: 2 mA
4) Applied position: Between terminals.
There shall be
no damage and
breakdown
breakdown.
4.4.
Bounce
ON bounce:
10 ms Max.
Fig. 3.
Bounce time at "ON" and "OFF" shall be measured under the
1) Circuit: Refer to Fig. 4.
2) Load: 1.5 times of the specified standard operating
force.
3) Frequency of operation: 3 to 4 times/sec.
SW
DC5 V
5 k-ohm
OFF bounce:
10 ms Max.
Oscilloscope
Fig. 4: Circuit
"ON"
"ON bounce"
y
a6
M1
.0
1
12
"OFF"
"OFF bounce"
Fig. 5: Bounce
File number
1796
S-0115
(3/9)
5. Mechanical Characteristics
Item
Test conditions
5.1.
Operating
Fig. 3 just after striking 10 times lightly.
force
1) Measurement speed: 0.5 mm/sec.
2) Limit load to apply: 1.5 to 2 times of the specified
5.2.
Return
Force (N)
force
Criteria
Specified on
Product
specifications.
Operating force
Return force
Stroke (mm)
Fig. 6: Force-Stroke curve
5.3.
Click ratio
Refer to 5.1 and 5.2 for the measurement conditions.
Force (N)
T
Travel
l
Specified on
Product
specifications.
Stroke (mm)
Fig. 7 Force-Stroke curve
Fig. 3 and at returned condition.
Load: 30 N
Duration: 15 sec.
5.5.
Impact
resistance
Measurements shall be made after testing under the
1) Acieration: 735 m/s2
2) Duration: 6 msec
3) Test direction: 6 directions
4) Number of test: 3 times per direction (18 times in total)
5.6.
Vibration
resistance
1) Vibration frequency range: 10 to 55 Hz
2) Amplitude: 1.5 mm (peak-to-peak)
3) Sweep ratio: 10-55-10 Hz in approx. 1 min.
4) Frequency sweep mode: Logarithmic or Liner sweep
5) Direction of vibration: 3 orthogonal directions including
the direction of operation.
6) Duration: 2 hr each (6 hr in total)
There shall be
no electrical
and mechanical
abnormality.
y
a6
M1
.0
1
12
5.4.
Stopper
strength
File number
1796
S-0115
(4/9)
Item
Test conditions
5.7.
Solderability
1) Solder temperature: 230 +/- 5 dig-C
2) Dipping time: 3 +/- 0.5 sec.
3) Composition of solder: Sn-3.0Ag-0.5Cu
4) Soldering flux: Rosin 25%, Alcohol 75%
5.8.
Soldering
heat
resistance
1) Hand soldering
1-1) Temperature of soldering iron tip: 350 +/- 5 degrees C
1-2) Soldering time: 3 +1/-0 seconds
1-3) The soldering iron should be applied to the terminals.
1-4) Excessive load should not be applied.
1-5) Power of the soldering iron should not exceed 15 W.
2) Measurements shall be made after reflow soldering under
2-1) Heating method: Far-infrared radiation heating
2-2) Temperature profile : As shown in below.
2-3) Allowable soldering process: 2 times Max.
Temp.
(deg-C)
Max.10 sec
260
30+/-10 sec
230
180
150
Criteria
More than 75%
of dipped part
shall be covered
with solder.
There shall be
no abnormality
such as marked
looseness,
drop-off,
and assured
4. Electrical
Characteristics.
Operating force:
Item 5.1.
90+/-30 sec
Fig. 8: Reflow soldering profile Time (sec)
The condition mentioned above is a temperature on the PWB
surface on which parts are mounted. There are cases where
board's temperature greatly differs from switch's surface
temperature,depending on board's material, size,
thickness, etc.Please care, therefore, should be used
not to allow switch's surface temperature to exceed 260℃.
y
a6
M1
.0
1
12
The above temperature profile is the conditions for heat
resistance test. Therefore, conditions of soldering shall be
confirmed under actual production conditions.
5.9. Precautions for soldering
1) Do not overheat when you solder with soldering iron.
2) Following the soldering process, do no try to clean the switch with a solvent or the like.
3) Safeguard the switch assembly against flux penetration from its top side.
4) As the conditions vary somehow on the kind of reflow soldering equipment,
please make sure you have the right one before use.
5) As the click ratio may deteriorate when a high heat load is applied, reflow soldering
should be performed in the shortest period and at the lowest temperature possible.
6) Please use the proper amount of solder in order to prevent the flux penetration
into the switch.
7) Switch terminals and PWB upper face shall be free from flux prior to soldering.
8) Note that if the load is applied to the terminals during soldering
it might cause deformation and defects in electrical performance.
File number
1796
S-0115
(5/9)
6. Durability
Item
Test conditions
6.1.
Operating life following conditions.
1) Electrical load: Rated load or no load.
2) Rate of operation: 2 cycles/sec.
3) Depression: The maximum value of specified operating
force.
4) Cycles of operation: Specified on the product
specification.
5)
Push rod:Material:Stainless steel φ4.0Flat
1
Criteria
Contact
resistance:
20 ohm Max.
Insulation
resistance:
10 M-ohm Min.
Withstanding
voltage:
Item 4.3.
Bounce
(ON/OFF):
20 msec Max.
Operating force:
Within +/-30%
of specified
initial value.
Travel:
Item 5.3.
7 Environmental
7.
Item
Test conditions
7.1.
Following the test set forth below the sample shall be left in
Humidity
normal temperature and humidity conditions for 1 hr before
resistance
measurements are made.
Water drops shall be removed.
1) Temperature: 60+/-3 deg-C, Humidity: 90 to 96% RH
2) Duration: 96+/-5 hr
7.2.
Heat
resistance
7.3.
Cold
resistance
1) Temperature: 85+/-3 deg-C
1) Temperature: -40+/-3 deg-C
Criteria
Contact
resistance:
1 ohm Max.
Insulation
resistance:
10 M-ohm Min.
Withstanding
voltage:
Item 4.3.
Bounce
(ON/OFF):
20 msec Max.
Operating force:
Within +/-30%
of specified
initial value.
y
a6
M1
.0
1
12
Travel:
Item 5.3.
File number
1796
CTRIC. CO., LTD.
S-0115
(6/9)
7. Environmental
Item
Test conditions
7.4.
Following continuous 5 cycles of the temperature cycling test
Temperature set forth below, the sample shall be left in normal
cycling
temaperature and humidity conditions for 1hr before
Criteria
Contact
resistance:
1 ohm Max.
Insulation
resistance:
10 M-ohm Min.
85+/-2 deg-
Withstanding
voltage:
Item 4.3.
-40+/-3 deg120 min
120 min
10 to 15 min
10 to 15 min
1 cycle
Fig. 9: Temperature cycling test conditions
Bounce
(ON/OFF):
20 msec Max.
Operating force:
Within +/-30%
of specified
initial value.
Travel:
Item 5.3.
y
a6
M1
.0
1
12
8 Use Condition
8.
8.1. Operating temperature range: Refer to the item 1.2.
(Temperature range which the product is ON and OFF electrically.)
There shall be no freezing and condensation.
8.2. Using environment
1) Do not expose the products to corrosive gas such as sulfur gas and salty wind.
2) Visible dust must be cleared.
3) Please do not apply excessive load to the products to avoid deformation and
deterioration.
9. Storage Condition
9.1. Storage temperature range: Refer to the item 1.3. There shall be no freezing and
condensation.
9.2. Environment
1) Do not expose the products to corrosive gas such as sulfur gas, and salty wind.
deterioration.
9.3. Storage method
1) Products shall be packed in an airtight plastic bag and stored in cool place avoiding
direct sunshine.
2) Do not stack too many switches for strafe. Shall be free from high temperature and
high humidity.
3) Do not store the products in the state of applying load on it's operation area.
4) Products should be used within six months after the date of delivery.
File number
1796
S-0115
(7/9)
10. Precautions in Use
10.1. Do not clean the products with a solvent or the like.
10.2. Do not use the products with beyond the rated current and voltage.
10.3. Do not apply excessive load to the terminals and the operating part.
10.4. Larger static load than specified and/or shock shall not be applied to the operating part.
10.5. After mounting the products on PWB/FPC, please do not stack too many PWB/FPC
in order to avoid excessive load to the switch mounted area.
10.6. The dimensions of a pattern on PWB/FPC shall refer to the recommended dimensions in
10.7. Use of organic acid flux shall be avoided because it may cause corrosion of the switch.
Please make sure the type of flux before you use it.
10.8. As this switch is designed for reflow soldering, if you place it at the edge of PWB
for convenience, then flux may get into the sliding part of the switch during automatic dip
soldering after being mounted, so do not apply auto dip after being mounted.
10.9. If the switch is given stress from the side, the cover may drop off and it may result in
damages to switch functions. Therefore, please handle it with extreme care.
10.10. The operating part should be moved to the appointed position in order to ensure proper
operation.
10.11. If you use this product in one of the following environmental conditions, progress of
sulfaration and oxidization on the contact part (silver) will be accelerated, which may
cause contact failure. Therefore, be careful about the operation environment.
1) Around a sulfarate hot spring where sulfide gas is generated.
2) In case this product is always used in a place where exhaust gas from automobiles
exist.
10.12. Unless provided for otherwise, the products have been designed and manufactured for
application in equipment and devices which are sold to end users in the market,
including audio-visual equipment, electrical home appliances, office machines,
information and communication equipment
equipment, and amusement equipment
equipment.
The products are not intended for use in, and must not be used for, any application for
nuclear equipment, driving equipment for aerospace or any other unauthorized use.
With the exception of the abovementioned prohibited applications, please contact us
(MITSUMI) and/or evaluate the total system regarding applicability for
applications involving high levels of safety and liability such as medical equipment,
burglar alarm equipment, disaster prevention equipment and undersea equipment.
Please also incorporate fail-safe design, protection and redundant circuitry, malfunction
protection, and/or fire protection into the complete system to ensure safety and reliability
of the total system.
10.13. If you intend to use the products for automotive, please let us know beforehand.
10.14. If you push the edge of stem, the switch might not operate properly.
An actuator to push the stem of switch in device case needs to be designed to touch
the whole surface of the stem evenly.
OK
NG
y
a6
M1
.0
1
12
Fig. 10
File number
1796
S-0115
(8/9)
11. Packing Specification
11.1. Dimensions of carrier tape are as shown below.
11.2. Taping rule
1) Tape winding direction is in clockwise.
(When pulling the tape toward, feeding holes should be located on the right side.)
2) Feeding holes shall not be covered with the cover tape.
The cover tape shall not be run off the edge of the carrier tape.
3) 160 mm or more from the end of trailer tape part shall be empty.
4) The leader part shall be 400 mm or more and it should include 100 mm of empty part.
The leader part shall have 20 to 30 mm of un-sealed cover tape.
5) The top tape of the leader part shall be stuck on the side of the reel by 30 to 50 mm
using adhesive tape.
6) Peeling strength of cover tape from carrier tape is 0.1 to 1.3 N at 165 to 180 deg.
7) Bar-code label and Mitsumi label shall be stuck on the side of the reel.
8) The products shall free drop from the reversed carrier tape without cover tape after
pressing at 0.1 to 0.2 N force.
9) Continuous two missing switches shall not be allowed.
Total number of missing switches shall be 0.1% or less of the packed quantity per reel.
10) Switch shall be packed in single direction.
11) 5,000 switches shall be packed in a reel.
A
12
D
B
C
1.75 5.5 +/-0.1 8+/-0.1
E
4+/-0.1
F
2+/-0.1
G
dia.1.5
Fig. 12 Carrier tape dimensions
Trailer part
(with 160 mm or more of empty pockets)
Pocket with products
Empty pocket
100 mm over
Top tape without sealing
20 to 30 mm
y
a6
M1
.0
1
12
Leader part
(400 mm or more)
Fig. 13 Taping specification
File number
1796
S-0115
(9/9)
12. Packing Specification
1) Inner packing specification
14 +/-0.5
Reel
380 dia.
60 Min. dia.
2 +/-0.5
3 - 2 +/-0.5
Material: PS
13 +/-0.5 dia.
Bar-code label
MITSUMI label
2) Outer box specification
Bar-code label
170
400
400
PE bag
5 reels max. shall be packed in an inner bag.
3) MITSUMI label specification
PARTNO
[G]
MODEL
SPEC.R-
R 66 ******
****** PCS
00
MADE IN CHINA
R 66 ******
MITSUMI model code
MITSUMI part number
Quantity
Lot number
Country of origin
Customer's part number
Lot - production line number
MITSUMI part number
y
a6
M1
.0
1
12
MITSUMI ELECTRIC CO.,LTD.
G: RoHS compliance
File number
1796
S-0115
