ONLY FOR REFERENCE
Mitsumi Model Name
STU-057A23AC
Mitsumi Model No.
R 66 8127
Operating Force
2.25N
Pcs/Reel
20,000
Any products mentioned in this catalog are subject to any modification in their appearance
and others for improvements without prior notification.
If you have any questions for the details, please contact SW engineering division.
For your adopting the products, the formal supply specification will be provided.
MITSUMI ELECTRIC CO.,LTD.
2‐11‐2,Tsurumaki,Tama‐shi.Tokyo 206‐8657 Japan.
SWITCH ENGINEERING SECTION
1049,Tateiwa,Iizuka‐shi. Fukuoka 820‐8533 Japan.
b1
e2
F0
5
02
(1/9)
General specification
Tactile switches
1814
STU series
Approved
Checked
Issued
Mar. 9, '17
SW Eng.
Ogura
Mar. 9, '17
SW Eng.
Nakamura
Mar. 9, '17
SW Eng.
Otaka
Released
March 9, 2017
1. General
1.1. Application
This specification is applied to Tactile switches named STU series.
1.2. Operating temperature range: -40 to +85 deg-C
1.3. Storage temperature range:
-40 to +85 deg-C (Product level) △4
-20 to +50 deg-C (Taped condition)
1.4. Test Conditions
Normal temperature; 5 to 35 deg-C, normal humidity; 45 to 85% RH.
If any doubt arises from judgment, tests and measurements shall be conducted
under the following conditions.
Temperature 20+/- 2deg-C, humidity 65+/-5% RH, and air pressure 86 to 106 kPa.
2. Appearance and Structure
2.1. Dimensions: Specified on Product specifications.
2.2. Materials:
Refer to Table-1.
2.3. Appearance: There shall be no defects that affect the performance of
the products such as crack, scratch, dirt, discoloration, air bubble of
ACTUATOR, and contamination.
2.4. Cross section view:
(1) ACTUATOR
(2) COVER FILM
(3) DOME
(4) HOUSING
(5) TERMINAL
Fig. 1: Cross section of product
(1)
(2)
(3)
(4)
(5)
Component
ACTUATOR
COVER FILM
DOME
HOUSING
TERMINAL
Table-1
Material
9T Nylon
9T Nylon
Stainless steel
9T Nylon
Phosphor bronze
Note
Ag plated
Ag plated
3. Rating
Specified on Product specification.
n9
u1
J
02
Code Division
Revision
P1.Correction of the use temperature range
04 ×3
03 ×1
02 ×2
01
'19.05.30 P8,P9.Change Carrier reel diagram
'17.09.22
'17.09.12
'17.08.01
Added
Added
Deleted, Changed, Added
File No.
Nakashima
Otaka
Otaka
S 66
1814
04
Nakamura
MITSUMI ELECTRIC. CO., LTD.
S-0115
(2/9)
4. Electric Characteristics
Item
Test conditions
Criteria
4.1.
Measurements shall be made under the following conditions. Specified on
Contact
1) Load: 2 times of the specified standard operating force. Product
resistance
2) Measurement conditions: Contact resistance meter at
specifications.
20 mV Max. and 10uA to 10mA.
4.2.
Insulation
resistance
1) Applied voltage: 100 V, DC
2) Applied position: Between terminals.
50 M-ohm Min.
4.3.
Withstanding
1) Applied voltage: 100 V, AC (50/60 Hz)
voltage
2) Duration: 1 min.
3) Leak current: 2 mA
4) Applied position: Between terminals.
There shall be
no damage and
breakdown.
4.4.
Bounce
ON bounce:
10 ms Max.
Measurements shall be made under the conditions shown in
Fig. 10(P7).
Bounce time at "ON" and "OFF" shall be measured under the
1) Circuit: Refer to Fig. 2.
2) Load: 1.5 times of the specified standard operating
force.
3) Frequency of operation: 3 to 4 times/sec.
SW
DC5 V
5 k-ohm
OFF bounce:
10 ms Max.
Oscilloscope
Fig. 2: Circuit
"ON"
"OFF"
"ON bounce"
"OFF bounce"
Fig. 3: Bounce
n9
u1
J
02
File number
1814
S-0115
(3/9)
5. Mechanical Characteristics
Item
Test conditions
5.1.
Operating
Fig. 10(P7) just after pressing 10 times lightly.
force
1) Measurement speed: 0.5 mm/sec.
2) Limit load to apply: 1.5 to 2 times of the specified
5.2.
Return
Force (N)
force
Criteria
Specified on
Product
specifications.
Operating force
Return force
Travel (mm)
Fig. 4: Force-Stroke curve
5.3.
Click ratio
5.4.
Travel
Refer to 5.1 and 5.2 for the measurement conditions.
Click ratio = (a - b) / a x 100%
Force (N)
Specified on
Product
specifications.
a
b
Travel
Travel (mm)
Fig. 5 Force-Stroke curve
5.5.
Stopper
strength
Measurements shall be made after applying static load
Load: 50 N
Duration: 15 sec.
5.6.
Side push
strength
1) Load: 3 N
2) Duration: 15 sec.
Test shall be made after two times of reflow soldering.
n9
u1
J
2
0.1mm 02
Fig.6: Side push strength test
There shall be
no electrical
and mechanical
abnormality.
File number
1814
S-0115
(4/9)
Item
Test conditions
5.7.
Measurements shall be made after testing under the
Vibration
resistance
1) Vibration frequency range: 10 to 55 Hz
2) Amplitude: 1.5 mm (peak-to-peak)
3) Sweep ratio: 10-55-10 Hz in approx. 1 min.
4) Frequency sweep mode: Logarithmic or Liner sweep
5) Direction of vibration: 3 orthogonal directions including
the direction of operation.
6) Duration: 2 hr each (6 hr in total)
5.8.
Impact
resistance
1) Acieration: 735 m/s2
2) Duration: 6 msec
3) Test direction: 6 directions
4) Number of test: 3 times per direction (18 times in total)
5.9.
1
Solderability 1 1) Solder temperature: 260 +/- 5 dig-C
1 2) Dipping time: 2 +/- 0.5 sec.
3) Composition of solder: Sn-3.0Ag-0.5Cu
4) Soldering flux: Rosin 25%, Alcohol 75%
5.10.
Soldering
heat
resistance
Measurements shall be made after reflow soldering under
1) Heating method: Far-infrared radiation heating
2) Temperature profile: As shown in below.
3) Allowable soldering process: 2 times Max.
Temp.
(deg-C)
250
220
1
180
150
1
40+/-10 sec
Criteria
There shall be
no electrical
and mechanical
abnormality.
There shall be
no electrical
and mechanical
abnormality.
More than 95%
of dipped part
shall be covered
with solder.
(Except for
fracture surface)
There shall be
no abnormality
such as marked
looseness and
drop-off.
4. Electrical
Characteristics.
Operating force:
Item 5.1.
90+/-30 sec
Fig.7: Reflow soldering profile
Time (sec)
n9
u1
J
2
5.11. Precautions for soldering
1) This product is designed for reflow soldering. Please do not solder manually.
2) Do not wash the product with solvent or the like.
3) The soldering conditions will be different depending on reflow soldering machines.
Conditions of soldering shall be confirmed under actual production conditions.
4) Reflow soldering shall be performed in shorter time and at lower temperature. Otherwise
click ratio may be decreased.
5) Please set the proper volume of solder in order to prevent soldering flux ingress and float
of the products.
6) Please do not apply soldering flux to the terminals and mounting surface of PWB/FPC.
7) Note that if the load is applied to the terminals during soldering it might cause
deformation and defects in electrical performance.
File number
1814
S-0115
(5/9)
6. Durability
Item
Test conditions
6.1.
Operating life following conditions and conditions shown in Fig.11.
1) Electrical load: Rated load or no load.
2) Rate of operation: 2 cycles/sec.
3) Depression: The maximum value of specified operating
force.
4) Cycles of operation: Specified on the product
specification.
Criteria
[After 300k cycle]
Contact
resistance:
20 ohm Max.
Insulation
resistance:
10 M-ohm Min.
Withstanding
voltage:
Item 4.3.
Bounce
1 (ON/OFF):
30 msec Max.
Operating force:
Within +/-30%
of specified
initial value.
Travel:
Item 5.4.
3
7. Environmental
Item
Test conditions
7.1.
Following the test set forth below the sample shall be left in
Humidity
normal temperature and humidity conditions for 1 hr before
resistance
measurements are made.
Water drops shall be removed.
1) Temperature: 65+/-2 deg-C, Humidity: 90 to 96% RH
2) Duration: 96+/-5 hr
1) Temperature: 85+/-3 deg-C
7.3.
Cold
resistance
1) Temperature: -40+/-3 deg-C
n9
u1
J
02
7.2.
Heat
resistance
[After 500k cycle]
There shall be
no electrical
and mechanical
abnormality.
Criteria
Contact
resistance:
1 ohm Max.
Insulation
resistance:
10 M-ohm Min.
Withstanding
voltage:
Item 4.3.
Bounce
(ON/OFF):
20 msec Max.
Operating force:
Within +/-30%
of specified
initial value.
Travel:
Item 5.4.
File number
1814
S-0115
(6/9)
7. Environmental
Item
Test conditions
7.4.
Following continuous 5 cycles of the temperature cycling test
Temperature set forth below, the sample shall be left in normal
cycling
temperature and humidity conditions for 1hr before
Criteria
Contact
resistance:
1 ohm Max.
Insulation
resistance:
10 M-ohm Min.
85+/-2 deg-
-40+/-3 deg-
1
1
60 min
60 min
1
max 5 min
max 5 min
1
1 cycle
Fig.8: Temperature cycling test conditions
Withstanding
voltage:
Item 4.3.
Bounce
(ON/OFF):
20 msec Max.
Operating force:
Within +/-30%
of specified
initial value.
Travel:
Item 5.4.
7.5.
Water
resistance
02
Ingress shall be confirmed after the test under the following
conditions based on IPX8.
1) Depth of immersion: 1.5 m
2) Duration of immersion: 30 min.
Water which affect
characteristics
shall not get inside
the switch.
n9
u1
J
2
8. Use Condition
8.1. Operating temperature range: Refer to the item 1.2.
(Temperature range which the product is ON and OFF electrically.)
There shall be no freezing and condensation.
8.2. Using environment
1) Do not expose the products to corrosive gas such as sulfur gas and salty wind.
2) Visible dust must be cleared.
3) Please do not apply excessive load to the products to avoid deformation and
deterioration.
9. Storage Condition
9.1. Storage temperature range: Refer to the item 1.3. There shall be no freezing and
condensation.
9.2. Environment
1) Do not expose the products to corrosive gas such as sulfur gas, and salty wind.
deterioration.
File number
1814
S-0115
(7/9)
9.3. Storage method
1) Products shall be packed in an airtight plastic bag and stored in cool place avoiding
direct sunshine.
2) Do not stack too many switches for strafe. Shall be free from high temperature and
high humidity.
3) Do not store the product in the state of applying load on its operation area.
4) Products should be used within six months after the date of delivery.
10. Precautions in Use
10.1. Do not clean the products with a solvent or the like.
10.2. Do not use the products with beyond the rated current and voltage.
10.3. Do not apply excessive load to the terminals and the operating part.
10.4. Larger static load than specified and/or shock shall not be applied to the operating part.
10.5. After mounting the products on PWB/FPC, please do not stack too many PWB/FPC
in order to avoid excessive load to the switch mounted area.
10.6. The dimensions of a pattern on PWB/FPC shall refer to the recommended dimensions in
10.7. If you use this product in one of the following environmental conditions, progress of
sulfaration and oxidization on the contact part (silver) will be accelerated, which may
cause contact failure.
Therefore, be careful about the operation environment.
1) Around a sulfarate hot spring where sulfide gas is generated.
2) In case this product is always used in a place where exhaust gas from automobiles
exist.
10.8. Do not push the cover film of products with something sharp.
10.9. Please design and assemble your unit not to apply over load to the switch.
10.10. Please let us know beforehand if you use other shape of pushing rod than the shape
described in Fig. 2.
10.11. Please be careful on designing and handling especially when the switch is being built into
the unit, not to add side force (static or impact) to the ACTUATOR as shown below
(Fig. 10), because the ACTUATOR might deform or come off.
Do not apply side
n9
u1
J
2
ACTUATOR
Fig. 9 Load and impact from side direction
10.12. Unless provided for otherwise, the products have been designed and manufactured for
application in equipment and devices which are sold to end users in the market,
including audio-visual equipment, electrical home appliances, office machines,
information and communication equipment, and amusement equipment.
The products are not intended for use in, and must not be used for, any application for
nuclear equipment, driving equipment for aerospace or any other unauthorized use.
With the exception of the abovementioned prohibited applications, please contact us
(MITSUMI) and/or evaluate the total system regarding applicability for
applications involving high levels of safety and liability such as medical equipment,
burglar alarm equipment, disaster prevention equipment and undersea equipment.
Please also incorporate fail-safe design, protection and redundant circuitry, malfunction
protection, and/or fire protection into the complete system to ensure safety and reliability
of the total system.
10.13. If you intend to use the products for automotive, please let us know beforehand.
10.14. Please avoid the usage which the ON state of the switch lasts for a long time.
File number
1814
S-0115
(8/9)
11. Push Rod
Push direction
Refer to Fig.-10 and 11 for
the measuring conditions and Push
rod
the recommended push rod.
φ1.5±0.05 mm
0.3 mm max.
Tilt angle range:
90± 2 °
(Vertical direction)
Flat tip
R0.1±0.05
Fig.-11 Push rod
(Material: SUS)
Fig.-10 Measuring conditions
12. Packing Specification
12.1. Dimensions of carrier tape are as shown below.
12.2. Taping rule
1) Tape winding direction is in clockwise.
(When pulling the tape toward, feeding holes should be located on the right side.)
2) Feeding holes shall not be covered with the cover tape.
The cover tape shall not be run off the edge of the carrier tape.
3) 160 mm or more from the end of trailer tape part shall be empty.
4) The leader part shall be 400 mm or more and it should include 100 mm of empty part.
The leader part shall have 20 to 30 mm of un-sealed cover tape.
5) The top tape of the leader part shall be stuck on the side of the reel by 30 to 50 mm
using adhesive tape.
6) Peeling strength of cover tape from carrier tape is 0.1 to 1.3 N at 165 to 180 deg.
7) QR-code label and Mitsumi label shall be stuck on the side of the reel.
8) The products shall free drop from the reversed carrier tape without cover tape after
pressing at 0.1 to 0.2 N force.
9) Continuous two missing switches shall not be allowed.
Total number of missing switches shall be 0.1% or less of the packed quantity
per reel.
10) The direction of products in the pockets is not specified.
11) 20,000 switches shall be packed in a reel.
A
12
B
1.75
C
D
E
F
5.5
2
4+/-0.1 4+/-0.1
Fig. 12 Carrier tape dimensions
Trailer part
(with 160 mm or more of empty pockets)
G
1.5 dia. +0.1/-0
H
1
Empty pocket
100 mm over
Top tape without sealing
20 to 30 mm
Pocket with products
Fig. 13 Taping specification △4
n9
u1
J
02
Leader part
(400 mm or more
File number
1814
S-0115
(9/9)
13. Packing Specification
1) Inner packing specification
13.4±1
Reel △4
380 dia
60 Min. dia
2.0±0.2
3-2±0.5
Material:PS
13±0.2 dia
QR-code label
MITSUMI label
2) Outer box specification
Bar-code label
170
400
400
PE bag
5 reels max. shall be packed in an inner bag.
3) MITSUMI label specification
PARTNO
[G]
MODEL
SPEC.R-
R 66 ******
****** PCS
00
R 66 ******
MITSUMI model code
MITSUMI part number
Quantity
Lot number
Country of origin
Customer's part number
Lot - production line number
MITSUMI part number
n9
u1
J
2
MADE IN CHINA
G: RoHS compliance
File number
1814
S-0115
