M22S-T20SB10-E230-R
M22S-T20SB10-E230-R
    MJE(茂仁)
    SELEC-THUMB-2POS ALT-1A-LED-RED
M22S-T20SB10-E230-R 数据手册
Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 M22 M22 Series Pushbuttons  Features  For front panel cut-outs measuring ø22.3mm  IP65 protection  M3.5 screw terminals  PCB (ø0.1t) terminals  Tough and durable body material  Available for multi-layer installations Flathead (M22FP) Extended head (M22XP) Double Actuator (M22DP) Selectors (M22S) ⚠ All back facing terminal block buckles (SB) are ONLY compatible with Moujen in house control boxes (M22B).  Recognition(s)  CE – EN60947  UL – UL508  RoHS Compliant  Reach Unaffected Buzzer (M22BZ) Pilot Lights (M22L/M22LC) Emergency Stop (M22E/M22EL) Key-operated (M22K) Mushroom Actuator (M22MP/M22MPL) Control Box (M22B)  Characteristics (1-layer) (1-layer) Possible (1-layer) Possible Terminal Type Contact Form(s) Poles & Throws Actuation Sequence(s) Screw(M3.5), or PCB Each Block: A, B Two Blocks: A+B, 2A, 2B SPST, 2*SPST, DPST-NO/NC, DPST Single Make, or Single Break, or Make & Break, or Double Make, or Double Break Operating Temp. AC Rated DC Rated Oil Resist Dust Resist Water Resist IP -25 to 70 C Switch: 6A 230V LED: 14mA 30~230V Switch: 3A 24V LED: 14mA 30V Yes Yes Yes 65 Positive Opening Electrical Contact Yes(NC) & No(NO) max 12 (2-layers: 4 contact blocks with 2 lamp blocks) Operation Frequency Service Life (min.ops) Dielectric Strength Momentary~3600/hr Alternate~1800/hr Selectors~2000/hr E-Stop~600/hr Momentary=5,000,000 Alternate=1,000,000 Selectors=100,000 E-Stop=100,000 Between live part and ground=2500Vac, 1min Between terminals of different poles=2500Vac, 1min Between terminals of the same poles=1000Vac, 1min Operating Humidity Contact Resistance Insulation Resistance Vibration 85% RH max 50mΩ max. (initial) 100MΩ min. (500VDC) 1.5mm amplitude at 10-55Hz Recommended tightening forces Purpose Control Box Panel Mount Screw type Lock Ring Circuitry Tightening 8.5±0.5 kgf.cm 2.0 N·m NC Blocks 88 NO Blocks moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 M22 Additional Characteristics: Lamp blocks (LED) Codename in nomenclature = E30 12~30VDC, 5~14mA, 0.25W/24V Codename in nomenclature = E230 85~264VAC, 5~15mA, 0.33W/24V Additional Characteristics: Buzzer (M22BZ) Sound types: Dimensions Sound Pressure: Sound Frequency: Insulation Voltage: Operating Voltage: Current Draw: Operating Temperature: Operating Humidity Insulation Resistance Dielectric Strength Vibration Service Life (min.) Slow pulse, Fast pulse Surface=ø29.7mm Length=53mm 80dB at rated voltage within 1 meter 2.5KHz±300HZ 60V AC/DC AC=110V, 220V DC=24V AC/DC
M22S-T20SB10-E230-R
1. 物料型号: - MJE moujen - M22系列按钮,包括Flathead (M22FP)、Extended head (M22XP)、Double Actuator Selectors (M22DP) (M22S)等。
2. 器件简介: - MJE Moujen Electric Co., Ltd. (台湾总部)自1961年以来生产M22系列按钮。 - 特点包括适用于直径ø22.3mm的前面板切口、IP65防护等级、M3.5螺钉端子、PCB (ø0.1t)端子和坚固耐用的机身材料。 - 包括蜂鸣器(M22BZ)、指示灯(M22L/M22LC)、紧急停止(M22E/M22EL)和钥匙操作(M22K)等不同功能的按钮。
3. 引脚分配: - 正面端子类型包括SF (螺钉端子) 和 PF (PCB端子)。 - 背面端子类型为SB (螺钉端子),仅与Moujen公司内部控制箱(M22B)兼容。 - 电气接触类型包括SPST、2SPST、DPST-NO/NC和DPST。 - 可能的极性和掷数包括每个块:A, B;两个块:A+B, 2A, 2B。
M22S-T20SB10-E230-R 价格&库存
很抱歉,暂时无法提供与“M22S-T20SB10-E230-R”相匹配的价格&库存,您可以联系我们找货
