Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961
M22
M22 Series
Pushbuttons
Features
For front panel cut-outs measuring ø22.3mm
IP65 protection
M3.5 screw terminals
PCB (ø0.1t) terminals
Tough and durable body material
Available for multi-layer installations
Flathead
(M22FP)
Extended head
(M22XP)
Double Actuator
(M22DP)
Selectors
(M22S)
⚠ All back facing terminal block buckles (SB) are ONLY
compatible with Moujen in house control boxes (M22B).
Recognition(s)
CE – EN60947
UL – UL508
RoHS Compliant
Reach Unaffected
Buzzer
(M22BZ)
Pilot Lights
(M22L/M22LC)
Emergency Stop
(M22E/M22EL)
Key-operated
(M22K)
Mushroom Actuator
(M22MP/M22MPL)
Control Box
(M22B)
Characteristics
(1-layer)
(1-layer) Possible
(1-layer) Possible
Terminal Type
Contact Form(s)
Poles & Throws
Actuation Sequence(s)
Screw(M3.5),
or PCB
Each Block:
A, B
Two Blocks:
A+B, 2A, 2B
SPST,
2*SPST,
DPST-NO/NC,
DPST
Single Make,
or Single Break,
or Make & Break,
or Double Make,
or Double Break
Operating Temp.
AC Rated
DC Rated
Oil
Resist
Dust
Resist
Water
Resist
IP
-25 to 70 C
Switch: 6A 230V
LED: 14mA 30~230V
Switch: 3A 24V
LED: 14mA 30V
Yes
Yes
Yes
65
Positive
Opening
Electrical
Contact
Yes(NC)
No(NO)
max 12
(2-layers: 4
contact
blocks with 2
lamp blocks)
Operation Frequency
Service Life (min.ops)
Dielectric Strength
Momentary~3600/hr
Alternate~1800/hr
Selectors~2000/hr
E-Stop~600/hr
Momentary=5,000,000
Alternate=1,000,000
Selectors=100,000
E-Stop=100,000
Between live part and ground=2500Vac, 1min
Between terminals of different poles=2500Vac, 1min
Between terminals of the same poles=1000Vac, 1min
Operating Humidity
Contact Resistance
Insulation Resistance
Vibration
85% RH max
50mΩ max. (initial)
100MΩ min. (500VDC)
1.5mm amplitude at 10-55Hz
Recommended tightening forces
Purpose
Control Box
Panel Mount
Screw type
Lock Ring
Circuitry
Tightening
8.5±0.5 kgf.cm
2.0 N·m
NC Blocks
88
NO Blocks
moujenglobal.com
M22
Additional Characteristics: Lamp blocks (LED)
Codename in nomenclature = E30
12~30VDC, 5~14mA, 0.25W/24V
Codename in nomenclature = E230
85~264VAC, 5~15mA, 0.33W/24V
Additional Characteristics: Buzzer (M22BZ)
Sound types:
Dimensions
Sound Pressure:
Sound Frequency:
Insulation Voltage:
Operating Voltage:
Current Draw:
Operating Temperature:
Operating Humidity
Dielectric Strength
Vibration
Service Life (min.)
Slow pulse,
Fast pulse
Surface=ø29.7mm
Length=53mm
80dB at rated voltage within 1 meter
2.5KHz±300HZ
60V AC/DC
AC=110V, 220V
DC=24V
AC/DC
很抱歉,暂时无法提供与“M22FP-ASB02-E30-R”相匹配的价格&库存,您可以联系我们找货
