Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961
VER.6.1 2022
M4CZ
M4CZ Series
Enclosed Basic Switch
Features
Positive Opening basic switch
Durable and economical PPS plastic with fiber glass enclosure
Enclosure material helps resist against corrosive chemicals
Completely sealed IP67 protection rating
SVT cable type (UL approved)
Recognition(s)
CE – EN60947
CCC – GB14048.5-2017
RoHS Compliant
Characteristics
Positive
Opening
Electrical
Contact
Terminal Type
Contact Form(s)
Poles & Throws
Actuation Sequence(s)
Yes
3 Points
Wire
Form C
SPDT
Break(1) Make(2)
Operating Temp.
AC Rated
DC Rated
IP
Oil
Resist
Dust
Resist
Water
Resist
Operating
Speed
-20 to 70 Celsius
1.5A 250V
0.4A 125V
67
Yes
Yes
Yes
0.1mm to
0.5m/sec
Operation Frequency
Contact Resistance
Insulation Resistance
Vibration
Mechanically: 120/min
Electrically: 30/min
300mΩ max. (initial)
100MΩ min. (500VDC)
1.5mm amplitude at 1055Hz
Storage Humidity
Service Life (min.)
Dielectric Strength
85% RH max
Mechanically: 2,000,000 operations
Electrically: 500,000 operations
1000VAC, 50/60Hz for 1 minute between noncontinuous terminals
Recommended tightening forces
Purpose
Mounting
Screw type
M4
Circuitry
Tightening
1.18~1.37N⋅m
59
moujenglobal.com
VER.6.1 2022
M4CZ
Materials
Actuation touch part
Electrical contact point
Enclosure
Nylon, or Stainless Steel
Silver 99.9%
PPS plastic with glass fiber
Nomenclature
Series:
Cable direction
Actuator:
Cable Length:
M4CZ –
45
01 –
1L
45=Bottom out
Stainless Steel Touch Part
01=Plunger
02=Roller plunger
03=Cross roller plunger
04=Side rotary, roller
06=Spring, coil
07=Side rotary, adjustable rod
08=Side rotary, adjustable roller
11=Plunger, sealed boot
1L=1m SVT
2L=2m SVT
3L=3m SVT
Nylon Touch Part
12=Roller plunger
13=Cross roller plunger
14=Side rotary, roller
16=Spring, coil
18=Side rotary, adjustable roller
60
moujenglobal.com
VER.6.1 2022
M4CZ
Dimensions & Operating Characteristics
*Measurements in millimeters
*Actuation touch part materials does not affect operating characteristics
M4CZ-4501
M4CZ-4502/4512
M4CZ-4503/4513
61
M4CZ-4504/4514
moujenglobal.com
VER.6.1 2022
M4CZ
M4CZ-4506
M4CZ-4516
M4CZ-4507
62
M4CZ-4508/4518
moujenglobal.com
VER.6.1 2022
M4CZ
M4CZ-4511
Handling and Usage
The bottom of the Switch at the cable outlet is resin-molded. Secure the cable at a point 5 cm from
the Switch bottom to prevent exertion of excess force on the cable.
When bending the cable, provide a bending radius of 45 mm min. so as not to damage the cable
insulation or sheath. Excessive bending may cause fire or leakage current.
63
moujenglobal.com
很抱歉,暂时无法提供与“M4CZ-4516-1L”相匹配的价格&库存,您可以联系我们找货
