M4CZ-4504-1L
M4CZ-4504-1L
    MJE(茂仁)
    LIMIT SWITCH SEAL POS-OPEN SLIM
M4CZ-4504-1L 数据手册
Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 VER.6.1 2022 M4CZ M4CZ Series Enclosed Basic Switch  Features  Positive Opening basic switch  Durable and economical PPS plastic with fiber glass enclosure  Enclosure material helps resist against corrosive chemicals  Completely sealed IP67 protection rating  SVT cable type (UL approved)  Recognition(s)  CE – EN60947  CCC – GB14048.5-2017  RoHS Compliant  Characteristics Positive Opening Electrical Contact Terminal Type Contact Form(s) Poles & Throws Actuation Sequence(s) Yes 3 Points Wire Form C SPDT Break(1) Make(2) Operating Temp. AC Rated DC Rated IP Oil Resist Dust Resist Water Resist Operating Speed -20 to 70 Celsius 1.5A 250V 0.4A 125V 67 Yes Yes Yes 0.1mm to 0.5m/sec Operation Frequency Contact Resistance Insulation Resistance Vibration Mechanically: 120/min Electrically: 30/min 300mΩ max. (initial) 100MΩ min. (500VDC) 1.5mm amplitude at 1055Hz Storage Humidity Service Life (min.) Dielectric Strength 85% RH max Mechanically: 2,000,000 operations Electrically: 500,000 operations 1000VAC, 50/60Hz for 1 minute between noncontinuous terminals Recommended tightening forces Purpose Mounting Screw type M4 Circuitry Tightening 1.18~1.37N⋅m 59 moujenglobal.com VER.6.1 2022 Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 M4CZ  Materials Actuation touch part Electrical contact point Enclosure Nylon, or Stainless Steel Silver 99.9% PPS plastic with glass fiber  Nomenclature Series: Cable direction Actuator: Cable Length: M4CZ – 45 01 – 1L 45=Bottom out Stainless Steel Touch Part 01=Plunger 02=Roller plunger 03=Cross roller plunger 04=Side rotary, roller 06=Spring, coil 07=Side rotary, adjustable rod 08=Side rotary, adjustable roller 11=Plunger, sealed boot 1L=1m SVT 2L=2m SVT 3L=3m SVT Nylon Touch Part 12=Roller plunger 13=Cross roller plunger 14=Side rotary, roller 16=Spring, coil 18=Side rotary, adjustable roller 60 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 VER.6.1 2022 M4CZ  Dimensions & Operating Characteristics *Measurements in millimeters *Actuation touch part materials does not affect operating characteristics M4CZ-4501 M4CZ-4502/4512 M4CZ-4503/4513 61 M4CZ-4504/4514 moujenglobal.com VER.6.1 2022 Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 M4CZ M4CZ-4506 M4CZ-4516 M4CZ-4507 62 M4CZ-4508/4518 moujenglobal.com VER.6.1 2022 Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 M4CZ M4CZ-4511  Handling and Usage The bottom of the Switch at the cable outlet is resin-molded. Secure the cable at a point 5 cm from the Switch bottom to prevent exertion of excess force on the cable. When bending the cable, provide a bending radius of 45 mm min. so as not to damage the cable insulation or sheath. Excessive bending may cause fire or leakage current. 63 moujenglobal.com
M4CZ-4504-1L 价格&库存
很抱歉,暂时无法提供与“M4CZ-4504-1L”相匹配的价格&库存,您可以联系我们找货
M4CZ-4504-1L
