MJ2-1734
MJ2-1734
    MJE(茂仁)
    检测开关 DC125V AC250V
MJ2-1734 数据手册
Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 MJ2-1 Series Basic Limit Switch  Features  Sealed actuator variants for better oil resistance  High temp. resistant phenolic enclosure types (T385J)  Fire resistant phenolic enclosure types (T200HF)  Recognition(s)  CE – EN61058-1  UL – UL-508  CCC – GB14048.5-2008  VDE – 0630/04.86  RoHS Compliant  Reach Unaffected  Characteristics Positive Opening Electrical Contact Terminal Type Contact Form(s) Poles & Throws Actuation Sequence(s) No 3 Points Screw Form C SPDT Break(1) Make(2) Operating Temp. AC Rated DC Rated IP Oil Resist Dust Resist Water Resist Operating Speed -15 to 80 C -15 to 150 C (phenolic) 15A 125V-250V, 20A 125V-250V 0.5A 125V, 0.25A 250V 40 Yes or No No No 0.01mm to 1m/sec Operation Frequency Contact Resistance Insulation Resistance Vibration Mechanically: 240/min Electrically: 20/min 15mΩ max. (initial) 100MΩ min. (500VDC) 1.5mm amplitude at 1055Hz Storage Humidity Service Life (min.) Dielectric Strength 85% RH max Mechanically: 20,000,000 operations Electrically: 500,000 operations 1000VAC, 50/60Hz for 1 minute between noncontinuous terminals 2000VAC, 50/60Hz for 1 minute between currentcarry part and ground Recommended tightening forces Purpose Mounting Screw type M4 Panel Mount Screw Nut Screw terminal Circuitry Tightening 1.18~1.37 N⋅m 2.94~4.92 N⋅m 0.25±0.05 N⋅m  Materials Actuation touch part Electrical contact point Enclosure Nylon, Stainless Steel, Teflon, POM, Nickel plated copper or brass Silver 99.9% PBT plastic with glass fiber, or Phenolic resin (T385J or T200HF) 24 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1  Nomenclature Series: Actuator: MJ2 – 1704 – Terminal: 1300=Nickel plated copper Pin plunger 1305=Nickel plated copper Pin plunger, tall 1306=Nickel plated copper Plunger, short 1307=Nickel plated copper Plunger, tall, panel mount 1308=SUS303 Roller metal plunger, panel mount 1309=SUS303 Cross roller metal plunger, panel mount 1326=Teflon Plunger, short 1327=Teflon Plunger, tall, panel mount 1328=Teflon Roller metal plunger, panel mount 1329=Teflon Cross roller metal plunger, panel mount Blank=Screw A=Quick (250, t=6.37mm) S=Soldering 1500=Cat whisker metal lever 1503=POM Roller metal lever, r31.9mm, 1-way action 1504=POM Roller metal lever, r53.8mm, 1-way action 1506=Simulated roller metal lever, r28.1mm 1523=SUS303 Roller metal lever, r31.9mm, 1-way act 1524=SUS303 Roller metal lever, r53.8mm, 1-way act 1701=Straight metal Lever, r63.5mm 1702=Straight metal Lever, r38.2mm 1703=POM Roller metal lever, r48.5mm 1704=POM Roller metal lever, r26.6mm 1705=POM Roller metal lever, r37.2mm 1706=Straight metal Lever, r28.7mm 1707=Straight metal Lever, r53mm 1708=PBT plastic lever, Red push lever type 1723=Nickel plated brass Roller metal lever, r48.5mm 1724=Nickel plated brass Roller metal lever, r26.6mm 1725=Nickel plated brass Roller metal lever, r37.2mm Enclosure Material: Amps: PH – 20 Blank=Plastic PH=Phenolic (T385J) FR=Phenolic (T200HF) Blank=15A 20=20A (only applicable to Phenolic enclosure types) S – Soldering Terminal A – Quick Connect Terminal With Oil Resist Boot Seals 1315=Nickel plated copper Pin plunger, tall 1316=Nickel plated copper Plunger, short 1317=Nickel plated copper Plunger, tall (no panel mount) 1336=Teflon Plunger, short 1337=Teflon Plunger, tall 1513=POM Roller metal lever, r31.9mm, 1-way action 1514=POM Roller metal lever, r53.8mm, 1-way action 1516=Simulated roller metal lever, r28.1mm 1533=SUS303 Roller metal lever, r31.9mm, 1-way act 1534=SUS303 Roller metal lever, r53.8mm, 1-way act 1711=Straight metal lever, r63.5mm 1712=Straight metal lever, r38.2mm 1713=POM Roller metal lever, r48.5mm 1714=POM Roller metal lever, r26.6mm 1733=Nickel plated brass Roller metal lever, r48.5mm 1734=Nickel plated brass Roller metal lever, r26.6mm CB-2 – Terminal protection cover 25 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1  Dimensions & Operating Characteristics *Measurements in millimeters MJ2-1300 MJ2-1305 MJ2-1306 MJ2-1307 26 MJ2-1308 MJ2-1309 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 MJ2-1326 MJ2-1327 MJ2-1328 MJ2-1329 27 MJ2-1500 MJ2-1503 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 MJ2-1504 MJ2-1506 MJ2-1523 MJ2-1524 28 MJ2-1701 MJ2-1702 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 MJ2-1703 MJ2-1704 MJ2-1705 MJ2-1706 29 MJ2-1707 MJ2-1708 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 MJ2-1723 MJ2-1724 30 MJ2-1725 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 With Oil Resist Boot Seals MJ2-1315 MJ2-1316 MJ2-1317 MJ2-1336 31 MJ2-1337 MJ2-1513 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 MJ2-1514 MJ2-1516 MJ2-1533 MJ2-1534 32 MJ2-1711 MJ2-1712 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 MJ2-1 MJ2-1713 MJ2-1714 MJ2-1733 33 MJ2-1734 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 Precautions for Safe Use • Be sure to ground. Otherwise electric shock may result. • Do not touch charged switch terminals while the switch is carrying current, otherwise electric shock may result. • Do not disassemble or touch the inside while the power is turned on, otherwise electric shock may result. • Do not handle products without proper protective gears; doing so may result in injury. • Connect a fuse which has 1.5 to 2 times higher breaking current than the product, in order to prevent products from short-circuit damage. • On the occasion when using the switch with EN/IEC/GB ratings, use a 10 A fuse that complies IEC60269, either type gG or gL. • Operating conditions will affect product durability. Be sure to check with actual using conditions before usage. • Do not drop the switch. • Do not connect a Single Limit Switch to two power supplies that are different in polarity or type. This may increase the risk of interference. • Be sure to keep the load current less than the rated value. Otherwise, there is the possibility that the switch may be damaged and/or burnout. • Do not use the Switch by itself in atmospheres containing flammable or explosive gases. Arcs and heat resulted from constant actuating may cause fire or explosion. • Be sure to prevent foreign materials such as scrapped cable intrusion into the switch when wiring. Otherwise, there is the possibility of spoiling normal operations. • Do not wire to the wrong terminals. • Using the Switch in a pressed-in state for an extended period of time can accelerate part deterioration and also lead to failure to return to the original position. Check the Switch beforehand, and perform periodic inspection and replacement. • Do not store or use the switch at the following places: (i)where the temperature fluctuates greatly. (ii)where the humidity is very high and condensation may occur. (iii)Where the vibration is great. (iv)Where there is direct sun light. (v)Where exposed to salty winds. (vi)Where exposed to cutting powder, machining chips, oil, and chemicals inside the protective doors. (vii)Where exposed to cleansers, thinners, and other solvents. • Do not use or store the Switch in locations with corrosive gas, such as sulfuric gas (H2S or SO2), ammonium gas (NH3), nitric gas (HNO3), or chlorine gas (Cl2), or high temperature and humidity. Otherwise, contact failure or corrosion damage may result. • Do not disassemble and/or modify the switch at any time. Otherwise, there is the possibility of spoiling the normal operation. • Do not apply deformative and/or degenerative forces to products. • If products have been used over an extended period of time or uses stated in products datasheets, contact reliability may still degrade due to natural oxidation; resulting in inadequate conductivity, which may lead to an accident. Please swiftly preform inspections and insure proper replacements are carried out. • Only allow certified professionals to preform installing and maintenance tasks. 109 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 Precautions for Correct Use Operating Environment • This switch is only for indoor use. If it is used in outdoor, it may cause switch failure. • Take special care if products are to be used at places where there is fine powder, mud and/or foreign materials accumulating. Check actual using conditions before using. If this is unavoidable, highly recommend integrating protective equipment. This is considered not Moujen’s obligations. • Seal material may deteriorate if a Switch is used outdoor or where subject to special cutting oils, solvents, or chemicals. Always appraise performance under actual application conditions and set suitable maintenance and replacement periods. This is considered not Moujen’s obligations. • Install Switches where they will not be directly subject to cutting chips, dust, or dirt. The Actuator and Switch must also be protected from the accumulation of cutting chips or sludge. ❌Incorrect Correct • Constantly subjecting a Switch to vibration or shock can result in wear, which can lead to contact interference with contacts, operation failure, reduced durability, and other problems. Excessive vibration or shock can lead to false contact operation or damage. Install Switches in locations not subject to shock and vibration and in orientations that will not produce resonance. • The Switches have physical contacts. Using them in environments containing silicon gas will result in the formation of silicon oxide (SiO2) due to arc energy. If silicon oxide accumulates on the contacts, contact interference can occur. If silicon oil, silicon filling agents, silicon cables, or other silicon products are present near the Switch, suppress arcing with contact protective circuits (surge suppressor) or remove the source of silicon gas. • If the Switch will be left in a location outside the storage environment conditions, if condensation has formed, or after long term storage exceeding one year, at the minimum, check the operating characteristics, contact resistance, insulation resistance, and dielectric strength. And conduct a check under the operating conditions. Handling & Usage • Do not remove or replace any built-in switches. Doing so may damage the product, resulting in increased risk of malfunctioning. • Do not use excessive force to insert, remove or twist keys of key-selector products. Doing so may damage the product, resulting in increased risk of malfunctioning. • Do not actuate products and hold its position for excessive amounts of time. Doing so will reduce the life of the internal spring as well as structural integrity; thus, increase risk of malfunctioning. • Do not bend or twist cables with excessive force. When bending is required, provide a bending radius of 45 mm min. so as not to damage the cable insulation or sheath. Excessive bending may cause fire or leakage current. • To change the installation position of the actuator: By loosening the Allen-head bolt on the actuator lever, the position of the actuator can be set anywhere within 360°. • To change the orientation of the head: By removing the head screws (two or four screws), mounting in any of four orientations is possible. Be sure to change the plunger for internal operations at the same time. The roller plunger can be set in either of two positions at 90°. • Flipping the roller to a different side: Loosen the Allen-head bolt, allows flipping the roller to the opposite side. • Adjusting the length of the rod or lever: The length of the rod or lever can be adjusted by loosening the Allen-head bolt. • Adjusting the rolling arm lever: (i) The roller arm can be set freely within a range of 225° after loosening the nut. (ii) The roller arm mounting bracket can be set in any direction after loosening the nut. 110 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 Mounting and Tightening • Please view each individual product page’s allowed parameters for details. • Please follow these parameters diligently. Otherwise products may not function properly. Wiring & Cabling • Use M3.5-nylon insulation covered crimp terminals (round type) • Appropriate wire size is AWG18. • Do not supply electric power when wiring. Otherwise electric shock may result. • Do not pull on the wires with excessive force. • Avoid connecting the wires directly to the terminal. Instead, attach using a crimp terminal. • Grounding is only installed on models with ground terminals. • In the case of prewired connector and direct connector: Holding the connector certainly when pulling connector. Do not pull the cable with excessive force. Conduit Installation • The connector must be tightened at a suitable tightening torque. Tightening with excessive torque could damage the case. • Select the connector based on the sealed rubber inner diameter for matching the cable outer diameter. • When mounting the connector, use seal tape (not needed if the connector includes an O-ring) on the threaded section of the connector to ensure sealing performance. • To ensure compliance of this Switch with the CSA standards, use of a waterproof connector compliant to CSA regulations. • Using an inappropriate connector or assembling Switches incorrectly (assembly, tightening torque) can result in malfunction, leakage current, or fire. Be sure to read the connector instruction manual thoroughly beforehand. • Even when the connector is assembled and set correctly, ends of the cable inside the Switch may come in contact. This can lead to malfunction, leakage current, or fire. Thus, be sure to protect the end of the cable from splashes of oil or water and corrosive gases. • The following wiring is recommended for preventing the entry of fluids from the conduit opening. No envelopment of cable jacket in conduit. Exposed single wires. Partial/loose envelopment of cable jacket in conduit ❌Incorrect ❌Incorrect Full envelopment of cable jacket in conduit. Correct Actuating Terminology 111 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 Integrating into systems – Limit Switches • Carefully determine the position and shape of the dog or cam so that the actuator will not abruptly snap back, thus causing shock. In order to operate the Limit Switch at a comparatively high speed, use a dog or cam that keeps the Limit Switch turned ON for a sufficient time so that the relay or valve will be sufficiently energized. • The method of operation, the shape of the cam or dog, the operating frequency, and the travel after operation have a large influence on the durability and operating accuracy of the Limit Switch. The cam or dog must be smooth in shape. Correct ❌Incorrect Correct ❌Incorrect Correct ❌Incorrect 112 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 ❌Incorrect Correct • Appropriate force must be imposed on the actuator by the cam or dog in both rotary operation and linear operation. If the dog touches the lever as shown below, the operating position will not be stable. ❌Incorrect Correct • Unbalanced force must not be imposed on the actuator. Otherwise, wear and tear on the actuator may result. ❌Incorrect Correct • Mount so that the actuator travel after operation (OT) is not exceeded. If the travel after operation (OT) exceeds the limit, switch failure could result. When mounting the Limit Switch, be sure to adjust the Limit Switch carefully while considering the whole movement of the actuator. • When using a pin-plunger actuator, make sure that the stroke of the actuator and the movement of the dog are located along a single straight line. ❌Incorrect Correct 113 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 Terms and Conditions Agreement Read and understand Please carefully read and understand all information published (on all platforms authorized by Moujen), before purchasing. Purchasing any Moujen products expresses your understanding and agreement towards the terms and conditions erected by Moujen Electric Co., Ltd. If you do not understand any information published, you are always welcome to consult with an official Moujen representative, and other authorized affiliates. Limited Warranty (a) LIMITED WARRANTY. MOUJEN’S LIMITED WARRANTY WARRANTS THAT PRODUCTS WILL BE FREE FROM DEFECTS IN MATERIALS AND WORKMANSHIP FOR A PERIOD OF TWELVE MONTHS; FROM THE DATE OF SALE BY MOUJEN (OR SUCH OTHER PERIOD EXPRESSED IN WRITING BY MOUJEN). MOUJEN DISCLAIMS ALL OTHER WARRANTIES, EXPRESS OR IMPLIED. (b) MOUJEN MAKES NO WARRANTY OR REPRESENTATION, EXPRESS OR IMPLIED, ABOUT A PARTICULAR PURPOSE OF THE PRODUCTS. BUYER ACKNOWLEDGES THEMSELVES THAT THE PRODUCTS WILL SUITABLY MEET THE REQUIREMENTS OF THEIR INTENDED USE. (c) Resolutions. Moujen’s sole obligation shall be, at Moujen’s discretion, to: (i) replace the non-complying Product (in the form originally shipped. Buyer is responsible for labor charges for removal or replacement thereof.), (ii) repair the non-complying Product, or (iii) repay or credit Buyer an amount equal to the purchase price of the non-complying Product. All resolutions must first be initiated through Return Merchandise Authorization procedures. Only testing sample products may not initiate Return Merchandise Authorization procedures. Only gratuitous and testing sample products are not subjected to monetary obligations; and have Limited Liabilities. Moujen shall not be responsible for warranty, repair, indemnity or any other claims or expenses regarding Products unless Moujen’s analysis confirms that the Products were properly handled, stored, installed and maintained; and not subject to contamination, abuse, misuse or inappropriate modification. Return Merchandise Authorization of any Products by Buyer must be approved in writing by Moujen and authorized affiliates. Moujen further disclaims all warranties and responsibilities of any type for claims or expenses based on infringements by Products or otherwise of any intellectual property rights. Moujen shall not be liable for the suitability or unsuitability or the results from the use of Products in combination with any electrical or electronic components, circuits, system assemblies or any other materials or substances or environments. Any advice, recommendations or information given orally or in writing, are not to be interpreted as an amendment or addition to the above warranty. Return Merchandise Authorization All Buyers initiating Return Merchandise Authorization (also known as RMA) must provide Proof of Transaction documentation, and Pictures or Videos detailing potentially non-compliant areas. All received information and documentation are subjected to Moujen’s Privacy Policy. (a) Non-compliancy inquiries: Buyers initiating RMA may provide Moujen and affiliates, to their best knowledge, with: (i) Pictures or Videos of how products are installed in system(s), (ii) Pictures or Videos of how products are actuated in system(s), (iii) Pictures or Videos of electrical energies subjugated to Moujen products, (iv) System schematics relating to Moujen product in question, and (v) Pictures or Videos of packaging when received. Additionally, once products are in shipped state, Moujen retains full rights to not accept and/or authorize returns due to Buyer’s own mismanagement. Signed orders shall not be subject to cancellation or modification either in whole or in part without Seller's written consent and then only with terms that will reimburse Seller for all applicable costs incurred by virtue of the sale; including costs of purchased materials, engineering costs and a reasonable allowance for profit. Seller's written consent must be given in advance of Buyer's return of Products for credit. Seller reserves the right to cancel any sale of Products without liability to Buyer (except for refund of monies already paid), if the manufacture or sale of the goods is or becomes technically or economically impractical. 114 moujenglobal.com Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961 Limitation on Liability MOUJEN SHALL NOT BE LIABLE FOR SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, LOSS OF PORFITS, OR PRODCUTION OR COMMERCIAL LOSS IN ANY WAY CONNECTED WITH THE PRODUCTS, WHETHER SUCH CLAIM IS BASED IN CONTRACT, WARRANTY, NEGLIGENCE OR STRICT LIABILITY. Moujen disclaims any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. Statements regarding the suitability of products for certain types of applications are based on Moujen's knowledge of typical requirements that are often placed on Moujen products in generic applications. Such statements are not binding statements about the suitability of products for a particular application. IT IS THE CUSTOMER'S RESPONSIBILITY TO VALIDATE THAT A PARTICULAR PRODUCT WITH THE PROPERTIES DESCRIBED IN THE PRODUCT SPECIFICATION IS SUITABLE FOR USE IN A PARTICULAR APPLICATION. Parameters provided in datasheets and/or specifications may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated for each customer application by the customer's technical experts. Product specifications do not expand or otherwise modify Moujen's terms and conditions of purchase, including but not limited to the warranty expressed therein. Further, in no event shall liability of Moujen exceed the individual price of the Product on which liability is asserted. Suitability of Use Moujen shall not be responsible for conformity with any standards, codes or regulations which apply to the combination of the Product in the Buyer’s application, or use of the Product. At Buyer’s request, Moujen will provide applicable third-party certification documents identifying ratings and limitations of use which apply to the Product. This information by itself is not sufficient for a complete determination of the suitability of the Product in combination with the end product, machine, system, or other application or use. Buyer shall be solely responsible for determining appropriateness of the particular Product with respect to Buyer’s application, product or system. Buyer shall take application responsibility in all cases. NEVER USE THE PRODUCT FOR AN APPLICATION INVOLVING SERIOUS RISK TO LIFE OR PROPERTY OR IN LARGE QUANTITIES WITHOUT ENSURING THAT THE SYSTEM AS A WHOLE HAS BEEN DESIGNED TO ADDRESS THE RISKS, AND THAT THE MOUJEN PRODUCT(S) IS PROPERLY RATED AND INSTALLED FOR THE INTENDED USE WITHIN THE OVERALL EQUIPMENT OR SYSTEM. Specifications ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA, THROUGH CONTINUOUS RESEARCH, ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. 115 moujenglobal.com
MJ2-1734
物料型号:MJ2-1系列
器件简介: - MJ2-1系列是基本限位开关,具有密封的执行器变体,提供更好的耐油性能。 - 有高温抗性的酚醛塑料外壳类型(T385J)和防火酚醛塑料外壳类型(T200HF)。
引脚分配: - 电气接触为3个点,端子类型为螺丝端子。 - 接触形式为C型(常开常闭),具有SPDT(单刀双掷)配置。
参数特性: - 操作温度范围为15°C至80°C(普通),15°C至150°C(酚醛)。 - AC额定值有15A 125V-250V和20A 125V-250V,DC额定值为0.5A 125V和0.25A 250V。 - 操作频率为机械240次/分钟,电气20次/分钟。 - 接触电阻最大15毫欧(初始),绝缘电阻最小100兆欧(500VDC)。 - 耐振性能为10-55Hz下1.5mm振幅。
功能详解: - 执行器顺序为断开(1)然后接通(2)。 - 操作速度范围为0.01mm至1m/秒。
应用信息: - 存储湿度最大85%RH,机械寿命为2000万次操作,电气寿命为50万次操作。 - 耐电压性能为非连续端子间1000VAC,50/60Hz,1分钟;电流承载部分与地之间2000VAC,50/60Hz,1分钟。
封装信息: - 执行器触点材料包括尼龙、不锈钢、特氟龙、POM、镀镍铜或黄铜。 - 电气接触点材料为99.9%银。 - 外壳材料为含玻璃纤维的PBT塑料或酚醛树脂(T385J或T200HF)。
MJ2-1734 价格&库存
很抱歉,暂时无法提供与“MJ2-1734”相匹配的价格&库存,您可以联系我们找货
MJ2-1734
