Moujen Electric Co., Ltd. (Taiwan HQ) - Since 1961
VER.6.1 2022
MN-5310
MN Series - Enclosed Basic Switch
Characteristics
Positive
Opening
Electrical
Contact
Terminal Type
Contact Form(s)
Poles & Throws
Actuation Sequence(s)
No
3 Points
Screw
Form C
SPDT Snap
Break(1) Make(2)
Operating Temp.
AC Rated
DC Rated
IP
Oil
Resist
Dust
Resist
Water
Resist
Operating
Speed
-10 to 80 Celsius
10A 250V
0.5A 125V
65
Yes
Yes
Yes
0.01mm to
50cm/sec
Operation Frequency
Contact Resistance
Insulation Resistance
Vibration
Mechanically: 120/min
Electrically: 60/min
25mΩ max. (initial)
100MΩ min. (500VDC)
1.5mm amplitude at 1055Hz
Storage Humidity
Service Life (min.)
Dielectric Strength
85% RH max
Mechanically: 10,000,000 operations
Electrically: 500,000 operations
1000VAC, 50/60Hz for 1 minute between noncontinuous terminals
Recommended tightening forces
Purpose
Mounting
Panel Mount Screw Nut
Screw terminal
Screw type
M4
Circuitry
Tightening
1.18~1.37 N⋅m
2.94~4.92 N⋅m
0.25±0.05 N⋅m
1
moujenglobal.com
VER.6.1 2022
Materials
Actuation touch part
Electrical contact point
Enclosure
Nylon, or Stainless Steel, or Teflon
Silver-Nickel alloy
PBT plastic and stainless steel top
Series Nomenclature
Series:
Actuator:
MN –
5100
5100 = Metallic plunger, short
5100-PT = Teflon plunger, short
5110 = Metallic Plunger
5110-PT = Teflon Plunger
5110L = Metallic Plunger, long
5110XL = Metallic Plunger, extra-long
5120 = Lever, straight, long
5121 = Lever, nylon roller, long
5124 = Lever, nylon roller, long, 1-way action
5140 = Lever, straight
5141 = Lever, nylon roller
5144 = Lever, nylon roller, 1-way action
5161 = Spring, metallic coil
5166 = Spring rod, nylon tip
5169 = Spring, cat whisker
5310 = Metallic Plunger, panel mount
5310-PT = Teflon Plunger, panel mount
5311 = Metallic Roller plunger, panel mount
5311-P = Nylon Roller plunger, panel mount
5311-PT = Teflon Roller plunger, panel mount
5312 = Cross metallic roller plunger
5312-P = Nylon Roller plunger, panel mount
5312-PT = Teflon Roller plunger, panel mount
Features
Durable PBT plastic body with stainless steel top cover
Universal electromechanical limiting applications
Slim side mount body design for tight space installations
O-ring sealed actuators
IP65 protection rating
Recognition(s)
CE – EN60947
UL – UL-508
CCC – GB14048.5-2008
RoHS Compliant
2
moujenglobal.com
很抱歉,暂时无法提供与“MN-5310”相匹配的价格&库存,您可以联系我们找货
